Question about Lexmark X652DE MONO LASER MFP All-In-One Printer
Hi, Assist with the location of a media (input) sensor P/N: 40X4368. I need to replace this part on a Lexmark X652de Multifunctional printer
I have a problem with the sensor that is under the toner where it passes the paper
Posted on Dec 03, 2010
How to resolve constant jam error 241 on Lexmark x652de MFC printer?
Double check to make sure roller shaft isn't 'locked' in both directions or spinning in both directions. If the shaft moved to the right a bit, it might be spinning in both directions. If it is, Grab the pick arm in one hand and push the roller shaft a little to the left. The shaft should spin in one direction but not the other. I am a Lexmark tech and have had this happen quite a bit on the 64X and 65X models.
Mar 07, 2017 | Lexmark X652de Multifunction Laser Duplex...
I have a Lexmark T652N that says it has a jam, but I cannot find it. It comes up with error 200.13 Paper Jam - check cartridge
200.13 - Input sensor jam.
The flag sensor that is located before the transfer roll and next to the end of the alignment rollers. Make sure the flag is still there. It can be easily broken. If it is there, make sure it moves forward and springs back into place. If it is missing or doesn't move properly, it needs replaced.
Input Sensor - 40X8673
Jan 27, 2015 | Lexmark T652N Mono Laser Printer
How to reset fuser kit on X656de
  • 01: Lift the paper bail, and then remove the fuser wiper cover
  • 02: Remove the top rear door
  • 03: Open the fuser cover
  • 04: Remove the fuser
  • 05: Remove the new fuser from the packaging
  • 06: Insert the fuser
  • 07: Close the fuser cover
  • 08: Attach the top rear door
  • 09: Lift the paper bail, and then insert the fuser wiper cover
Or watch this video
Lexmark Product Videos
click on Service Maintenance
then click on Replacing the fuser
Manual X651de X652de X654de X656de X656dte X658d X658de X658dme X658dfe...
May 11, 2014 | Lexmark X656de AllInOne Laser Printer
What a cartridge sensor is
This is a sensor in the unit that tell the processor that the cartridge is in place. Look into area where the cartridge goes and make sure it is not too dirty. If it is you can try just blowing the dust or toner out of the section. I suggest canned air. Also make sure that cartridge is completely seated in place. Hope this helps
Mar 03, 2014 | Lexmark "x652de multifunction monochrome...
200.13 paper jam check cartridge
The unit has either an electronic sensor or actual switch to detect paper path. If there is more paper dust than usual, visually check for any thing that me impede the paper. If you are using recycled paper they seem to create more dust due to the clay in the paper. If you have canned air blow out as much dust as possible or if you have computer vacuum, vacuum the interior. If there is a flag type sensor in paper path be careful not to knock off spring. Hope this offers some help.
Sir my printer problem is on printer menu write a clearing paper path what is this massage and give me solution.
Thank you contacting FixYa for your printer inquiry.
This error is associated with either a sheet of paper blocking the paper path or a partial piece of paper that blocks path or trips a sensor. The printer will usually throw up a error code 13.XX on the display and the XX is a number that will indicate where in the paper path this error most probably occurred. Just follow the steps for your error on the below chart.
This link will take you to the user guide which will be helpfull identifying components and providing guidelines for most of the helpful hints and things you will need to know about this printer.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00218691/c00218691.pdf
Locate your error on the matrix below and follow the steps. Comment back if you need more help. Thank you again for contacting FixYa.
TF
HP Laserjet Error Codes 0 - 19 Message on printer Display Panel What it means. What to do. 13.XX PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation. 3.0 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation. 13.1 PAPER JAM OPEN INPUT TRAYS Paper-delay jam at paperfeed area. 1. Ensure that paper trays are loaded and adjusted properly so media can feed from the tray. It might be necessary to reduce the stack height of media in the tray. 2. Check the input area for obstructions such as media in the path. Also check to see if the registration assembly damaged or unseated. 3. Replace any defective sensors or flags. 4. Verify the media meets the specifications. 5. Check the pickup feed and separation rollers for unusual wear. Replace as needed. 6. Rotate the media in the input tray by 180° and/or turn it over On NX engines this is most likely the fuser flag or the ACPM. The ACPM has a photosensor hard-wired to the back of it. 13.10 PAPER JAM CHECK DUPLEXER Jam at duplexer. 1. Check the duplexer and the rear area of the printer for obstructions or damage. 2. Check the duplexer for proper operation. Replace the duplexer if a sensor is defective. On a 5si, 8000, or 8100 series laserjet a Duplex Jam can be caused by a tray 2 and 3 feed assembly failure. 13.14 For Laserjet 5si. This error is caused by a defective paper control PCA Replace paper control PCA. 13.2 PAPER JAM OPEN INPUT TRAYS Paper-stopped jam at paper-feed area. 1. Check the input area for obstructions such as paper in the path. Also check to see if the registration assembly is damaged or if the transfer roller is out of place. 2. Replace any defective sensors or flags. 3. Ensure the media does not exceed the maximum length. 4. If multiple sheets are feeding, it might be necessary to fan the media and reduce the stack height. Also, replace separation pad. 5. Verify that the fuser is properly installed. On NX engines this is an input jam. 13.20 PAPER JAM CHECK REAR DOOR Media stopped in the paper path during power on or when the top door was closed. 1. Remove all media in the paper path, and then open and close the top cover. 2. If the message persists after all media is removed: Check if media is jammed in the prefeed area. Replace any defective sensors or flags 13.21 DOOR OPEN JAM The top cover was open while printing. 1. Clear the jam and close the top door. 2. If the message persists, check the top door switch for proper operation. 13.5 PAPER JAM CHECK REAR DOOR Paper-delay jam at fuser. 1. Check the transfer roller and small media belt to ensure they are operating and can feed print media. 2. Check the paper path for obstructions at the transfer roller, toner cartridge, paper feed assembly, and fuser. 3. Replace any defective sensors or flags. 4. Turn the media stack over and/ or rotate it by 180° in the input tray. If still persists - replace fuser, then DC controller. 13.6 PAPER JAM CHECK REAR DOOR Paper-stopped jam at fuser. 1. Check the paper path for obstructions at the fuser and output/delivery area. 3. Replace any defective sensors or flags. 13.99 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation
Jun 09, 2011 | HP LaserJet 4350 Printer
Lost my installation disk how can I get it installed on my pc now
Check the link below and download the required drivers.
http://www.nodevice.com/driver/company/Lexmark/Multifunctional.html
Sep 19, 2010 | Lexmark X2350 All-In-One InkJet Printer
Wrong Media loaded error - tranceparencies
hi!!! in that kind of problem maybe the paper sensor was defective and it can't detect the kind of paper you loaded to your printer.
Apr 18, 2009 | Lexmark C534N Printer
Lexmark c510 printer will not print at all. Don't have disk. Have downloaded driver from lexmark website - still no joy!
hi
i found same problem but i got the solution from iYogi Technicians. For more help you can visit this URL
http://www.iyogi.net/multifunctional-printer-repair.html
Regards
Sep 14, 2008 | Computers & Internet
Lexmark X652DE MONO LASER MFP All-In-One Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
