Question about Chicony TwinkleCam DC2110 Webcam
I don't have a CD drive how can i connect it to my computer?
    President:
  • 2,571 Answers
Download the drivers from the support website.
I could only see a model dc 3110 not the dc2110, but the driver should work ok for you
http://www.chicony.com.tw/download/kb/top1.asp
Posted on Sep 03, 2010
Music management rca th1100
The Music Management CD that comes with your player contains all of the necessary software components you need to make your player work properly.
These components enable you to transfer files from your computer to your player.
Inserting the included CD into CD drive:
Turn on your computer and place the Music Management CD that came with your player into your computer.
Important: Don\'t connect the USB cable to the PC or the player before or during the CD installation.
If the setup screen does not appear, double-click My Computer, double click your CD drive icon, and double click Install to run the installer.
Dec 28, 2013 | RCA Th1100a Usb Audio Player -white
I don't have the CD for the FinePix Viewer. Is this software available to download
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what said first, you can use any photo cataloging program such as Picasa.
Jul 16, 2012 | Fuji FinePix Cameras
My computer says I don't have drivers for my camera after running the CD.
You don't need to use a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Mar 24, 2012 | Fuji FinePix A340 Digital Camera
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Whenever i insert a readable cd into my dvd drive,system restarts....what should i do?
this would be the first thing to check
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Mar 04, 2011 | Sony Computers & Internet
Cd/w/ dvd/r 522c is not reading nor writing just blank screen !
is it your computer screen that is black
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 22, 2011 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
HP Pavilion zd7000 will not power on at all I have the right adapter and all the computer does is flash the keyboard lights every few seconds
make sure all leads that are attached to your dvd\cd drives have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Feb 18, 2011 | HP Pavilion zd7000 zx5000 zv5000 presario...
I don"t have a cd - rom
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Dec 27, 2010 | Canon PowerShot A460 Digital Camera
I need to install my printer to my computer but i don can
Try this. Before connecting the printer put the printer driver cd in the drive and install the drivers. If not asked to connect the printer, then restart the computer with the CD in the drive Connect the printer. Printer will be detected.
Dec 17, 2008 | Office Equipment & Supplies
Chicony TwinkleCam DC2110 Webcam Logo
54 people viewed this question
Top Chicony Computers & Internet Experts
Nicholas Bannister
Ricky Ostrom
Ricky Ostrom
micky dee
Are you a Chicony Computer and Internet Expert? Answer questions, earn points and help others
