Power supply problem with Phillips 46pp8621/79
Hi guys,
I am looking for a solution or circuit diagrams for my Phillips 46pp8621/79 TV.
I currently believe there isn't any HV power coming out of the power supply or there is a short on the driver board bringing the power supply down. I haven't done much testing as yet as it is hard without knowing exactly what voltages I am looking for and where.
Would anybody have the diagrams available to download??
Thanks in advance.
  • greglamont May 12, 2008
    Thanks for the info. I actually found the Service Manual. I have tested the Power Supply and it seems ok. Possibly the HV Module?? Are the any suggestion on how this is tested - aside from carefully?? I this a common fault??
    There is a constant clicking and like a high pitched alarm sound coming from the unit, but I can't yet identify which component.
    Thanks again in advance.
    Greg
    Australia
  • 8,617 Answers
Your chassis is the DPTV 325 you can get the factory training manual for your set emailed to you at the following link. It cost 12.99 but comes with unlimited tech support if you need it. The manual is listed as DTV300 series training manual its has the trouble shooting proceedures and diagrams that you would need. heres the link.
http://servicemanuals.vstore.ca/
Posted on May 11, 2008
  • Sonny Berry
    Sonny Berry May 12, 2008
    Usually that symptom is related to the HV generator (flyback) being faulty
Power goes out on Phillips 55 in tv. Model 50pf9631d/37. I am suspecting power board
That would be my guess, could also be a safety circuit detecting out of range parameters. But most likely a bad capacitor on the power supply board/module.
Jul 16, 2017 | Televison & Video
How do i find the value of a burnt component on a circuit board from a samsung tv?
JAMES THERE SHOULD BE A SITE ON THE INTERNET WHERE YOU COULD CALL SANSUNG CUSTOMER SUPPORT TAKE A LOOK!
Jan 24, 2016 | Samsung Televison & Video
TV picture went out. stand by/timer light blinks when I turn on the TV. no other response from TV.
The timer light blinks representing the fault on the tv. If the tv blinks in an orderly fashion then the number of blinks before pausing is used to indicate the fault. This can only be determined by looking at the service manual for that set. If the blinking is continuous without pauses after a number of blinks, then it indicates there is a problem and the first place to look would be in the power supply. Either the power supply isnt supplying power to the Line output transformer i.e an open circuit or short circuit..OR the line output circuit has a short. Without a diagram i cannot guide you which components to check..but..swollen topped capacitors in the power supply are a give away :)
Aug 02, 2009 | Sony Televison & Video
TV won't come on - get a blinking red light instead
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you the flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jul 01, 2009 | Philips 50PFP5332D 50 in. Plasma...
Hey i have a phillips 50inch plasma tv and recent the bottom half of the tv goes black... what wuld u think the problem is??
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
If the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
Jun 28, 2009 | Philips Televison & Video
Circuit diagram Samsung LE23R88BDX - LCD TV
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
Feb 24, 2009 | Samsung Televison & Video
Looking for diagram of CWT-9200C PC Power supply
Hi guys
Thanks for your willingness.
I have found a cct diagram of a similar atx power supply which solves my problem.
Be Blessed
Andre
Feb 18, 2009 | Generic Memory 250 W POWER SUPPLY...
Phillips 55pl9524/37
Hi
this amber color means defective power oscillations Circuit! need to diagnose at the regulated power supply. and or at the HOT area.,
Thanks!
Dec 27, 2008 | Philips 55PL9524 55" Rear Projection...
Noisy Phillips 32p w9308 tv
HI Brad,
I wonder if the coil was on the cord for the power or in the tv circuit board. I would definally suggest you replace the part with the correct part as I'm certain the engineer that designed the set wouldn't have designed it with a coil if it wasn't needed. I do have lots of used parts from junk sets if I knew what yours was exactally, I would be happy to send you one for the price of the freight. Let me know if I can help.
Ed
NC Electronic
PO Box 1696
Mills, Wyo, 82644
307-266-4675
Jan 05, 2008 | Philips 32PT6441/37 32" TV
TV wont turn on
your problem is in power supply
there is a switching circuit in power supply
some capacitor or transistor might be faulty there
also check for loose contact in power supply
it is a simple problem for skilled tech.
good luck
Oct 14, 2007 | Televison & Video
Televison & Video Logo
194 people viewed this question
Top Televison & Video Experts
