Question about HP Photosmart 2710 All-In-One InkJet Printer
Whats the ip address for hp photosmart C7280 - HP Photosmart 2710 All-In-One InkJet Printer
  • HP Master
  • 32,281 Answers
According to the HP specification for this model printer, it only has a USB connection, therefore it has no IP address.
If you want to setup this printer as a network printer, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Posted on Sep 03, 2010
How to scan, what icon to click
Visit to the given link and download the manual or user guide. The complete procedure for scanning is mentioned therein...
http://www.retrevo.com/support/HP-C7280-Multifunction-Printers-manual/id/3837dj879/t/2/
http://www.generalmanual.com/Printers/HP-Photosmart-C7280-All-in-One-Printer.htm
Hope this has helped you... Please rate the answer... Thanks...
Jul 08, 2010 | HP Photosmart C7280 Printer
My C7280 is printing at an angle
You could try the recommendations from HP support for your model: (recommend cleaning feed rollers)
HP Photosmart C7280 Prints Crooked
Jan 07, 2010 | HP Photosmart C7280 Printer
Hello i just want to know ip address for dell 2350 exp like an 192.168.1.1 is okay or give me right one to change the setup from settings thanks
I'm going to guess here, since the 192.168.1.1 is a Verizon address I think you are asking how you find out the IP address of the printer.
If your printer has a front panel, then you can go through the printer's menus until you find the network settings page. Then you can add the put in the IP address of the printer.
That's a fairly tough task. Is there some reason that you can't just go to the printer properties and share the printer?
Did you use the Windows Network Wizard to create a local network (peer to peer)?
Don
Nov 20, 2009 | HP Photosmart C7280 Printer
I have Windows XP Pro, SP2, Office 2007, and an HP Photosmart C7280 off a wireless router. Printer scans OK but 9 times out of ten it can't see the PC. DHCP is "on" but printer IP address is sometimes Auto...
The problem is you want to have the printer on a fixed IP address. This can be done by reserving the IP for the mac address of the printer in the router OR simpler just set the IP address in the printer.
Change IP settings
The default setting for the IP settings is Automatic, which sets the IP settings
automatically. However, if you are an advanced user, you might want to manually change
the IP address, subnet mask, or the default gateway. To see the IP address and subnet
mask of the HP All-in-One, print a network configuration page from the HP All-in-One.
NOTE: When manually entering an IP Setting, you must already be connected to an
active Network, otherwise the setting will not stay when you exit from the menu.
CAUTION: Be careful when manually assigning an IP address. If you enter an invalid
IP address during the installation, your network components will not be able to connect
with the HP All-in-One.
To change IP settings
1. Press Setup.
2. Press until Network is highlighted, then press OK.
The Network menu appears.
3. Press until Advanced Setup is highlighted, and then press OK.
4. Press until IP Settings is highlighted, and then press OK.
If the HP All-in-One is already connected to a wired network, you are prompted to
confirm that you want to change the IP settings. Press OK.
5. Press until Manual is highlighted, and then press OK.
6. Press to highlight one of the following IP settings, and then press OK.
• IP Address
• Subnet Mask
• Default Gateway
7. Enter your changes, and then press OK to confirm the setting.
Jul 04, 2009 | D-Link RangeBooster G DPR-1260 (DPR1260)...
How can I connect my wireless laptop to print wirelessly?
run the wireless setup wizard on the printer from the front panel menus of the printer...this would assign an IP address to the printer from the router...then use the s/w cd that came along with the printer and get the drivers and s/w installed on your computer....if you want a wireless connection it would give you approprite options
Jun 21, 2009 | HP Photosmart C7280 Printer
I have a HP Photosmart C7280 I ran network configuration page and it says everything is ok. But I can't print anything off the internet How do I no if everything is connectd by the way I have a wireless...
Verify that the printer is getting a good IP address.
Then go to the Control Panel >printer and Faxes>click on your printer.
Then ports . There check to make sure that the printer is showing up next to the box that has the same IP address as your printer. If it does not , put a check mark in the box with the IP address. Then try to print a test page.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 10, 2008 | Office Equipment & Supplies
Wireless problem
First we need to check whether there is a communication between the computer and the all-in-one. Once print the network configuration page from the all-in-one and collect the IP address of the all-in-one and pste it on the address bar of the internet explorer and press enter, this should open the printers information page, if it is opened then there is a communication between the computer and then all-in-one. Now disable the firewall and antivirus and then try to install the drivers. If there is no communication then try to assign the IP address manually to the printer depending upon the computers IP address.
Apr 27, 2008 | HP Photosmart C7280 Printer
HP Photosmart 2710 All-In-One InkJet Printer Logo
456 people viewed this question
Seeker5211
Seeker5211
