Question about Blueant Supertooth Light Bluetooth Speaker Car Kit
SUDDENLY THS MORNING THE BLUE LIGHT ON AND THE RED LIGHT OFF ARE FLASHING ALTERNATELY IE WHEN AERIAL LOCATED TO ON POSITION THE ON LIGHT BLUE FLASHES ALTERNATE RED AND BLUE AND BLUE TOOTH NOT WORKING
    President:
  • 1,118 Answers
I think your car kit has lost its pairing data. Blue and red lights flashing alternately means it is in pairing mode. On your phone (or the device it was paired with), delete the partnership with your car kit, and make it search for new devices again. After a little while, your car kit should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey, or passcode) is requested, enter '0000' (four zeros).
By the way, detailed instructions on how to pair it with your phone (illustrated with pictures) can be found on its user guide; In case yours happens to be missing, you'll still be able to find it here.
Hope you are able to sort your problems out soon.
Please, let me know if I can help you any further.
Regards, Carlos
Posted on Nov 12, 2010
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
Jul 20, 2014 | 1995 Lincoln Town Car
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
Need the speakers stereo schematic
1997 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Hope helps.
Jan 25, 2011 | 1997 Ford Explorer AWD
I bought a 1996 Subaru Impreza L 4dr 5speed AWD that runs and starts fine but when I was installing fog lights i noticed that there appears to be an alarm hooked up (it says "code alarm elite DM...
Battery Constant 12v+ Positive Wire (+): Black/Yellow
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Blue/Red
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Red
Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Red/Yellow
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Red
Parking Light Positive Wire Location: Low In Drivers Kick Panel
Power Door Lock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Lock Negative Wire Location: To Drivers Door Only
Power Door Unlock Negative Wire (-): Add Actuator. This vehicle uses a central door locking system. When connecting a keyless entry, you will need to add a door lock actuator and some units will also require (2) extra relays.
Power Door Unlock Negative Wire Location: To Drivers Door Only
Door Trigger Negative Wire (-): Red/White
Door Trigger Negative Wire Location: In Black Plug, Above Hood Release
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Red/Green
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black/Blue
Tachometer Wire Negative Wire Location: At ECM, Under Drivers Side Dash
Brake Light Positive Wire (+): White/Black
Brake Light Positive Wire Location: At Switch Above Brake Pedal
CODE ALARM SYSTEM
Used on:
Impreza 1996-2001
Legacy 1995-1999
Forester 1998-2000
codealarmremote2.jpgBattery GP-23A
Lock: Left button will lock all doors. Double chirp indicates locked.
Unlock: Right button will unlock driver's door only. Hold unlock button app 6 seconds, it will unlock all doors including rear gate. Single chirp indicated unlock.
If the car chirps or lights flash 4x the alarm was triggered.
Panic. Press both buttons to activate emergency honk and flashing lights.
Valet mode: With optional alarm onlyPress the red alarm button on the left of the steering wheel. The light will quickly double flash. To re-set back to normal mode, press the red alarm light button again
Battery failed and lights flashing?
Parking lights will flash when the vehicle's battery is disconnected and reconnected.
To stop lights from flashing, either:
Press remote transmitter "UNLOCK" button once OR turn the ignition switch to the "ON" position and press programming button for one second (see below).
The vehicle interior (courtesy) light and door open warning light (DOOR AJAR indicator) will then illuminate for 60 seconds when the ignition is turned off, or until the doors are locked with the remote transmitter. Yes, the dashboard instrument panel lights will flash when the parking lights flash.
Programming or Overriding the Alarm when you have lost the remote
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button.
Press lock (left) button the remotes to be programmed. The door locks will cycle one time. Exit programming mode by releasing Programming button under dashboard and turning key to off.
codealarmremote1.jpgCode Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring (see diagram).
This button must be pressed while programming remotes or if the battery was disconnected and the lights are flashing.
Jan 05, 2011 | Subaru Impreza Cars & Trucks
Is Blue tooth headset Plantronics Explorer 210 compatible with k790i. I got this headset recently, but am unable to pair with my Sony Ericson k790i mobile. Please help?
Your headset must be in paring mode, in order to be paired with your phone. If, after turning it on, the indicator light doesn't alternately flash in red and blue (thus indicating it is in pairing mode), it has, most probably, been paired to another phone before. In this case, turn it off, wait for the indicator light to turn red, and, then, off. Then, turn your headset on again, and hold the call button until the indicator light is flashing alternately in red and blue. Either way, make your phone's bluetooth application search for new devices. After a while, your headset should appear on-screen. Make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process has been successful, your headset will enter the stand-by mode.
Hope it works for you.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Sep 10, 2010 | Plantronics Explorer 220 Bluetooth Headset...
How do you put blue parrott B250--XP in discovery mode.
From the power off position, switch the unit on by holding the function button for 3 seconds. Keep holding the function button until the indicator light on the function button flashes red and blue in an alternating pattern. The unit should now be in discovery mode and ready to pair with another device..
Aug 03, 2010 | VXI Corporation Blueparrott B250-XT...
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
What color is the power wire in 1994 toyota pick up
this might help
1994 Toyota Pickup Car Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): White And White/Red
Starter Positive Wire (+): Black
Ignition Positive Wire (+): Black/Yellow
Second Ignition Positive Wire (+): Black/Yellow Or Black/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue/Red
Parking Light Negative Wire (-): Red/Black
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/White
Power Door Lock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Power Door Unlock Negative Wire (-): Blue/Yellow
Power Door Unlock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Door Trigger Negative Wire (-): Black/White Or Black
Door Trigger Negative Wire Location: At 2-Pin Plug, Top Of Fusebox
Horn Negative Wire (-): Green/Red
Tachometer Wire Negative Wire Location: At Diagnostic Connector. The diagnostic connector, is located on the passenger inner fender near the fuse/relay box.
Brake Light Positive Wire (+): Green/White
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Nov 29, 2009 | 1994 Toyota Pickup
I need color codes
Constant 12V+ Black/Yellow
Switched 12V+ Red/White
Ground Black/Light Blue
Illumination Orange
Dimmer Pink
Antenna Trigger Orange/Red
Antenna Right Rear
Front Speakers 4" Doors
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
Feb 19, 2009 | 1996 Dodge Intrepid
87 dodge ram charger 318 alternator installation.
Case groung= BLACK
Battery Positive = RED
Field wires = one green, one blue
They have been this way since 1970
Nov 17, 2008 | 1987 Dodge Ramcharger
Blueant Supertooth Light Bluetooth Speaker Car Kit Logo
234 people viewed this question
Top Blueant Radio Communications Experts
Michael Vincent Cruz
aliasger yq
Paul Chapman
Paul Chapman
Are you a Blueant Radio Communication Expert? Answer questions, earn points and help others
