Question about Sony Handycam DCR-TRV18 Mini DV Digital Camcorder
No sound when using Sony Camcorder
When recording using a Sony DCR TRV18E I'm not geetting any sound when using in playback mode or when downloading to my PC and playing back on my PC. It doesn't seem to be recording the sound!
I've gone through the instruction manual trouble shoot section for no sound (page 176) and none of these suggestions work.
This camcorder is 4 years old and I've never had this problem before.
  • 10 more comments
  • a1sba May 11, 2008
    I didn't know that you could mute the sound when recording? There does not seem to be a mute selection in the menue settings.
    Camcorder audio setting are set to HiFi and audio mix is in the middle.
    I get video but no sound
    Volume is at maximum
    Yes. It is set at HiFi Stereo
    LCD video screen is open.I've trid a new tape and probelm still exists. Would it matter if I've got the "16 bit" message on the LCD screen?
    This model only has Stereo, "1", and "2" settings in the VCR Set/HiFi sound menue. I tried both the Stereo and "1" settings.
    Just tried the tape cleaner - still doesn't work
    Just changed setting back to 12 bit. It didn't change anything - still no sound. Unfortunately I don't have an external microphone
    Just bought an external mic and tried it. Still no sund on recording
  • a1sba May 13, 2008
    Very interesting. I've just played a tape I know had sound recorded on it back through the camcorder (VCR mode)and no sound was playing.I also ran the cleaning tape through the camcorder for about 2 minutes and it still didn't work. With my layman's knowledge, it sounds as though the audio head is faulty?
    I've played an old tape through the VCR and it didn't produce sound. I've also tried an external microphone. Both of these suggestions didn't work.
I had the same problem. There is no sound when playing minidv tapes and also when recording. I searched the i'net for answers, tried them but all failed. I decided to investigate the audio connections located at the front of the camcorder below the lens. I removed 3 screws on the plastic cover. I checked the pcb, jacks and connectors. Then I noticed a loose connector (plastic brown color) which is link to another pcb inside. Reconnected, tested and problem solved. Try it and let me know if you have any questions. Hope this helps.
Posted on Jan 11, 2009
  • 1,512 Answers
Hi, I know this is not a direct fix, but if all else fails, before taking it to a sony service center, you could log the problem with the Sony support system. They have many FAQ listings about your camcorder. You can find it here
Good luck
regards
robotek
Posted on May 11, 2008
  • Graeme Ross
    Graeme Ross May 12, 2008
    I just logged the problem to Sony... wait see I guess :)
    robotek
  • 2,296 Answers
Try a previous tape that you know the audio works and see if you get audio. If you do It means the audio head is working; if you do not get audio you might have a defective audio head.
If the audio is not recorded, the microphone could be defective.
    Scholar:
  • 46 Answers
Set the audio to the normal mode i.e stereo made any check with the other settings too i.e not only with hifi mode with other normal modes too if the sound is getting recorded in that then your cam is perfectly allright if the sound is not recorded in even the normal mode then there may be some problems in hadycam if the playback is working with sound in hadycam but not in pc means you dnt have right software for it try installing vlc media player it plays all types of vedios you can download it here http://209.85.175.104/search?q=cache:Ie8HbsJplEYJ:vlc-media-player.uptodown.com/en/+vlc+madia+player&hl=en&ct=clnk&cd=3&gl=in
hope so your problem solves by this if still not solved ask me again
    Brigadier General:
  • 6,966 Answers
with the indulgence of the others...
It may be that the internal audio capture (mic) is at fault. Can you try doing a recording with an external microphone attached to the camera? You can even try those mics intended for PCs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • 2 more comments
  • Louie  Role
    Louie Role May 11, 2008
    Alternately, you can try recording from another device such as a DVD using appropriate cables/connectors. If there is sound recording this way then it is the mic. If not then it is something internal to the camera.
    It could just be also the audio head.
  • Louie  Role
    Have you tried head cleaning?
