The unit says bye in 3 seconds. - Audio Players & Recorders
  • 52 Answers
There could be a short in the speaker wires. Check the wire at both ends and look to see if any bare wire is touching. It shuts off because there's a thermal protection, so it's heating up for some reason. Bring it in for service
Posted on Sep 03, 2010
My Samsung dvd/vhs player will not stay on. Says hello, then bye a couple seconds later
Sounds like a bad power switch. When you push the power button, it will initiate the unit to turn on, but if the switch does not keep the power on to the unit when you let go of the power switch, then the unit goes into shut down mode. Then the unit will display good bye. I would have the power switch looked at first.
Aug 24, 2016 | Samsung Televison & Video
Tip
Force Eject
If a disc gets stuck in the recorder, there a few steps to try before the problem becomes service-related:
1. Power the unit off (so it shows the clock), then simply press the Open/Close button. The unit should power on and attempt to eject the disc.
2. If the above doesn't work - power it off again, then press and hold the STOP and CH UP button on the recorder itself together and hold them down until the unit powers up. This is called a force eject. If this doesn't work (usually if it's not going to work the recorder will simply come on momentarily then loop back into "bye" and go back to the clock), there is one last method to try.
3. Unplug the unit for 30 seconds. Press and hold the same buttons as above as you plug it in. After it performs the self-check "ooooo" across the screen it should do the force eject. If not, the unit requires service to be repaired and possibly the drive replaced.
on Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
I feel totally stupid asking this but I was recently given an MP3 player GoGear VIBE 4GB and I can't figure how to turn it off. HELP!
The putton on the left of the unit that you used to turn it on with. Hold this down for about 15 seconds and the unit will say "Bye" on the screen and turn off.
Jan 19, 2011 | Video Game Consoles & Games
What error code is f 60? is it repairable?
F60 error is associated with a failure of one of the main circuit boards inside the unit.
Unfortunately it may not be economic to repair unless you could source a failed unit of Ebay and are confident in electronics work.
One thing you should try is a factory reset which although unlikely to resolve the error will do no harm and there is always an offchance that it will help.
To do this;
1) Flip down the front panel to reveal the channel buttons at the front of the unit itself.
2) With the recorder on press and hold the channel up and down buttons at the same time until it says "Bye" on the display.
3) Wait 10 seconds before powering up and try the unit to see if it has helped.
Please do leave a vote for the solution. Thanks.
Aug 19, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmr-e85 locked up. I finally got it to
To setup your IR Blaster (transmitter), hold down the channel up and down button at the same time on you the unit for more than 5 second until the unit says bye and 12:00 flashes, then power on unit and the setup screen will come on your TV.
Sep 15, 2009 | Panasonic DMR-E85H DVD Recorder
Dual xdvd8182
Try doing the following:
1. Find the reset button on the unit and press it down for 10 seconds.
2. Disconnect the battery for at least 30 minutes then reconnect.
These simple options usally work. If not you have a faulty unit and its possible that it has been damaged by condensation from the a/c. Ive seen it a good many times especially in Honda's.
Mar 20, 2009 | Dual XDVD8182 Car DVD Player
GPX ML648B Will not hold charge
The Player gets it's charge from the USB port. I would recommend plugging your Player in and leave your computer on overnight.
If your player still does not retain a charge, I would contact the manufacturer.
Feb 18, 2009 | GPX ML648B MP3 Player
TV does not turn, they turn on the light and stereo stan bye
Let me know exact TV model number and check does standby light blinks? If yes, please count how many time it blinks as there would be pause of 3 seconds in blinks.
Feb 10, 2009 | Sony KP-61HS30 TV
Can't download
it is internet error only download when link disconect your download few second done.
server problem.
Feb 09, 2008 | E-Machines eMachines Desktop PC
Endless loop
Mine did this (on a Ram disk) but I was able to push eject before the dvd tried to read the disk. I had unplugged it overnight, then once plugged back in immediately pushed eject. Once the disk was out it stopped going into recovery mode.
Hope it helps. Good Luck.
Sep 27, 2007 | Panasonic DMR-E80H DVD Recorder
16 people viewed this question
 Grubhead
Grubhead
