Question about HP Compaq 6715b Notebook
Laptop will not turn on battery light flashes orange 8 times then stops?
Hello! Have you solved this problem? I am having exactly the same problem and I'm trying to find the solution, so any help would be appreciated.
Posted on Oct 13, 2010
Battery light flashes green 5 times then changes to orange.
What is the make and model of your laptop? What operating system is being used?
Dec 05, 2017 | Dell Latitude D610 Notebook
Battery light flashes green 5 times, then changes to orange.
The flashing green indicator is telling you (and the notebook) that the battery is almost fully charged, but then by switching immediately to flashing orange, the status has changed to "battery charge is low". This is not normal behaviour and probably indicates a serious issue with the battery. My guess is that the charging is initiating some kind of rapid battery self-discharge.
Ref - Knowledge Base
Notebooks will power up and work without a battery just fine.
Ref - Laptop Battery Basics dummies
Try to operate yours this way. This will eliminate the battery from the loop as a potential cause of the BSODs you are seeing.
Jan 09, 2018 | Dell Latitude D610 Notebook
Orange light flashing, no chargine
A replacement battery must be the EXACT same power spec as the original in DC volts and Milliamps, or you could damage the Mobo components. Some aftermarket batteries do not work well. The connections may be different.
Jan 31, 2013 | Dell Latitude E5500 Laptop
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
Won't Start Up
try this link it might help you get start again. laptop Won Start Up Google Search
Oct 19, 2017 | Toshiba Tecra TE-2100 Notebook
My wife has a toshiba satellite L35-S2151 laptop. When she went to turn it on, the orange battery light flashes 8 times and nothing else happens. Any clue as to what is going on?
Try turning on the device with the power connected if it turns on, keep the power plugged in for the entire day. See if you will have the same problem without the power supply. If it still occurs without the power supply, you may have a bad battery, you can verify if you can get swap battery from a similar laptop.
Oct 01, 2009 | Toshiba Satellite L35-S2366 Notebook
Battery light flashes 4times orange then 1green
We had the same problem. I figured out it was NOT the main battery, but the auxilary battery. The batter life WITH the auxiliary was 68% total, when I removed the 2nd battery the battery life shot back up to 98% AND the flashing orange / red lights were gone (both on the power source and off). I then replaced the auxiliary battery with a spar back up to make SURE that it was not a fluke and with the new backup battery firmly in place the lights still did not flash. Problem solved.
Jun 17, 2009 | Dell Inspiron 6000 Notebook
Battery Light Flashes Orange and Green
I have had three different laptops, last one an XPS from DELL which did the same thing. Replacing the battery solved all three laptops. How old is the battery you have in there now?
Jun 02, 2009 | Dell Inspiron 6000 Notebook
Battery light is flashing orange on d510 computer
i have a d800 that does the same thing. battery is no good
Apr 21, 2009 | Dell Latitude D600 Notebook
HP Compaq 6715b Notebook Logo
997 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