  • Louie  Role
    If external mic is a no go, pls try using external source such as a DVD. If still a no go then it is internal to the unit and no amount of setting and configuration would correct that since it is a hardware fault. Your best then would be to seek the services of a qualified service professional such as those in a Sony service center. Sorry but that's the last try a user can perform without opening the unit.
  • Louie  Role
    Additionally have you tried Jaime867's post of playing an old tape that you have recorded before and known to have sound?
  • 135 Answers
Check your sound settings. Make sure that the vcr set and the player set HIFI sound settings are set to stereo. Also make sure audio mix is set in the middle.
  • 3 more comments
  • Michael Thibodeau May 11, 2008
    Ya there dosent seem to be a mute. I read the manual. Im sure you made sure the volume is turned up. The only other thing I see is that audio mix setting that could be causing that.
    volume is up?
    Audio setting should be HIFI "stereo" If it is set to 2 it will have no sound.
    The only other thing I see is that the lcd has to be open for the sound to work. Other than that sounds like there could be a problem with it. Also make sure you are using the correct tapes. Or maybe you have a bad tape. Try another one.
    In your menu there is a setting for 16 bit or 12 bit sound. Try changing that. Its under tape set in the menu.
    President:
  • 1,944 Answers
Did you check that you didn't mute the sound when recording?
Where do you find instuctions for sony handycam dcr-trv18e
Please click here to download the Manual of the Camcorder. Please let me know if you require further assistance.
Thanks for using Fixya..
Feb 01, 2012 | Sony Handycam DCR-TRV18E Mini DV Digital...
How to save and download the video and picture in the pc
So, what did you use firewire or USB? If you want to use SUB you will have to install proper driver, by the way, I wouldn't even try USB, quality is horrible. Best way to capture video is firewire (IEEE1394). You will not need to install any drivers for firewire connection if your PC equipped with firewire card.
Dec 01, 2009 | Sony Handycam DCR-TRV18E Mini DV Digital...
Sony digital video camera mode no. DCR-HC14E not showing pictures/recording
If your Sony DCR-HC14E shows fine picture in playback of old tapes and does not give live view in camera mode to record then its CDD Imager problem that Sony will repair free of cost.
Click Sony CCD Imager Support for details.
Jun 10, 2009 | Sony Handycam DCR-HC14E Mini DV Digital...
Editing software for Sony DCR-TRV18e
Download Pinnacle12 or Adobe Premiere Pro
www.mininova.com
Feb 21, 2009 | Sony Handycam DCR-TRV18E Mini DV Digital...
Sony trv18e a few things don't work
Night shot light is "Infra Red" and you can not see it directly though camera will shoot in darkness if you slide ON Night-Shot switch.
Regarding playback volume problem, I think built-in speaker is defective ( open ) and needs to be replaced.
Let me know if you want some more info.
Feb 16, 2009 | Sony Handycam DCR-TRV18E Mini DV Digital...
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Firstly you need the remote control that came with your camera (RMT-814).
Switch on your camera to VCR mode. Then on the remote, press the Data Code button (and of course, point the remote towards your camera). This should display the date and time in the bottom left of the screen.
It should display the appropriate date and time for each bit of recorded video.
Hope this helps!
Ron.
Jul 06, 2008 | Sony Handycam DCR-TRV18E Mini DV Digital...
Sony Handycam DCR-TRV18E recording to PC stopped by sleep mode!
Hi , my old DCR-TRV18E ,don't go to sleep mode while capturing video to my laptop through usb? It goes to sleep mode after 4 minutes when it stays in idle mode...I am using windows XP and Ulead VideoStudio 9.But usb don't capture good movies.Better to use 1394 port. Its not much of help ,but anyway ..
Goodluck , M
Dec 27, 2007 | Sony Handycam DCR-TRV18E Mini DV Digital...
No Audio only video is visible.
Replacing the speaker part number 152959011 2,0 cm should solve the problem. If you need more info please advice. Arpi
Mar 15, 2007 | Sony Handycam DCR-TRV18E Mini DV Digital...
Sony Handycam DCR-TRV18 Mini DV Digital Camcorder Logo
193 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
sonic boom...
sonic boom...
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
