Question about Panasonic KX-FL501 Plain Paper Laser Fax
Toner cartridge The toner cartridge will not snap down on the right side which is causing the cover to not close.
    Genius:
  • 2,120 Answers
Look for a piece of the old cartridge down in the cavity.
Posted on Oct 14, 2008
Corona wire problem
Hi, you can clean the corona wire easy, just follow those steps:
1) Turn of printer power and unplug all cord including phone cord.
2) Make sure the scanner is closed, then lift open the top cover by its handle.
3) Remove both the drum unit and toner cartridge assembly for the color desired to be replaced.
4) With the drum unit removed, push down the GREEN lock lever to remove the toner cartridge.
5) Slide the GREEN tab left to right several times to clean the unit's primary corona wire.
6) Before installing new toner cartridge, shake it from side to side to distribute toner.
7) Remove protective cover from cartridge.
8) Insert cartridge into drum unit until it snaps in place.
9) Ensure that you are inserting the correct color toner cartridge into its proper place and then slide the drum unit into the printer.
10) Close the top of the machine and then reconnect all cords; turn on power to ensure proper installation.
May 16, 2012 | Brother MFC-9320CW Color Laser Printer -...
I cant get the toner cartridges in my canon c ir 2050 to go back into the copier
Try these steps.
  • Pull out of the front cover of the Canon 2200 so that it flips down and exposes the inside of the machine.
  • Remove any toner cartridge already in the machine by pressing down on the blue lever located near the bottom right of the inside of the machine. Then grasp the toner box right above the handle and slide it out until it stops.
  • Hold the new toner cartridge in both hands and shake it from side to side a few times to loosen up the toner.
  • Orient the toner cartridge so that the flat surface is facing downward and the small handle at the end of the surface is pointing toward you.
  • Place the toner cartridge on top of the toner box. Push it back in as far as it will go and then press down on the cartridge until you feel it click into place.
  • Pull back on the small handle on the top of the cartridge. A thin separator sheet between the cartridge and the toner box will come out. Continue to pull until you see a stop sign on the separator sheet.
  • Tap on the toner cartridge to cause the toner to vacate the cartridge and fall into the toner box. After you have tapped it a few times, push the cartridge handle back in. When the handle goes all the way back in, you will feel the cartridge unlock from the toner box.
  • Remove the empty toner cartridge and push the toner box back into the machine. Pull up on the blue lever once the box is all the way in. Close the front cover to the Canon 2200.
Hope this helps.
Jun 29, 2011 | Canon for IMAGERUNNER C2020 C2050 C2058...
Don't see the printer cartridge on Dell 1110 printer
To replace the toner cartridge: 1. Open the front cover. 2. Pull the used toner cartridge out and lift it up and away from the printer. 3. Unpack a new toner cartridge. Hold the cartridge carefully and thoroughly shake it from side-to-side 5 or 6 times to distribute the toner. 4. Pull the tape to remove the protective paper. 5. Locate the cartridge slot inside the printer, one on each side. 6. Unfold the toner cartridge handle and grasp it. Insert the cartridge into the printer until it snaps into place. 7. Close the front cover. Make sure that the cover is securely closed. If it is not firmly closed, printing errors may occur.
Hope this helps! Best of luck!
Jun 21, 2011 | Dell 1110 Laser Printer
I have a similar black line (about 2inches in width, on the right side) on faxes sent from my Brother 4100e. I cleaned the scanner glass as suggested by you, but it continues to have the same problem on...
Either your machine's
primary corona wire for printing may be dirty, or the sending party's fax scanner may be dirty. Clean
your primary corona wire. I recommend placing the drum unit on a drop cloth or large disposable paper
to avoid spilling and scattering toner.
1. Clean the primary corona wire inside the drum unit by gently sliding the tab from right to left several times.
2. Return the tab and snap it into the Home position, (Caution: If the tab is not at the Home position, printed pages may have vertical stripes).
3. Reinstall the drum unit into the machine.
4. Close the front cover.
5. Plug in the power cord first, and then plug in the telephone cord.
or ask the sender to make a copy to see if the problem is with the sending machine.
Try receiving from another fax machine.
If the problem continues, call Brother Customer
Service at: 1-800-284-4329 (in USA) or 1-877-BROTHER (in Canada)
OR
You can also try these steps below
2 Reset the drum counter if you have already changed the drum recently. Open the device's front cover and press the button labeled "Clear," then close the cover and press the "1" button on the device's control panel.
3 Pull down on the top of the device's front cover. Slide the print cartridge assembly out of the inside of the printer and place it on a scratch piece of paper.
