Question about HP Compaq Presario 2500 HP Pavilion ZE 5000 NX9010 Series (chassis bottom)319470-001 (319470001) CD-ROM Drive
My nx9010 is coming out of standby. you have to restart the machine by first switching off the main. How best can i have it it come out of standby
    President:
  • 2,571 Answers
After replacing power supply and resetting tv still only have green flashing light
Remove Mains Plug and press Standby switch from LED Panel for 30 sec. Press Input & Ch Down Switch from LED panel and plug in and start LED LED will start and "K" will appear on screen Press Ch Down & Vol Down switch at same time You will get 1/10 page on screen Go to 9/10 page by pressing left & right button from remote Select EEP and press Ok button from remote After 30Sec remove main plug and restart LED.
Dec 13, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Hitachi 42" Colour TV 42HXT12U No V14415112 Purchased March 2014
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 11, 2014 | Televison & Video
How to dismantle hp nx9010
No problem, rigidarmz!
HP Support > HP Compaq Business NX9010 Notebook PC > Main Support page,
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=321850&lang=en&cc=us
Go down to the subheading -
Resources for HP Compaq nx9010 Notebook PC
Click on Manuals under this subheading.
Scroll down to the black bold subheading -
Service and maintenance information
Click on the file name -
Service Manual
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name, it may take up to 30 seconds, before the first page comes up.
(10 seconds just now using a medium speed DSL connection)
May I ask; anything I can help with?
Post in a Comment.
Regards,
joecoolvette
Oct 14, 2012 | HP Compaq Business Notebook NX9010
We are having xerox 1038 model usa made . we are getting the error u6 when we switch on our machine . so plz suggest us the best possible way to fix up the problem ...`````
U6-1 The main PWB failed checking the ROM.
Shut down and restart the copier. If it appears again U6-1, replace the main PWB.
U6-2 The main PWB failed checking the RAM.
Shut down and restart the copier. If it appears again U6-2, replace the main PWB.
U6-3 and U6-4 The main PWB failed to check the battery MNV (U6-3). Or the main PWB does not properly initialize the NVM (U6-4).
Follow the procedure in the development of memory to initialize the NVM, code 20-96. Shut down and restart the copier.
Jul 20, 2011 | Office Equipment & Supplies
MY RICOH AFFICIO 1027 JAMMED AND SHOW SC542
SC542 A Fusing temperature warm-up error The fusing temperature does not reach the standby temperature within 20 seconds after the main switch is turned on. • Fusing thermistor defective or out of position • Fusing lamp open • Fusing thermostat open • Power supply board defective • Poor connection of the fusing unit
Apr 16, 2010 | Office Equipment & Supplies
Nx9010 notebook coming up with disk read error dont have recovery disc this is my granson's computer
it`s very possible to be a hard drive error, the main thing what you can do is to try to install the operating system over the old one if that goes ok it means that you had a premature shutdown and the files where corrupted if the problem persist it`s a hardware problem.. solution is to buy another harddrive
Mar 13, 2010 | HP Compaq nx9010
Compaq nx9010 startup buttom doesn't work
1>>Shut down the computer and restart the computer and while restarting computer keep tapping on F10.
You by this go to BIOS screen , press F9 here and then F10 to save the defaults and to exit out of BIOS
2>>In the Control Panel click on Power Options and here click on Choose what the power button does and set the option accordingly
Jan 25, 2010 | HP Compaq nx9010
Screen on compaq nx9010 is darkly,barely visable, machine works otherwise. Restart and no problem (yet?) Is this the ballest going out? Is this circuit part of the motherboard or on a separate circuit...
1) Is of all we will go to BIOS screen and check if we get the same screen.if that the case then we need to take the laptop for repair
2) we will go and install the upgraded graphic driver
3) we can try doing system restore
4) we will go and do recovery
Dec 13, 2009 | HP Compaq nx9010
TV will not come on via the remote control and remains in standby
Try switching it off at the main switch on the TV. Then switch it back on from the same main switch on the TV. If the TV then comes on & works normally, then check the batteries in your remote control, they may need replacing.
Mar 28, 2009 | Samsung LE32A41B 32 in. HD-Ready LCD...
Compaq nx9010 powers down to stanby.
select control panel off computer menu then select performance and maintence icon then select power options then you will see power options properties options tabs.. set properties to suit your needs
this should solve your problem
Jan 12, 2008 | HP Compaq Business Notebook NX9010
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
