Question about Canon PowerShot SD300 / IXUS 40 Digital Camera
Lens is jamed
Why my ixus40 's len can not pop out at all
  • Canon Master
  • 4,738 Answers
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jun 03, 2008
Problem for Olympus Zuiko? 40-150 mm f/3.5-4.5 Lens My viewfinder with this lens is dark. Other lens are OK
thats because its not a very good lens or its very dirty,,,tre looking at the light reading and shutter speeds with a similer lens fitted then put on the zuiko and see the difrence
Oct 13, 2009 | Olympus Zuiko 40-150 mm f/3.5-4.5 Lens
The Autofocus does not work on my Nikon D40
1 Possiable dirty lens contact terminals
2 Auto focus motor in lens is jamed/malfuntion
3 Auto focus engagement pin on camera body is not engaging the lens
4 Correct lens,old nikon lens and some 3rd party lens wont work on the D40
Jul 18, 2009 | Cameras
Panasonic DMC-TZ3 Damaged lens rings
i think the colours have gone behind the screen can it be repaired lumix tz7
Jun 20, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
I have a camera canon powershot and the lens was out of the camera while it was off. Now when i try to power on the camera the message error: "lens error. restart the camera".
you have a mechanical jam in the lens gear chain. It happens often when lens is extended, the camera may have slight impact or pressure on the lens, it damages the plastic gear chain and jams. You can try with very light force, jiggle the lens while tuning on the power to disengage from the jam. If this does not help, you need a help from repair technician. Average repair price for this repair would be around $115. -James
Apr 07, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Nikon s200 when camera turned on lens error
You may have a jammed lens assy. When the camera is turned on, camera go through a few stages of processing to be ready to take picutre and if the lens does not respond mechanically, it will give you a lens error. Lens jams due to sand or impact (even unnoticable light impact). If the lens is extended out you can somehow grab the lens barrel lightly with two fingers while turning the power on and nudge it side by side. If this did not help, take it to a reliable local technician for a diagnostic(should be free). Good luck. -james
Mar 28, 2009 | Nikon COOLPIX S200 Digital Camera
E18 error on Canon ixus40 - lens stuck
The E18 error is an error message on Canon digital cameras. The E18 error occurs when anything prevents the zoom lens from properly extending or retracting.[1] The error has become notorious in the Canon user community as it can completely disable the camera, requiring expensive repairs.
A quick internet search for "E18" + "canon" quickly reveals hundreds of similar complaints.
ConsumerAffairs.com reports that the "lens has a feature called bellows claw, which is a gear that physically extends and retracts the lens. A piece that holds the lens, the barrier plate, is not large enough and can sometimes cause the bellows claw to malfunction, resulting in a stuck lens". The result is a black screen that only contains the error message, E18. Another problem mentioned on the site blames a sticky iris in the lens, caused by grease entering inside from the microphones built into the lens. The buildup freezes up the ability of the lens to open.
Nov 13, 2008 | Canon PowerShot SD300 / IXUS 40 Digital...
Lens
The lens will pop up on certain settings, like the night settings
Aug 19, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Parts and service manual of Nikon ED AFNikkor 80-200mm 1:2.8 D zoom lens
Nikon Parts
841 Apollo Street, Suite 100, El Segundo CA 90245
(310) 414-8107, (310) 322-6979
Jan 19, 2008 | Nikon 80-200mm f/2.8D AFED Lens
Problem during assembly in reverse order on Canon SD300 (Ixus40)
Not quite sure where you are having the problem with your camera, but there are several places on the internet that can help fix your camera and/or lens.
Here is one listing I found on eBay for you - http://cgi.ebay.com/Canon-SD500-Camera-LENS-BARRIER-SHUTTER-FLAPS-REPAIR_W0QQitemZ260164183646QQihZ016QQcategoryZ64352QQcmdZViewItem
You can email him your model number and he should be able to help you.
Best of luck!
Dec 20, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon IXUS40, rubber(?) seal between lens rings & body keeps popping out
It can be replaced, but requires removing the front face of the camera. Here's an example disassembly. Proceed no further than removing the front face to install the seal:
http://www.smashedhat.com/sd300repair/
Not sure where you could find a replacement other than from another (broken) camera. The seal is mainly intended to minimize sand and grit from entering the camera, but is not necessary for operation of the camera.
Dec 18, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot SD300 / IXUS 40 Digital Camera Logo
59 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
