Question about Uniden Cordless Phone
How to re register base unit with handset i accidentally de-registered bse unit form the handset by going to base setting in handset option and okaying it. please help me.
    President:
  • 1,070 Answers
Welcome to Fixya
Dear USer
Place your Extension Phone Near to Main for Few times Until it Beeps.OR it Ask for Registration like Please Register or Something like that.Follow the Steps carefully to Register it...Then Check it for Dial tone to Confirm.Some phones may display that the handset needs to be registered. If this appears-Move the handset near to base/main unit & press the "Prog/Mute". Next, press the "Pager" button on the base unit .Then press the "Prog/Mute" button on the handset again to complete the registration.
Hope you got it....Thanks for Connecting FixYa
Posted on Sep 03, 2010
My V-TECH CS6229-3 phone base does not register the base phone but i can change another phone on this three phone set and it is registered and the phone
Is the handset you are trying to register de-registered? if not it will not register to another base until it is.first de-registered.
To de-register the handset do the following-
With a charged battery in the handset Enter *331734# then without pause Press and Release the Menu Select Button. You will hear a Beep. Handset would then be De-registered..
Then place the handset on the Main Base cradle and follow the instruction that come up on the handset display.if the handset still does not register then most likely the base memory is full and will have to be re-set .
To re-reset the Base:- Remove any handset from the main base cradle. Then Press and Hold the Locator or find HS or handset Locator button until the IN USE light comes on and begin to flash then release it and immediately with out pause press and release it again. That will re-set the base memory. All your handset will then be de-registered and will to be re-registered. Place each handset to be re-registered on the Main Base cradle and follow the instructions on the the handset display and they will register.
Sep 06, 2016 | Lands Phones
How can i register my hanset. it says error.
Please use the below link to assist you with handset registration.
http://service.us.panasonic.com/OPERMANPDF/KXTG5621S.PDF#page=35
May 06, 2014 | Panasonic KX-TGA560 Cordless Expansion...
How do I deregister my handsets on my VTech 2656
To be able to register your replacement handset, you must de-register all the handsets from the VT2656 base unit.
Follow the steps below to de-register your handset(s) from the VT2656 base:
1. Take out the handset that sits on the base.
2. Unplug power from the base.
3. Hold down PAGE while reconnecting power. When the In Use light blinks, release the PAGE key.
4. Hold down PAGE key for 5 seconds. When the In Use light begins to flash, release the PAGE key.
5. The handset charging light will blink 5 times. Within 5 seconds from when it stops blinking, press PAGE once.
You must register the handset(s) by following the steps below:
1. After charging the handset, remove it from the cradle, the LCD display will read "SEARCHING FOR BASE".
2. Press "NEW" and then enter the 15-digit Base ID code, located on the underside of the VT2656 base unit.
3. Press "OK". The handset will display "PLEASE WAIT!!".
4. Wait approximately 15 seconds. The handset will display "FOUND BASE". If the handset displays "BASE BUSY TRY LATER", this indicates that the system is in use. Wait until the base unit is in the idle (on hook) mode and repeat steps 2-4.
Apr 30, 2010 | Vtech Digital Cordless Telephone VT-2568
CIT310 - registration problems with the base
use the pager button, keep it pressed for about 15 seconds, and then use the register option from the phone, handset will pick up the signal. You may have to do this multiple times.
May 27, 2009 | Linksys CIT310 IP Wireless Phone
We had Uniden model TRU8866. Handset #2 was damaged and lost. We purchased a new phone through Uniden. It says Set #4 on it. We would like it to say #2 The new phone is a Power max5.8ghz.
In order to re-register handsets with TRU8866 base unit, you have to reset the base unit, de-register the handsets, and then re-register the handsets. To reset the base station, disconnect the power from the base and then press and hold the CID, Intercom, and Exit keys while you connect the power. Wait for the beep, and let go of the keys. Now re-register the handsets - the first one will become #1, and so on.
May 16, 2009 | Uniden Lands Phones
Can't re-register extra receiver
Try this, Push and hold the "End" key, while still pushing the "End" key push in the "#" key and hold both keys till you hear a beep. The LCD display should now say "De-register Handset" and under that "Base Unavailable" Select Base unavailable. The LCD should now say "Handset not registered, place in base" Just set it in the charging cradle on the base unit and it should register to the base.
Feb 25, 2009 | Uniden DECT 6.0 Cordless Telephone...
Can I use handsets from another DCT 748 unit to expand my DCT 748
Short answer:
No. This model of phone can only support 4 handsets. If you need more than that, you will need to have a second base unit.
Detailed answer:
One of my handsets went bad, and I just bought complete DCT748-4 package from a seller on eBay for a very good price. This set was used, but in very good condition. I didn't need the whole set - just one handset - but like I said, it was a good price. Anyway, I began by telling my old base unit to de-register handset #2 (the failed unit). However, I then found that I could not register the "new" handset with my old base unit because it was already registered to the "new" base unit. So, I first had to apply power to the "new" base unit and de-register the handsets. Then, I placed one of the "new" handsets onto my old base unit, and it said "Handset Registering ..." and registered just fine. Just for the fun of it, I placed one of the other spare handsets into my old base unit. It said "Hanset Registering ..." but then it beeped and said "Registration Failed." This is because I already had 4 handsets registered to my base, and the base can not handle a fifth handset.
Feb 15, 2009 | Uniden DCT-748-4 Telephone
Uniden Cordless Phone Model DSS7855. frequently fails to connect to an incoming call, with 'out of range' indication. The phone is less than 1 meter from the base station.
The handset/base keeps a record of who it’s registered to. The base also keeps a record of how many handsets are registered to it.
Using the de-register function on the handset deletes the handset from the base (decrements the count) and deletes the base info from the handset. All this requires that the base and handset can communicate with each other.
To remove the base data from a handset when out of range of the base, press and hold the ‘end’ button and the ‘#’ button simultaneously until the phone beeps. It will now be de-registered from the base.
However, the base will still have this handset in it’s record.
To de-register all handsets from the base, remove power and the base handset. Press and hold the ‘flash/find hs’ button while applying power. Wait for the beep and release the button. The charge light will now flash. Sit any handset in the cradle. When the flashing stops, all handsets are inhibited from connecting.
However, the handset still appears to be connected to the base unit. Pressing talk will give an ‘Unable to connect’ message. To re-register the handsets to the base, you have to de-register the handset first with the two button method.
Of interest, pressing ‘*’ and ‘#’ on the handset while reconnecting the battery is suppose to reset the handset. Doing the same on the base unit puts you in some sort of diagnostic mode. Press speaker to exit.
Aug 21, 2008 | Lands Phones
TWX977 submersible unable to base register
push menu on base station - select register phone
push # sign on twx977 phone at the same time
phone will register on 9485 base station and unit
Sep 09, 2007 | Uniden TRU9485 Cordless Phone
Uniden Cordless Phone Logo
375 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
