Question about eMachines W3611 PC Desktop
Upgraded memory in W3611. Won't start. Gives three long beeps instead. Restored old memory. Won't start. Gives three long beeps instead.
  • 44 Answers
Remove RAM(S), clean the ram slot by blowing air, fix RAM(s) back in position untill both the side clamps are properly locked.
If problem persists try resetting motherboard via jumper pins on the motherboard.
Posted on Sep 03, 2010
When i turned on my emachines w3611 there was three beeps and then the monitor shut off. what do i look at first in order to repair it ?
The problem is in the graphics card. If the monitor connects to the onboard video circuits, them you'll need to replace the motherboard.
Jan 01, 2016 | eMachines Computers & Internet
Emachine w3611 power button blinks but won't start computer
Try unplugging from power source and leaving for about three minutes and then plug it back in.
May 12, 2015 | eMachines W3611 PC Desktop
Monitor says no signal when turned on
Check the memory cards are inserted correctly (remove and reseat)
Dec 27, 2013 | eMachines W3611 PC Desktop
I have Intel Desktop D845GLLY motherboard, recently it has no display and when power is on it gives three beep. I have a intel board that was running find until i upgraded memory and changed the dvd...
The three beeps tells you that something inside the system is not properly installed. Check all hardware installations and position properly all hardware not properly installed. If nothing is improperly installed, try cleaning the RAM with a piece of clean cloth and install properly.
Feb 20, 2011 | Intel Computers & Internet
My w3611 emachine froze and will not boot up. I get three beeps if I try. I am thinking it might be the processor, onboard graphics, or the bios.
Well if it's 3 short beeps then its a RAM failure. If its 1 long and two short then it;s a video monitor issue. 3 long beeps is a keyboard or keyboard card error.
Sep 01, 2010 | Computers & Internet
Wen i upgraded memory on hp 708 pc all i get now
possible cause of this issue is that the memory module you purchase is not compatible with the motherboard. e.g if you old memory is 1Gig DDR2 667mhz you should purchase a 667mhz memory also if you will still be using the old memory. you cannot use memory with different speed.
Mar 27, 2010 | HP (387539-001) Motherboard
After powering up the server it gives three long beeps and no vga is displayed,removed the memory and inserted new memory.
remove the new ram and start the pc if the beeps still then it must be the new ram incompatable with the bus speed
Dec 01, 2009 | Intel Server Board SE7501WV2 Motherboard
Hi..my hp pavillion dv 2000 last year made same problem. we changed mainboard, after 6 mounths mean todat gives same beeps and same problem black screen and one long two short beeps and system not start...
Did you upgraded your BIOS after you have changed the MB?
Did you install memory ? if yes check if it was compatible.Check Beep codes from net search.
You may use two similar but different memory for a short time but end of it, you will get this beeps. Check it by removing one memory each time and try the laptop, Make sure in process time, remove the battery and plug off power, otherwise you will demage the MB.
IF NOT you need to obtain (Or if you have ) OEM CD or order from HP to reload programs,
Mean time I also suggest, Remove the hardisk and with a niddle try to bring springs on from Hardisk Caddy connector. Do Not know how to do it? See techy.
Goodluck
JMC
Aug 12, 2009 | HP Pavilion dv6000z Notebook
Beginning dump of physical memory
Try removing that newly added memory and see if it solves the problem. Might be faulty or incompatible.
Jun 28, 2009 | Compaq Computers & Internet
Computer beeps three times and will not start
Clear CMOS/ Remove battery for 10 minutes, reinstall battery & wait for another 10 minutes before turn on. Three Beeps means RAM is defective/ not detected.
Jun 27, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
eMachines W3611 PC Desktop Logo
192 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