4 Depress the lever on the right side of the assembly and separate the toner cartridge from the drum assembly. Remove the new drum unit from its aluminum bag and snap the toner cartridge into it.
5 Place the print cartridge assembly back into the device and keep the front cover open. Press the "Clear" button, then press "1." Close the front cover once the device's screen reads "Accepted."
Regards,
Ron
Mar 09, 2011 | Brother IntelliFAX 4100e All-In-One Laser...
How to insert a cartridge in canon printer 4320d ?..
Hold the front side of the operation panel with your hands.
Lift the scanning platform (A) until it is locked. (You will hear an audible "click.")
Hold the grip (A) on the right front side of the toner cover.
Take out the new toner cartridge from the protective bag.
Do not open the drum protective shutter (A).
Save the protective bag. You may need it later when you remove the toner cartridge from the machine.
Gently rock the toner cartridge several times to evenly distribute toner inside.
Place the toner cartridge on a flat surface and pull the seal completely out.
If toner is adhered on the removed seal, be careful that your hands or clothes do not get dirty from touching the toner.
Do not pull the seal out at an angle.
Hold the toner cartridge by its handle (A).
  • Do not open the drum protective shutter on the toner cartridge. Print quality may deteriorate if the drum surface is exposed to light or is damaged.
Always hold the toner cartridge by its handle
Insert the toner cartridge so that the protrusion (A) on the right side of the toner cartridge fits into the guide (B) located on the right side of the machine and slide it down parallel to the guide.
Push the toner cartridge to make sure it is properly set in the machine.
Close the toner cover.
Lower the scanning platform.
If you cannot close the toner cover, do not force it to close. Open the cover and make sure the toner cartridge is properly set in the machine.
Be careful not to get your fingers caught.
Dec 04, 2010 | Canon Office Equipment & Supplies
How do i change the toner on this copy machine?
Canon iR3300 copier /image runner is a best machine which is not needed any expert mechanic. Thanks to the manufacturer.If the toner in the cartridge was completed a message may be displayed on the screen that 'refill the toner'. Even though there will be a small quantuty of toner in the cartridge the message may be appear on the screen. Please don't bother about this mesaage. You may think the machine be damaged some where else. You might have handling the 'motor bike' or 'scooter' and you may experienced about the resrve . i.e. even though there is some petrol in the petrol tank of vehicle , the vihicle may stops to work. After filling of the petrol the vehile may run as usual. So , after the reserve of toner in the cop[ier the machine will stops to work. The you have to refill the toner cartridge with the fine quality toner of 1/2 kg or with 1kg. The cost of the toner may be Rs.500/- to Rs.650/- depending on the quality and the company and availability of the toner in the market. The toner must be compatible with the iR 3300 copier. After purchasing of the toner you must shufle the toner bag up and down nearly (100) times , so that the toner in the bag may thouroghly mixed and see that there will not be hard particles. Then remove the front cover gently and turn the side levers 1). left lever to left side and 2). right lever to down side. Then gently drag the toner cartridge of only 3/4 size. Please don't try to remove the toner cartridge completly out side of the machine. The costliest cartridge and not avialability of the new cartridge in the market may be break.At the front and top of the cartridge , there will be small lever attached to the cover of cartridge . Just hold the front ant and top of the cartridge with middle fingers and thumb fingers either side of the cartridge by both the hands and just press the levers out side towards you with the fore fingers of both the hands.. Then drag the cover only 3/4 of cover out side towards yourself. Make a small hole at the corner of the toner bag and pour the toner gently in to the cartridge. while pouring the toner in to the cartridge gently move the cartridge inside and out side , so that the toner may evenly spread in the cartridge. After pouring of hole toner , close the cover the cartridge by pressing the edge of the cover from out side and then press the cartridge in to the machine and there after turn the levers in to the original position and close the front cover.
Sep 24, 2010 | Canon (6981A002AA) for imagerunner 2200,...
HOW DO I FIX THE ERROR 004-332...???
1. Reseat and clean the 4 toner cartridges and verify the orange plastic covers have been removed.
2. Reseat the toner cartridge carousel position. By doing the following:
Lift the handle of the first available toner cartridge or toner cartridge attempting to be installed and remove the toner cartridge.
Close the front cover. Power off the printer. Power on the printer.
An LCD message Insert <toner color> Toner appears. Open the front cover. To reinstall the toner cartridge, align the arrows on the cartridge with the corresponding arrows on the printer, guide the cartridge in until it snaps into place, and then push down the right lever to lock the cartridge in place. Close the front cover. The toner cartridge carousel rotates to the correct toner position.
