Question about HP EW192AA Webcam
No camera found appears.i am using hp loptop how can i solve it
How to transfer photos on may casio camera to my loptop
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Apr 08, 2014 | Canon EOS 1100D Rebel T3 Body Only Digital...
Cant transfer pictures to computer
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Apr 04, 2014 | Canon PowerShot SD750 / IXUS 75 Digital...
Won't reboot
Follow Instructions
  • Run Recovery Disk - it will solve your problem .
  • Your OS Has been corrupted. Repair or reinstall it after formatting
  • Prefer Repair disk
Nov 19, 2011 | Compaq Presario CQ60-220US PC Laptop
When my P100 is set up to my HP laptop, the photos do not transfer Everything appears to be set up correctly.
Having gone two months without a response to my query, I assume my suggestion to use a card reader solved the problem.
Jul 06, 2011 | Nikon COOLPIX P100 Digital Camera
My loptop compaq oresario A900/A933TU,I installed window xp,sound card driver not available,please inform me which driver to be used.
I am not sure which driver you need however the following is a link for the recovery discs for the model you mentioned double check and i hope this helps. note that compaq is owned by HP now.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00810334&lc=en&dlc=en&cc=us&site=null&os=228& rule=51714&product=3641176&key=null&sw_lang=
May 28, 2011 | Computers & Internet
Fuji S1500 unable to delete photos after taking them. Unable to see photos back. I delete photos on my loptop and then they appear again.
Deleting or formatting on the computer instead of the camera corrupts the card. The camera does not recognize the operating system used to delete. Stop using the computer to do that!
Apr 12, 2010 | Fuji FinePix 3800 Digital Camera
CDDVDW stop responding
Try reseating the driver or delete registry: Follow the steps but you do that, please back up registry files by clicking on File and import:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Jul 01, 2009 | Compaq Presario F767NR Notebook
Webcam to dark, donot know how to adjust
I have the same problem on an HP Pavilion dv1000.
This is what I have discovered. The properties of the webcam (contrast/brightness etc) are not available via Windows anywhere that I can find.
However if you install Skype you can access these properties, its free, its a good voip client and you can turn off the autoload at startup. Go to Tools > Options > Video Settings and you will see a button marked "Webcam Settings" under the "Select webcam:" dropdown. Click on this and you have access to the webcam properties, I found checking the Low Light option on the Advanced tab makes the webcam image much brighter, you can play with the other settings but I didnt bother.
If you then go to My Computer > HP Webcam you will see that the webcam is also brighter there, this seems to be the case even if you exit Skype. Haven't tested it in other apps but it should work ok.
Hope this helps
Basil
Oct 06, 2008 | HP Pavilion dv1000 Notebook
About my loptop
Try right-clicking anywhere on the blackened area of your desktop, a menu might appear. Scroll down to Properties and click. In the Display Properties window click on the Settings Tab and see if you can re-adjust your screen resolution here, if not then read on...
Power off the laptop. Power on the laptop while holding the F8 key or both the SHIFT and F8 key together, if it boots to the Windows start up screen, power off and try again. This will bring up a menu, you will want the BOOT INTO SAFEMODE menu option.
After the safemode boot process, see if your laptop will display graphics (it should default to 640x480 mode and you should be able to view most of your desktop icons). Right click any where in a black area on your desktop, a menu will appear. Scroll to Properties and click. In the Display Properties window, click on the Settings tab and adjust your screen resolution from here.
Let me know if this works or not.
Jul 10, 2008 | IBM Computers & Internet
HP EW192AA Webcam Logo
23 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
