Question about Generac Power Systems Generac iX800 Watt Inverter GeneratorNot for sale in California
I have thee problem on commins gen set QSX 15 fault code is 427 can degrade how to reset
Can voltage on Powermate be adjusted?
yes
the adjustment is by the rpm setting on the governor spring
thee is a nut that you adjust the spring tension with and lower the rpms and watch the voltage gauge until you get the desired voltage
if the load is going to be constant but is well within the rated capacity( example 2kva of a 6.5 kva set) of the gen set then the variation when the load comes on will be less than 5 volts
however if the power required is close to the max capacity of the gen set ( example 4.5kva of a rated 5 kva set) , then turn the unit on and adjust the rpms up to the required voltage required
remember that an advertised kva is not the rated kva
rated kva is what the gen set will produce all day and is normally around 1kva less than advertised kva
so if you have a 6.5 kva gen set ,it will handle current peaks to 6.5 kva but will burn out if required to run long time at that load
if the gen set is 1000 watts then rated watts will be less ( 750-800) for long time use
Oct 22, 2015 | Electrical Supplies
Coil issue
code p0301 and 302 refer to cylinder I and cylinder 2 misfire detected.--- causes--engine mechanical fault--wiring---ignition/ fuel system--injector--ECT/MAF sensor ---ECM I would have had a fuel pressure test done as miss fires from injectors not getting enough fuel would have been a better starting point
Run the fault codes again to see what else has happened.
May 26, 2013 | Subaru Forester Cars & Trucks
Have Onan 3.6 KY propane gen that will not keep running. Runs only as long as start switch is pushed. Then stops immediately after release. Fault code is 15 (underfrequency) and suggests removing heavy...
I am not familiar with your peice of equipment but from your description of the fault being Under Frequency it appears that generator governor is out of adjustment or the governor spring has brcome weak or broken and not allowing the engine to run at the correct speed to produce an output frequency within the allowable tolerance. Governor linkage could also be binding and not moving smoothly to respond properly to engine load conditions. Thoroughly check governor and throttle linkage for free and smooth operation and full range of movement.
Another cause could be that the engine is not getting sufficient fuel causing the governor to have the throttle wide open to try to get engine to run at its correctly governed speed but unable to do so because the engine is not developing enough horse power.
Jan 10, 2011 | Watts Onan Portable Generator - 4000 ,...
Dodge commins Code Fuel Calibration Error. what is
Hi
The reasons for Fuel Calibration Error are many...
Faulty Fuel pump
Excess anti freeze in the fuel.
Faulty setting of fuel injection system. i.e. wrong mixture being sent to the engine block.
Faulty or damaged Turbo assembly.
You will have to do an diagnostic check to find the real culprit.
Regards
Berry
Feb 01, 2010 | 1999 Dodge Ram
I have two cameras and i need another quick release part that attaches the camera to the tripod. the tripod is the quantaray QSX 9002D.
A couple of palces you can get he plates: Manufcturer is sunpak repriesented by ToCad America-(973)627-9600  OR http://www.tripodquickrelease.com/Sunpak_Quick_Releases.htm
Aug 02, 2009 | Quantaray QSX-DigiPro 8500 Tripod
Jaguar fault codes
it looks like a comminications error make sure you check all computer reated connectors before going to the dealership, i have attache a code list
Aug 04, 2008 | 2002 Jaguar S-Type
Truck wont start
Is it getting fuel?
is it getting spark?
as for the code.........here is the code list for gm vehicles
Code: Meaning:
12
No Distributor pulses
13
Oxygen sensor
14
Coolant Temp sensor circuit
15
21
Throttle Position Sensor
22
23
Manifold Air temperature sensor
24
VSS (Vehicle Speed sensor)
25
32
EGR system
33
MAP sensor or MAF sensor depending on engine
34
35
Idle Air Control Valve
36
MAF Burn-off circuit
41
No Distributor pulses, cylinder select error
42
Electronic Spark Timing or Bypass fault
43
Electronic Spark Control fault
44
Lean exhaust
45
Rich exhaust
46
VATS system fault
51
PROM fault
52
CALPAK fault
53
System over-voltage
54
Fuel pump circuit
55
ECM fault
61
Oxygen sensor fault (degraded sensor)
Jul 17, 2008 | 1990 GMC Sierra
Generac Power Systems Generac iX800 Watt Inverter GeneratorNot for sale in California Logo
42 people viewed this question
Top Generac Power Systems Electronics - Others Experts
Are you a Generac Power Systems Electronics - Other Expert? Answer questions, earn points and help others
