Brivis MPS he30i error code 69. Just had ignitor and sensor replaced after error code 62. Heater won't start
4 Suggested Answers
  • 3 Answers
SOURCE: Error code 62 on Brivis Me20 ducted heater
When it comes to error 62 resetting the unit probably won't work. Because the NG1/lo is INSIDE the heater it is subject to significant hot / cold temperature fluctuations - causing crystallisation in soldered joints on the PC board and a loss of electrical continuity.
Posted on May 05, 2010
heatman101
  • 43501 Answers
SOURCE: We have a brivis error
Checkout this thread from this site .....
http://www.fixya.com/support/t638215-brivis_heater_help
There are many great suggestions there...
heatman101
Posted on Dec 30, 2010
jas247
  • 844 Answers
SOURCE: what causes a 71 error code on a brivis ducted
Welcome to FixYa!
Error Code 71 is caused by either of the following: 1. A very low setting on the controller less than 16 degs. 2. Or a higher than 25 degs. setting causing overheating when the damper outlets are mostly closed.
The power supply needs to be reset due to the fault being detected.
Solution:
  • Put the power supply to heater off first
  • Reset the heater panel
  • Press the button again to show EMS on
  • Then set the heater to the required temp. after turning on to the heating mode.
Thank you for using FixYa.
Have a great day.
Jas247
Posted on Jun 04, 2011
Brivis error code 62 hi
Hi Matthew,
It would seem obvious to contact the manufacturer's customer support department. http://brivis.com.au/
Aug 01, 2015 | Heating & Cooling
Brivis multiplex he20e
MPS HE20E is a gas heater. So the unit should need a pilot to be re-ignited. This will happen automatically once you press the ON button on the controller. Assuming the gas supply is normal this should happen immediately. The unit attempts re-ignition 4 to 5 times but if the pilot does not turn on it will display an error code on the controller. Take extreme precautions when dealing with gas appliances. Make sure you call a technician if unsure.
Aug 21, 2014 | Heating & Cooling
Brivis ducted Heater won't get above 19 degrees ,
could be broken ducting letting hot air escape or on the intake side drawing too much outside air in. could be the fan unit not pushing enough air
Jul 26, 2013 | Cars & Trucks
Brivis heater HX 231-XA error code 58
I just called a technician out for a Code 58 error and it started working fine after he reset the controller. He checked for a blockage in the condensation pipe but it was clear so a bit of a mystery.
Apr 25, 2012 | Heating & Cooling
Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Jul 12, 2010 | Heating & Cooling
Hi
Error 62 is related to hot surface ignitor (HSI)or/nglo module
you can check the resistance of the ignitor should be less than 10 oms @ 20 degrees
failing that, if you incomming suppy exceeds 270 volt will also result in error 62
May 04, 2010 | Heating & Cooling
Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Apr 12, 2010 | Heating & Cooling
Brivis Heater help
These Brivis guys and girls are a rip-off. They are only out to take your money. Then can easily ask you to do just as mentioned above. And pronto all works in 3 minutes to be precise.
It is just the power supply reset required due to a fult being detected, either caused by a very low setting on the controller less than 16 degs. or a higher than 25 degs. setting causing overheating when the damper outlets are mostly closed.
So, put the power supply to heater off first, reset the heater panel, press the button again to shaow EMS on and then set the heater to the required temp. after turning on to the heating mode. That simple! That is if it is the error 71 HI.
Jun 01, 2008 | Heating & Cooling
Heating & Cooling Logo
252 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