3. Verify the developer rotor frame is not bent. If it is bent then the printer should be replaced, it would not be cost effective to replace the frame.
4. If it is not bent. Open the front door, try to rotate the carosel. It should NOT rotate. If the rotation is rigid and feels broken, then the printer should be replaced. If it rotates smoothly, the developer latch should be replaced. If the carosel does not rotate but still gives the error the rotor control board should be replaced.
Jul 16, 2010 | Dell 3010cn Laser Printer
Get code 004 332 restart printer. have removed the four toner cartridges and replaced the drum cartridge and the same code appears
Hello,reseat and clean the four toner cartridges, verify the orange plastic covers have been removed, and verify the cartridges are fully locked into place, .This is the procedure:
1. Press the Menu button and press the down arrow until Replace Toner appears, and then press the "ENTER" button.
2. Press the down arrow to choose the appropriate color toner cartridge and press the "ENTER" button.
Note:If the Menu button is inaccessible, begin replacing the toner cartridges with step number 3.
3. Open the front cover.
4. Lift the handle of the appropriate colored toner cartridge and remove the toner cartridge.
5. Gently rock the toner cartridge from side to side.
Note:Rock the toner cartridge over newspaper as there may be some toner leakage.
6. Gently wipe the exterior of the toner cartridge with a dry cloth.
7. Verify the mag roller has been removed.
Note:Grasp the orange strap, peel the tape away from you, and then, with the tape free, pull the blue strap toward you.
8. To reinstall the toner cartridge, align the arrows on the cartridge with the corresponding arrows on the printer, guide the cartridge in until it snaps into place, and then push down the right lever to lock the cartridge in place.
Note:Ensure each cartridge lever is fully pressed down into the locked postion.
9. Close the front cover.
10. Repeat steps 1 through 8 until all toner cartridges have been reseated.
Good luck
Feb 05, 2010 | Dell 3100cn Laser Printer
Unable to remove black cartridge, it is really stuck. Help
I just changed my black toner this past week, and finally figured out why the cartridges get stuck like this.
First, you must eject the toner cartridge on the front-panel menu:
Menu->Replace Toner->Eject Toner->Black(K)
It will say "Rotating to Black Toner(K)" and then say "Black Toner(K) Ready to Eject"
Now, open the front panel and you'll see the black toner cartridge in front. You can also open the top panel if you want more light on your work area.
Lift the lock handle on the old toner cartridge to the "unlock" position, and here's the part that the Dell instructions don't have:
There are two channels for the toner cartridges -- one on each side. Run your finger down the channel on the right, and you'll feel a small, spring-loaded catch. This catch often gets sticky and won't release the cartridge without some help. Don't force it, but gently move it towards the back of the printer and it should release.
Now the old cartrdige should slide right out, and you can finish per the instructions that came with the new cartridge.
Jan 27, 2010 | Dell 3100cn Laser Printer
How to remove drum unit from kyocera fs 1920
Installing the Toner and Drum Cartridges
bullet.gif Installing the Toner Cartridge
bullet.gif Installing the Drum Cartridge
caution.gif CAUTION: Before performing any of the following procedures, read and follow the safety instructions in your Owner's Manual. Installing the Toner Cartridge Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier will not rotate).
  1. After confirming the Insert Yellow Toner (Y)message, open the front door.
  1. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
note.gif NOTE: You need to remove the protective cover only the first time that you install the toner. note.gif NOTE: Dispose of the protective cover after you remove it. note.gif NOTE: The protective cover is attached to each toner cartridge mount. mag_cover_5.gif
  1. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
  1. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
  1. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
  1. Close the front door.
note.gif NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly. close_front_cover.gif
  1. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
  2. Repeat steps 1 through 7 when inserting the remaining cartridges.
  1. When the Insert Drum or Insert Drum Cart message appears, open the front door, then lift and push back the top cover.
  1. Remove the protective sheet from the drum cartridge.
  1. To insert the drum cartridge, push up the lever on the right side of the printer. With the lever in the upright position, hold the drum cartridge by the handle, align the arrows on the drum cartridge with the corresponding arrows on the printer and guide the cartridge in until it snaps into place.
  1. Pull down the lever on the right to lock the drum cartridge in place.
  1. Close the top cover, then the front door.
note.gif NOTE: After installing the drum cartridge, the printer makes an adjustment for about one to two minutes. Do not turn off the printer during this time.
Aug 04, 2008 | Office Equipment & Supplies
Panasonic KX-FL501 Plain Paper Laser Fax Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
