Question about Garden
Hi there! When i start my mower, it runs for about 30seconds then it turns off.? not sure why it does it?
  • 472 Answers
Needs a carb kit and needs the fule needs to be flushed out and clean the carb up with some b 12
Posted on Sep 04, 2010
The forward/reverse pedal does not work right. It will only go in forward.
The brake Matt be stuck look under for rod you'll see when it connects to trans wiggle it .also could try placing trans in bypass and running forward holding 30seconds than reverse 30 sect do this about 4 or5 times than place back in drive see if that helps
Apr 09, 2016 | Garden
Doesn't act like it is getting gas. Cranks but wont start. Will start if I pour gas in carboretor but won't stay running. Changed gas filter and fuel pump.
Hi: I sounds like it is not getting gas, it probably need the carburetor cleaned out. but first make sure the gas is turned on, tighten the carb . I you have left it for a long time with out running the gas out it most likely needs the carb cleaned Good Luck I hope I was of some help
Dec 19, 2015 | John Deere EZtrak Z225 Zero-Turn Riding...
How to troubleshoot my Toro MX5060 when it doesn't start?
thats a zero turn mower... are you sure this is your mower ???
Sep 03, 2014 | Toro TimeCutter MX5060 - 23HP 50 Zero Turn...
Yanmar 4TNV88 engine starts,then cuts out after 20-30seconds
It sounds like there is a fuel flow problem. There is a restriction either in the tank or fuel filter that lets enough fuel through to start the engine, but not enough to keep it running.
Mar 17, 2014 | Electrical Supplies
Mower will start and run for less than 30seconds before stopping.This is happening with a mower that has been used only 3 times.Air filter is clean and thegas is fresh.Any ideas?
Check that you haven't the throttle control in the start position. Some mowers have a position on the control which turns on the choke and you have to move the lever to the run position for normal use.
Check the spark plug cable is pushed fully onto the plug. The float valve in the float bowl may not be allowing fuel to flow freely into the bowl. Remove the bowl while holding a container underneath it to collect the fuel. The float bowl works like a toilet cistern and the flow stops when the float rises upwards on the fuel in the bowl. Check the fuel is running ok.
Jul 18, 2011 | Poulan "Poulan" Push Mower
Lawn mower dies when it gets hot when it cools off it starts until hot again I've changed the coil and module
you should change the oil and make sure you are using a good oil. Also, make sure your fuel line isn't running next to any place where it can heat up.
Jun 16, 2011 | John Deere Garden
Mower starts runs five minutes then turns off. After it cools down it will start again and will have same problem.
Hi, your problem sounds like a fuel delivery issue. Make sure that the carb is receiving enough fuel to the bowl and that the fuel filter is not clogged. Hope this helps.
Nov 16, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Is there anyway to bypass or disable the passlock system in an '99 Olds Intrigue?
no. the passlock system talks to the ecm and shuts down the fuel injection.. what kind of problem are u having with it?
Aug 23, 2010 | 1999 Oldsmobile Intrigue
Hi, our kodak dx7590 will start up but a 30seconds
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Dec 29, 2009 | Kodak EasyShare DX7590 Digital Camera
Rover lawn mower is not working
Make sure you get a spark, Clean the gas tank, maybe even go as far as cleaning the carb, make sure everything is like new and start it up.
Jun 21, 2009 | Garden
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
