Question about Refrigerators
Fridge / freezer not cold - power on
Fridge light is on therefore power running, thermostat does not appear to be working and cabinet a dn freezer compartmetn are not cold
  • 2 more comments
  • Anonymous Jun 28, 2008
    refrigerator light is on, motor is running, however frig is not cooling
  • cierra07899 Aug 07, 2008
    my freeze is working, keeping everything frozen but the fridge is not cold... i have no idea what to do or even how to go about fixing this problem
  • charlie_babb Sep 06, 2008
    Freezer seems to be working but fridge is not cold... dial turned all the way up and still nothing. All my food has spoiled. Unit making a constant ticking noise and I hear the hum of the motor. Freezer fan never goes on anymore since this started.
  • Anonymous Nov 22, 2008
    Freezer not working
Thermostat problem
Posted on Nov 06, 2008
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
I recently scored a bargain Fisher Paykel stand-in fridge/freezer because my original fridge developed a fault. sadly the stand-in Fisher Paykel N405T has an issue of its own, the freezer doesn't really...
Yes ur correct. the fan can be accessed by removing the back panel wall from ur freezer dept. sometimes u will have to remove the bottom panel first a couple screws are all it takes
Mar 31, 2015 | Fisher Refrigerators
How do I repair the fridge thermostat?
Is there a flap that allows cold air from the freezer section to enter the fridge, or is it a separate system altogether.
In what way is the thermostat "broken"?
Jun 11, 2014 | Midea 3.1 Cubic Feet Black Double Door...
Maytag fridge (model MBB2256GES) freezer cold but fridge warm
Sounds like one or more of ofvyour 3 defrost components have failed which are defrost heater , defrost thermostat, and defrost timer or board
Nov 06, 2017 | Maytag MBB2256GES Bottom Freezer...
Fridge not cold compressor running fine sides are warm to the touch, enough ventilation bottom freezer and top fridge setting at maximum cold both freezer and fridge fan are working with an external 12V...
There are three reasons for your fridge problem. 1. Malfunction of defrosting. 2.Gas chocked.3.Thermostat setting.
1. The freezer can be set to atemperature between.
Thanks, helpful?
-14°F and 8°F.
Feb 08, 2011 | Fisher and Paykel E522BLE Bottom Freezer...
My Maytag msd2756geb freezer is too cold.
You are probably right that it is always running. This is because the thermostat/sensor has gone bad. The fridge adjusts by a door that allows air to come from the freezer to the fridge side. Therefore this will still work...
You will need to replace or have the thermostat replaced....
Heatman101
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
Feb 04, 2010 | Maytag Freezers
MZD2766 fridge light works but the fridge does not
The only thing you need to do is let us test the auto vent. Yes you may need to take it out but it has a thermostat built into it. Drop the pig tail in cold icy water and warm the thermostat pigtail. If door does not open or shut replace it.Tell me your freezers temp?
Sea Breeze
Jan 17, 2010 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Mar 08, 2009 | Maytag MZD2766GES Side by Side...
Belling B160 Fridge is warm Freezer is cold
In fridge freezer where the fridge is under the freezer, the cold air falls down a channel from the freezer. I had a similar problem and it was a failed defrost thermostat. The evaporator in the back of the freezer was a solid lump of ice and wasn't allowing any cold air to drop into the fridge. The defrost thermostat was changed and then 30 minutes with a heat gun melted the ice. It was worked fine ever since. On a side by side fridge, there is a bypass from the freezer to the fridge. Either way, you need an engineer. You are not the only one to see this problem with that model. I see two in Google.
http://www.ukwhitegoods.co.uk/forumsphpbb3/belling-b160-fridge-freezer-t48629.html
Sep 19, 2017 | Refrigerators
Refrigerators Logo
187 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
