Question about Sharp AQUOS Blu-ray Disc Player
Model Sharp LC-40LB700X AQUOS LCD color TV with Blue Ray wont play avitar. Can you advise
  • 53 Answers
SOURCE: sharp aquos LC-37D4ou
What kind of connections are you using?
If component (red, green, blue) double check to make sure they are seated properly. I'm thinking it sounds like the blue one got loose.
Posted on Mar 27, 2008
  • 10 Answers
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Posted on Jan 08, 2009
ginko
  • 19396 Answers
SOURCE: LC-37AF3X Sharp Aquos KCD TV
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
rulds2008
  • 3866 Answers
SOURCE: Two red vertical lines down 32" Sharp Aquos LC-32P50E LCD TV
There are solutions for stuck "and not dead pixels" Here are a couple idea's to try and please do not rate me bad if don't work!! That would not be nice as i do not get compensated showing your solutions I get them by your "good ratings" Hence do not use "Thanks for Trying" rather helpful or fixya will do now here are the websites:
http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
http://www.jscreenfix.com/basic.php
If you TV can hook up to a computer witch it can through servral means then you can use this information. But However do not rate me Thanks for trying if the darn thing just dont unstick the pixels... Thank You for using Fixya.com
"were we can save you hundreds of dollars on repairs" It has been my pleasure assisting you today. Rulds2008- Expert Top 10 Fixya.com
Posted on May 15, 2009
  • 73 Answers
SOURCE: Problem connecting my PS3 to my Sharp Aquos LC-C3237U LCD TV
Your PS3 set itself above the max resolution your LC-C3237U. Most likely the PS3 is doing 1080P, but the highest the Sharp can do is 1080i. So do this:
1. Connect PS3 to TV (you can use the current cable or analog cable)
2. Turn on TV and set input to port PS3 is on.
3. Make sure PS3 is connected via correct cable.
4. Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Posted on Sep 27, 2009
Sharp Blue Ray and Sharp Aquos TV were working just fine, now blue ray not recognized by tv; screen stays dark but the blue ray appears to be operating. Have tested the blue ray independently and worked...
A refurbished set? If blue ray is not built into set the issue is with the set--maybe the reason set was refurbished.....If have not tried it unplug set for a while and reconnect with set turned off.
May 01, 2012 | Sharp Aquos Quattron LC-46LE810UN 46-inch...
Sharp aquos tv lost blue tones
Examine the set with the color OFF and if No blue (odd problem) check hookup----component uses red, green and blue cables and if blue cable is bad and signal is from component on a box---box could be bad.
Easy way to know---hook DVD etc to a rear inputs= still no blue?
Mar 25, 2012 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Sharp Aquos Blu Ray player cannot play my blue ray disc.
goto sharpusa.com and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
Apr 24, 2010 | Sharp AQUOS Blu-ray Disc Player
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Can not get my new 42 " Aquos TV to work with my new blue ray DVD
A blu ray player will play on any television. The television might not however have the highest resolution to display the full capability of a blue ray. That being said, the blu ray player may be faulty the connections may be incorrect. I would recommend running an HDMI cable from the A/V out on the blu ray to the HDMI input on the TV. GOod Luck
Dec 23, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Component connection does not support progressive scan DVD
No can do the set cant deal with that signal. turn off prgressive scan on the DVD the signal is still a preaty good one. Only blue ray or HD DVD will get the real HD.
Jul 10, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Sharp aquos LC-37D4ou
Mar 27, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Vertical line
Sorry, you have a defective LCD panel. If your TV is still under warranty, contact Sharp to get the TV exchanged. Otherwise, LCD panels cost more than the TV is worth.
Mar 25, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Color looks horrible when playing dvds. when watching tv, the color is fine. help!
U have to use a hdmi cable ok or red green blue coumpount cable ok that way get a better picture thx for using fix ya .
Feb 05, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp AQUOS Blu-ray Disc Player Logo
257 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
