Question about Siemens HF87960GB 800 Watts Microwave Oven
AN ERROR SHOWS UP ON DISPLAY eR4 - Siemens HF87960GB 800 Watts Microwave Oven
2 Suggested Answers
SOURCE: sienens microwave HFT879 fault
Exactly the same problem over here, but after our house was hit by lightning, so not really surprised about the cause of the problem. If you look closely, you can still see the displays on a very low light level. I can still choose a microwave program, turn the time etc, and see the time changing, but start won't just just work.
m.de.man att zonnet.nl
Posted on May 05, 2010
Microwave keeps shutting off after a few seconds and error number H97 shows up on display pad. What does this error mean?
Error code H97 is an indication of a possible failure of the Magnetron, DPC board or the High Voltage Inverter board. It could be just a loose wire connection also between the DPC board and the High Voltage Inverter board.
This failure will require a service technician to diagnose and repair.
Jan 24, 2015 | Panasonic Microwave Ovens
Display shows "=SE-", and do nothing
"SE" means = sensor error, try to dry it out with a hair dryer, if not working, you have to replace the sensor
Jul 29, 2012 | Samsung SMH9151 Microwave Oven
I have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the...
Dear Sir i have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the problem How Can Solved this Problem This prestige induction cook top model PIC 3.0 Only one week so please do need full
thx... Kundan singh Rana Baddi (H.P.) 09857455945 ranansd@gmail.com
Mar 23, 2011 | Microwave Ovens
My Samsung SMH7178STD just started showing error code E-13
Hi, please click on this LINK then select 'Display Panel', then 'Microwave Is Displaying An Error Code' for instructions on what to do in the event of an error code, such as 'E-13'
Oct 31, 2010 | Samsung SMH7178STD Microwave Oven
Microwave model UMC5200BAB display is locked. After power reset per instructions display shows error code -SE- or -5E-. Somtimes pressing Stop for few seconds bring the clock back and it work fine for a...
"SE" error means you have a shorted membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs
Oct 08, 2010 | Microwave Ovens
Error flashing on display KHHS179LSS
If you pull off the top louver (it just pulls straight off) usually (mine does) there is a small technician manual (is a small black plastic bag) on the right side above the control panel. It shows all the error codes and what they mean. It shows how to enter test mode and exit which may clear the error. Hope this helps.
Jan 01, 2010 | KitchenAid KHHS179LSS Convection /...
Sienens microwave HFT879 fault
Jan 11, 2009 | Siemens HF87950GB Convection Microwave...
HME9750 error Er4
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
Aug 12, 2008 | Bosch HME9760 Microwave Oven
F3 Error Message
It needs a new key pad it is shorted the ge website has a list of error codes f3 is the keypad
Jan 31, 2008 | GE Advantium 120 Convection/Microwave Oven
Siemens HF87950GB /03
If the display is dim and another problem is denoted on the dim display, the problem may be the power supply which may be in common with both items. The power may have surged to a high level before going out which could have damaged the power supply. The only way to know is to probe the power supply with a voltmeter. If the board doesn't show the power levels, usually +5V or +/- 12 V DC, read the values on the electrolytic capacitors on the board. Usually 16 V caps are used on 12 or 5 volt supplies, 32 V caps on 24 V supplies, etc. Be very careful or leave this to a profesional
Nov 24, 2007 | Siemens HF87950GB Convection Microwave...
Siemens HF87960GB 800 Watts Microwave Oven Logo
53 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Steve
Gerry Harvey
Gerry Harvey
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
