Question about Toshiba Satellite M45-S265 Notebook
DVD-CDRW doesn't read anymore..need instructions to install a new one
My DVD-CDRW combo drive has stopped working. It won't do an auto-run, or read anything. I can find sites where I can buy a new one for around $150.00. I need to know how easy it is to install a new one in these laptops, whether I can do it myself or just have someone else do it, even though that would be the more costly way.
Laura
  • 2 more comments
  • laura46 May 11, 2008
    M45-S265 (PSM40U07V001) PC is the Laptop model number. I am running Windows XP. All had been fine with the DVD-CDR combo drive. Then one day I inserted a disk and it ususally auto runs right to the install. Not this time. Tried a few times, turned on and off, etc.
    Then I thought I'd try the old System Restore...and of course that wouldn't boot either. I looked at My Computer to see what it showed on there, and it didn't even show that drive. If I need to install a new one, is there anyway to get instructions for that?
    Thank you for any help,
    Laura
    Where might I look to find a less expensive optical drive for my laptop, please< i don't have time to sit and search hundreds of sites,but would of course like to get a better price.
  • laura46 May 12, 2008
    I haven't tried to remove the old drive yet, it scares me, but I knkow it has to be easy. The link you sent takes me to a Samsung, but it looks like my Toshiba. Will it work/ are they interchangable like these? The price sure is better if it will fit in my computer. The Samsung name just threw me off. You know this stuff, so if you say Samsung is the one, I certainly will buy at that price!
    Laura
  • Ian Cormier
    Ian Cormier May 11, 2010
    what is the brand of laptop what is the os your running and anyother info thanx
I had this same problem and fixed it. In many cases there is NO NEED TO GET an new combo if the old one isn't physically broken. All you need to do is run an optical drive fix. This fixes the registry filters and should handle your problem immediately.
Posted on Jun 06, 2008
  • 39 Answers
Rarely will you find a model with a hard to remove cd-rom drive. Ussually it takes just one screw to remove the drive. If you have trouble replacing the drive yourself there are usually repair manuals available on the manufacturers website, or we'd be happy to find the manual or a tutorial for you :-) (given the exact make and model # of your laptop)
Posted on May 11, 2008
  • 1 more comment
  • Ian Culp
    Ian Culp May 11, 2008
    BTW, $150 is a steep price for an optical drive, even for a laptop. You should be able to find it for about a third of that price :-)
  • Ian Culp
    Ian Culp May 12, 2008
    http://www.newegg.com/Product/Product.as...
    The mounting brackets can be removed from your existing drive and installed on this drive. Were you able to remove the old drive?
  • Ian Culp
    Yes that samsung drive WILL fit in your laptop. All you have to do is unscrew the mounting brackets from the old drive and screw them onto the new drive. Once again I have no step-by-step tutorial for you, but it is a fairly simple process. The only thing you have to worry about is losing those teeny tiny screws :-)
Dell Inspiron 1525 1526 24x CDRW/DVD Combo Drive cannot read to boot osDell Inspiron 1525 1526 24x CDRW/DVD Combo Drive Module Burner
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it if this fails you might try cleaning the lens it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
Jun 22, 2012 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
What type of disc does a sony crx830e support
This is a combo drive
It will support
1. CD reading & burning (Blank CDR and CDRW)
2. DVD reading only.
We cannot use a combo drive to burn DVD.
Jan 02, 2011 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
My disk drive is stuck and will not read the disk. How do I fix this?
make sure that the cdrw/dvd combo is getting enough power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cdrw/dvd combo then plug them back in this will activate found new hardware wizard or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device ?
control panel admistrive tools,computer management,device manager scroll down cdrw/dvd drives?right click you can? you can update driver,roll back driver,or select properties general troubleshoot, select driver? click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Dec 01, 2010 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Optical drives do not recognize disk when trying to load new disk
If you cannot read those CD-disks in _any_ computer, then the disks are "bad".
If you can read those CD-disks, then it's time to replace the CD/DVD drive. Find a smaller computer-store -- often they will remove the "dead" drive, and install the "new" drive, for $0.00, or for a small fee, if you buy the new CD/DVD-writer from them.
Nov 18, 2009 | Dell Inspiron 530 -Intel® Pentium®...
My cd/dvd burner stop working it won't read
Try cleaning the laser lens with alcohol and a Q-tip. If this does not work then the burner is tired.
Aug 11, 2009 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
I have problem in ROM DVD/CDRW in PC cannot read CD but it only read DVD,
verify if it is old combo Drive try installing the drivers for it, then it works, also certain scratches on the cd wont read try cleaning the drive using the lens cleaner, it works......
Mar 24, 2009 | Computers & Internet
My DVD/CDRW only reads commercial dvds
My hl-dt-st cdrw/dvd gcc4244 ata device cannot write on DVD-rw imation cd why. How to resolve this problem
Dec 23, 2008 | Teac (DW224E/S) CD-RW/DVD-ROM (Combo)...
My Samsung CDRW/DVD SM352F plays commercial DVDs but will not recognise an inserted DVD/RW for recording picture files and shows properties as O bytes used space and O bytes free space. What is wrong?
the drive you are using is called a combo drive
CDRW- means CD WRITER
DVD- means DVD READER
DVD WRITER is not included in this combo...
only cd could be read and also written
but is case of DVD , it could only be read..
thankyou,.
regards
JC
Aug 13, 2008 | Computers & Internet
Sony combo drive
Can you please explain more the problem so i can help you? CD-R is the same as CD-ROM!!!! best regards AMINE
Aug 27, 2007 | Sony 52X32X52X16 CDRW DVD Combo Drive...
Open Questions:
See all Toshiba Satellite M45-S265 Notebook Questions
Toshiba Satellite M45-S265 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
