Question about Protron PDV-700
Mikenj i have around 200 pc brand new protron pdv700 dvd portable but they only turn the power light but it doesnt start please let me know what i can do regards mayer
  • ticos May 11, 2008
    Just wanted to make sure that you understood me correctly, I received 300 DVD portables, and only 200 had this problem. I am wondering if you believe it is the inside regulator that is damaged, or if it is the outside power supply that may be the problem.
    Do you think that i need to change the regulator completely, or is their another way i can make them function.
    Hoping for your response ASAP.
    Thank you, Mayer
Marian
Posted on May 11, 2008
    Brigadier General:
  • 6,966 Answers
Did I get you right, 200 pcs of brand new Protron PDV700 DVD Portable Player?
In any case, chances are the problem is the switching 5V regulator which supplies the logic circuitry or any part of the circuitry of the power supply.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role May 11, 2008
    Hi again,
    Copy that 200 out of 300 are non-functional.
    Since they are of the same brand/model, pls select one of the working ones. After verifying that indeed it is working, set the player aside. For purposes of discussion let us call that working unit #1. Use the external power supply of #1 to test the questionable 200. If any of the 200 would work using #1's external PSU, then it is the player's external PSU at fault, if not then it is the player.
    If any unit (of the 200) has been determined to be at fault, then it would have to be opened up and diagnosis made. It is of course required that one need to be comfortable and familiar working with electronic circuitry and components, use of a VD and a low wattage soldering iron (or preferably a Combo hot air station and soldering iron for surface mounted components). Availability of a service manual or at the very least a schematic diagram with voltage readings is also essential. In the absence of the service manual/schematic diagram, it is possible to use one of the good player as a template when doing actual voltage readings.
    Should you be uncomfortable going through the above method, perhaps your best would be to seek the professional services of a qualified technician.
    Cheers.
Battery does not hold charge. Where can I find a
I suggest to purchase another brand , PROTRON no longer on the market , it belongs now to SPECTRONIQ,and their customer service is very bad, they will tell you that the BATTERY replacement is out of stock at the moment but its on order , Ive been like this trying to get a replacement for my PROTRON for about 3 years !! AJ
Dec 01, 2009 | Protron PDV-288 7" LCD Portable DVD Player
Looking for a car power adapter
Radio Shack carries the Protron PDV-288 AC charger. Please visit a local radio shack.
May 31, 2009 | Protron PDV-288 7" LCD Portable DVD Player
No user manual for Protron PDV-288 portable DVD player
nahh you cant over chargee silly;; when its done, its done, it just doesnt loose battery power. and im not positive about the light.. but i would most likely assume that when the green light is on, that means its charging.. thats how pretty much every electronic works.. light on-charging; light off-no charge. sometimes it varies by different color lights.
thanks ! hope i was helpful.
Feb 10, 2009 | Protron PDV-288 7" LCD Portable DVD Player
Charge indicator light on Protron PDV-288 portable DVD player
now maybe you could help me. i have the same portable dvd player and i have the plug in that goes into the actual player.. and you know how its that weird looking end that has the light that lights up.. well what is that supposed to plug into? because i dont have anything that it can plug into and im not sure if i am missing a piece..
The middle piece in a protron portable dvd is missing
If you talking about the clamper (the peice on top of the door) Yes its a common replacement part used on many brands and
should be inexpensive to replace. You can call 909-354-4120 and order one.
Dec 31, 2007 | Protron 7" Portable DVD Player
POWER PROBLEM
This is a common problem, makes sure the switch in front of the DVD door and off to the right is not stuck down, it tells the Screen you have opened the clamshell and must be up when opened.
Nov 10, 2007 | Protron PDV-228 Portable DVD Player
Doesnt work
Unfortunately, Protron LCD's are very low quality, mine went out in 15months. Your problem may be similar to one I had & I fixed it by cycling the on/off switch next to where the power cord goes in the back of the TV. Also make sure the power cord is inserted right since the "yellow" light indicate powering up but not full power. Hope this fixes it since I couldn't find ANYONE that services/repairs PROTRON brand.
Nov 12, 2006 | Protron PLTV-26 26 in. HD-Ready LCD...
Protron PDV-700 Logo
75 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
