Question about Nokia N72 Cellular Phone
When i receive a text message my nokia E72 doesnt ring, what could be the problem?
  • Nokia Master
  • 4,737 Answers
Does the phone ring when you receive an incoming call? If so, press Menu go to Control Panel (or might be the profile is shown in the menu) after control panel, Profile then Options and then Personalize, then, scroll down and again select Message Alert Tone, set the Tone for the message. Also make sure that the volume is turned up. Save the settings and try again. If this doesn't help and you don't hear any ring tone during an incoming call, let me know after checking the sound settings.
Good luck.
Thanks for using FixYa.
Posted on Sep 03, 2010
Cannot receive messages on nokia e72
Can you make calls? If so then it is probably an issue of the dedicated memory for messages being all filled up, try deleting a couple and see what happens. If you cannot make calls it is probably because you lack enough signal strength to receive the messages.
Mar 29, 2012 | Nokia E72 Smartphone
Nokia E72 dropped in water. Phone works to make and receive calls, and text messages can be read, but some of the keys do the wrong thing, so I cannot lock the phone or write text messages / emails. Can...
There may still be water in the phone. Take out the battery, put it in a ziplock bag of rice, and leave it over night. the rice should absorb all the water from the phone.
Please remember to rate my solution to show your appreciation.
Amardeep
For more tips visit my blog at http://thegeektweet.wordpress.com
May 28, 2011 | Nokia E72 Smartphone
I recently updated the firmware on my Nokia E72. Now, when I receive a text message, it no longer shows who sent it on the standby screen. Just shows a notification saying "1 new message" or...
Hello Sir
i guess we cannot solve this issue becasue its in the default settings of firmware. if you dnt like it much and want it back as you liked so my advise to you is just go to settings and restore the default factory settings
May 06, 2011 | Nokia E72 Smartphone
I'm using nokia n8, i'm unable to send text messages..checked the sim with other phone, its working fine...i've checked the phone with other sim as well...problem persist...i've tried restoring the phone...
1st Check that the SMS message center # is correct.Turn your n8 off overnight if that doesnt work, copy your WAP services settings to the Internet destination.Settings> Connetivity> Settings> Destinations>Wap services>Copy
Feb 21, 2011 | Nokia E72 Smartphone
Just got a nokia e72. Why can't I send texts?
Message Problems
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding the text messages,
the problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone and try sending a message from another mobile to you number,
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
You can check the message center number, but I don't think
it's very much important in your case, well, if you wanna try,
just check the text message settings and verify that the message
center number (which is currently in use) is the same number which
is on another phone with the same network (the other Sim should be
of the same network in your area). If it's different, make the changes
and save the settings. Also disable the "Receive Via" or similar settings..
(I can't recollect the exact settings as i don't have the same model with
me, please excuse me for this.).
If the same Sim card doesn't receive text messages using another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
Feb 14, 2011 | Nokia E72 Smartphone
I can't send text messages on my nokia e72 phone....help!
i think you should check your message centre no.
Aug 30, 2010 | Nokia E72 Smartphone
Have a nokia e72 smart phone can receive text but cannot send text
for sending text messages :
1. call to your network operator customer care
2. request the message center number...
3.note it down
4. go to message settings>message center number
5. insert the number which is noted by you and save it
this solves your messaging problem ...
Good luck
Aug 17, 2010 | Nokia N72 Cellular Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Nokia N72 Cellular Phone Logo
384 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
