My Gateway Computer Monitor is faded... I mean the color and the letters and number hardly can readable....It looks like if no paint in the printer...so my monitor screen look like that
  • KBalaton May 11, 2008
    Thank You for the advice, finally I am lucky the Store where I have purchased the monitor will replace my monitor .No help....anymore I have tried everything ....She is dead....( My monitor)
My monitor went out. I have a gateway computer. Do I have to buy the same name brand? I not what other brands can I use.<br /> <br /> L.
Posted on Aug 18, 2010
Try adjusting the setting on the monitor, i,e contrast,color. etc etc
Posted on May 11, 2008
I want to refurbish some old license plates.. best way to paint the letters/numbers?
Paint the background color first and let it dry, then smear the background color with vaseline, then spray the numbers and let it dry and wipe the vaseline off.
Dec 19, 2013 | Cars & Trucks
The colors on my monitor are faded!!!! i got a compaq q2009
Check the backlight settings on the monitor, Sometimes they are set too low and it looks like the color is faded. In the monitor settings (on the monitor Itself) play with the color and brightness until you find a setting you like. If you need reset the monitor to factory.
Jun 17, 2011 | Compaq Q2009 Monitor
I have a "dinosaur" type E-Machines monitor,I've
That sounds like a picture tubeproblem and because to the cost of these old monitors it is cheaper just to buy a new flat screen than to try and repair that old one.
Feb 23, 2011 | E-Machines W3400 PC Desktop
Looking for paint color code
Subaru paint codes are located on either strut tower or in the door edge or jamb. Most paint color codes are three digits long and may contain both letters and numbers. For two tone cars: The paint code for a two tone car provides the data for both the upper body paint color and the lower bumper color. The trim code is never the bumper color. For a list of touch up paint colors for your Subaru go here: http://www.automotivetouchup.com/choosecolor/year.aspx?make=Subaru.
Sep 01, 2010 | 1999 Subaru Forester
Paint
Try going the the metal pressed out id plate, its painted the same color as the vehicle so some times its hard to find there will be a boat load of letters and numbers right them down and got your local Finishmaster store and they will be able to find the right 1. If that dosent work they can always use the color eye to code it for u. good luck
Jul 28, 2009 | 1984 Dodge D150
Screen all hazzy letters hard to read
Pull out the graphics card & RAM chips. Give their contact points a good cleaning and replace hem. Also check to see that all cables are snug tight. Finally remove the Monitor cord fro its slot at the back of the CPU and remove all dust and check if any pins are loose. See that the monitor plug is firmly placed..................sodeep
Apr 20, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
FPD2275W LCD Monitor power on blinks the display words- gos black
I don't think you will be able to match that IC without an ID number
Jan 20, 2009 | Gateway FPD2275W LCD Monitor
Computer monitor
u r monitor has colour controll /regulating problem.it has to be serviced.
Jul 29, 2008 | Gateway FPD2275W LCD Monitor
My Gateway Computer Screen is faded ,everythink looks like on the screen ...for example- you print something and no paint in the printer and the colors letters.etc. hardly visible ....so my computer screen...
It sounds like the voltages set in the LCD driver color references are dead. Maybe if you open it up it will have a loose voltage divider or bad LCD clock/voltage distribution boss circuit. It can of course be that the transistors on the panel are themselves destroyed, but check the below first:
Set the resolution to the monitor's native resolution (1680x1050), and change the panel's brightness and contrast to try and improve things. If it's not glare, make sure the temperature is okay for operating the monitor and perhaps check the video source (another video card or such.) Did the monitor always have this problem?
May 11, 2008 | Computers & Internet
Some letters on monitor are fading out
Some letters on monitor are fading out if there is no problem with card then it is due to monitor high voltage section failure. 1 there should be proper output from power supply. 2 focus control on flyback to be set. 3 crt base loose 4 or focus wire going to crt base not properly connected due to some foreign material deposited on it. 5 at last if monitor is old there is a possibility of crt getting weak.
Sep 24, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
David Payne
David Payne
