Question about Alesis TransActive Mobile PA System Speaker System for iPod TRANSACTIVE
Hey currently my transactive has all three green lights but are very dim and the front power light wont come on and it wont reconise any form of input. Oh and the red light at the back is shining the brightest
  • 2 more comments
  • david_low Sep 03, 2010
    ive managed to get the sound back and it will charge but now it sounds fuzzy and pops when i touch the volume control
    hello again ive managed to open the front panel and noticed the curcuit board was almost broken in two at the ipod phono input does anyone know an easy way to repair or does any one know where i can but one cheaply
    A Solution at last thanks alot :D
  • Alesis Master
  • 19,396 Answers
Hi.
  • IMPORTANT: Ensure that battery is fully charged.
  • Try disconnecting power for ten minutes (unplug power cord) , also remove battery.
  • After connecting back, connect an audio source, but ensure that volume of input sources is zero and devices are off, or you risk blowing the final amp section.
  • Switch everything on in the following order:
  1. Audio input sources (i.e. microphones, instruments, CD/MP3 Players)
  2. Transactive Mobile
  3. last, any amplifiers
  • Disconnect in reverse order.
  • Check connection cables, a shorted coax may cause the same problem.
If that does not help, then the unit is probably faulty, in that case you will need to call support number listed in user documentation.
Here a manual:Quickstart Manual - Rev C
Posted on Sep 03, 2010
  • Ginko
    Ginko Sep 03, 2010
    Re:managed to open the front panel and noticed the curcuit board was almost
    A: If the crack is not too big, the repair is done re heating solder joints and rebuilding circuits. Better contacting Alesis to see if spare is available. Here contact.
Dim green light on power supply blinking
If the Power supply LED dims and flickers its either your motherboard circuit has been cut or there is a short in the laptop. The AC adapter is not the cause.
Try this:
Remove the battery, then press power button to drain all the current, then re-install battery and plug to adapter.
If that doesn't work, then it's most likely the motherboard.
Mar 19, 2012 | ASUS (X83Vb-X2) PC Notebook
Shut down my PC, unplugged it, moved it to new location. Plugged it back in and it would not power up green light on the ASUS P4P800SE would not stay lite. Replaced power supply, green light on the mother...
Remove cmos battery and then replace it after 3 mins or so,
Try rebooting
If no luck, remove ram modules one at a time and retest
unplug all but hdd and power connector to mobo, cpu and hard drive and retest.
failing that, could be a surge of electricity has damaged your mobo
Jan 11, 2011 | ASUS P4P800SE Motherboard
My dashboard light or green background on the odometer side is very dim. How do i lighten up the green background on my 2004 Range Rover HSE???
There should be a dimmer switch like a roller on the dash or connected to the light switch. It may be also in the form of a button you push upwards to brighten and downwards to dim. Let me know how it turns out, The Raz
Apr 17, 2010 | 2004 Land Rover Range Rover
My thomson dti 6300 250gb free view box wont turn on
Emailed Topuptv and got this reply
Dear Sir/Madam,
Thank you for contacting Top Up TV.
Please note that we are currently aware of an issue affecting some Thomson DTi6300 boxes.
If your DTR will not come out of standby and is not responding to your remote control, please try the following procedures.
Step 1: Power cycle
First of all, remove the power to the box and wait 20 seconds before restoring power.
Wait while the box tries to restart and allow 2 -3 minutes for this to complete.
Try this at least twice.
If it doesn't go to the solid green light then proceed to the next step.
Step 2: Front Panel Reset
Note: This procedure will unfortunately cause you to lose all of the recordings that you have stored on the box. You will need to be able access the back of the DTR and the front panel buttons
1. Remove power to the unit by removing the power cable from the back of the DTR.
2. Wait 20 seconds and restore the power cable while holding in the standby/power on button on the front panel of the DTR.
3. Release the standby button immediately you see a light 'blip' on the DTR front display and then immediately press the following front panel arrow buttons in sequence Up>Down>Left>Right
4.The DTR will now show the Orange LED with the Green LED flashing until the format has been completed in about 60 seconds. The DTR will return to ON automatically.
5. If requested, perform a channel scan to complete the operation.
We apologise for any inconvenience caused. Our Customer Services department can also be contacted on 08444 159 159. However, please note that we are currently experiencing high call volumes and so may not be able to answer your call as quickly as we would like.
Kind Regards,
Richard
May 04, 2009 | Televison & Video
Oem Radio installation
*** 91 park ave with delco bose =
black = ground
dark green = lights on input
grey = panel lights
pink = on input
yellow = power input
orange = battery power input
nca = shield ground
tan = left fr spkr +
orange/black = left & right spkr -neg
lite green = right fr spkr +
nca = shield ground
dark blue = right rear spkr +
dark green/yellow = right & left spkr - neg
brown = left rear spkr +
purple/white = display dim output
pink = vehicle speed input
**** 91 park ave without delco bose =
grey = left front - neg
tan = left front + pos
dark green = right front - neg
light green = right front + pos
black = ground
dark green = display dim signal
grey = panel lights
pink = power antanna
yellow = ign input
light blue = right rear - neg
dark blue = right rear + pos
yellow = left rear - neg
brown = left rear + pos .
there YA go
Dec 27, 2008 | 1991 Buick Park Avenue
RED RING WHEN TURNED ON OFF FOR A WEEK
SYMPTOMS Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360... loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top CAUSE The three flashing red lights may indicate that there is a hardware problem with... loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request on... loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem:
  1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/ ) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/ ) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/ ) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated
  2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.
If your console continues to display three flashing red lights, your console may have to be repaired. For more information about how to start the repair process online, please visit http://www.xbox.com/support (http://www.xbox.com/support) , and then click Repair your console in the upper-right part of the Web page. Note Online console repair service is currently not available in all countries and regions.If you want to instead contact Xbox Customer Support directly, please visit http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to do this.
Nov 26, 2008 | Microsoft Xbox 360 Console
Alesis TransActive Mobile PA System Speaker System for iPod TRANSACTIVE  Logo
551 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Gil Shultz
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
