Question about Xerox Office Equipment & Supplies
Hi, Iam having xerox docucolore 250 with freeflow xerox server. Iam facing print interface problem " p 03-201" and red X mark in the machine symbol the printing isnot possible. After when i switch of the machine it is working to take one print then same problem, can anybody give solution. thanks
mstr2kx
  • 102 Answers
SOURCE: Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
Posted on Mar 20, 2007
  • 2072 Answers
SOURCE: Print margins too large on Xerox DocuColor 12 - How do I reset?
Not sure this is what your needing but ,,
The Edge Erase default setting is No Erase, which enables the copies to print within 2 mm of each page edge. This is normally sufficient to remove shadows from the edges. If the dark edge is closer than 2 mm, you must set Edge Erase at Variable Erase.
The Variable Erase option enables the copier / printer to vary the amount of erasure from 0 to 50 mm in 1 mm increments. The same amount of erasure is applied to both top and bottom edges or right and left edges of the document.
  1. Select [Edge Erase] on the Added Features tab. The Edge Erase screen is displayed.
  2. Select [Variable Erase]. The Variable Erase screen is displayed.
  3. Under Top & Bottom Edges, use the [Up] arrow to increase the amount of erasure at the top and bottom edges. Use the [Down] arrow to decrease the amount of erasure at the top and bottom edges.
  4. Under Left & Right Edges, use the [Up] arrow to increase the amount of erasure at the left and right edges. Use the [Down] arrow to decrease the amount of erasure at the left and right edges.
  5. Under Original Orientation select the page orientation that most closely resembles the orientation of the document on the Document Glass.
  6. Select [Save]. The Edge Erase screen is displayed.
  7. Select [Save]. The Added Features tab is displayed and shows the new Edge Erase values.
Posted on Feb 13, 2008
  • 2072 Answers
SOURCE: docucolor-12 10-389 CODE
That is a fuser jam indication.
  1. Clear the Paper Jam and Obstructions in the Machine
  2. Make Sure the Paper is the Correct Size, Type, Weight, and Orientation
  3. Make Sure the Paper Supply Setting Matches the Type of Paper Loaded in the Paper Tray
  4. Load the Paper Trays Correctly
  5. Fan the Paper, Turn the Paper Over and Reload the Tray
If the above are all correct, you may just have a small piece of paper stuck on a sensor. Just has to be a small piece of paper directly on one of those. Also see if a sensor flag is dislodged. A sensor may be bad but not likely
Posted on Mar 12, 2008
SOURCE: phaser 7400
i have a phaser 7400 printer when i turn on the printer it say cyan led error turn off printer and turn it back on. It keep on giving me this message what should i do. Another thing is that a gear on the waste cartridge is broken is there a way i could fix it without getting a tech to come look at it. It alway say waste toner is full, ( replace it) which i already did. What should i do?
Posted on Mar 14, 2008
  • 37 Answers
SOURCE: machine keeps printing symbol codes till all paper is empty
It sounds as if you have scanned/faxxed a lot of things from this machine. It is just that you need to clear the memory. Remove all paper so that it is not wasting ink or paper. Turn the unit on and navigate through the menu until you come to pending jobs and clear them and then clear the memory. Hope this helps!
Posted on Mar 16, 2009
Xeroc docu color 250
If you are printing from an Adobe product make sure you are printing as image and let the printer manage the colors. Also, try calibrating and updating the machine through Command Workstation which can be downloaded for free from www.Efi.com. Download the updates by going to the Fiery web interface by typing the ip address of the copier in the web browser and going to the configure tab and clicking on check for updates. Make sure you install them in order and reboot the machine in-between updates. ALSO, you can import the file directly into the fiery by using command workstation avoiding any driver complications.
Jan 15, 2014 | Xerox Office Equipment & Supplies
Xerox DocuColor 4CP printer will not print colour. It will print black fine though. Have defaulted printer and printed colour page, still no colour, just black.
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=DC4CP&Xlang=en_US&Xcntry=USA
According to this site, Windows 7 drivers are available for the Xerox Docucolor 4CP printer.
What operating system are you using?
Also, is it possible that your color toner has been depleted?
Jul 18, 2010 | Xerox Office Equipment & Supplies
Cant print Xerox Docucolor 240 with Creo CX250
its the problem of connecting cable.and other error 212 is for internal circuit board error.you will have to contact xerox service center and get the resetter for this online.or if its board problem you will have to order the parts.
http://www.office.xerox.com/multifunction-printer/color-multifunction/docucolor-240-250/sprt-enus.html
click the link directly and check out your areas service center or the nearest to your area.
thanks.
Please do rate the solution. Thank you for using fixya.keep updated. thanks.
Jul 19, 2009 | Xerox Office Equipment & Supplies
Docucolor 12 no print
if its a print from system to machine do the following
1: check the cables from fiery to machine
2: press clear server in the fiery menu
its not ok
next time mention fiery model
Jan 16, 2009 | Xerox DocuColor 12 Color Copier
Error... the Fiery Server Interface timed out, please, check the Fiery
Sir, I have Document Centre ColorSeries 50 In this machine Scanner is not working, in the Machine Display showing : Error... the Fiery Server Interface timed out, please, check the Fiery. Please help me
Sep 24, 2008 | Xerox DocuColor 12 Color Copier
212 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
