Question about Car Audio & Video
Protection light blinks and amp only turns off and on every 10 to 15 seconds
  • 1 more comment
  • ramseyrrange Sep 03, 2010
    should have clarified on my part, sorry. The speaker wires were checked for shorts and the meter read all these as fine and receiving the correct amount of power, as far as overheating it doesnt stay on long enough to really tell if its overheating. the amp is a kicker zx 100.2 model
    yessir...
    tried that...it still would flash on an off
  • 19,396 Answers
Protection blinks because there is a fault condition. Check the wiring at the back of the amp and stereo. Ensure that the draw from the amp is not excessive, in case use a capacitor.
If that does not solve the problem, it means that there is an internal fault, in that case the amp must be disassembled and tested to find the problem.
Posted on Sep 08, 2010
    Guru:
  • 642 Answers
The obvious thing to check is incorrect output wiring. Remove all connections from the output terminals(speaker connections. If the protection light still comes on, measure supply voltage and remote turn-on voltage(should be more than 12V, less than 16 Volt). Measure earth. Voltage measurement between amp earth connection and battery negative should be no more than 0.5V.
With voltages correct and no speakers connected and the unit still does not turn on it is faulty and needs to be sent for repair. You could attempt a repair yourself, the most common fault is a blown power IC which causes a short circuit on the output. If you dont have any electronics training I would advise against attempting a repair yourself.
If voltages are correct, no speakers connected and the unit powers up then check your wiring and speakers for short circuit. Also check the speaker impedance. 2ohm speakers can be connected in stereo mode. 4 ohm in mono(bridged) mode. Do not connect speakers in parallel. See diagram. The correct wiring is shown for connecting single speaker per channel and multiple speaker per channel. The resultant impedance for connecting the 2 speakers in series is 4 ohm which is correct as your speaker impedance should always be more than the amp output impedance. protection light blinks and amp - c5596ae.jpg
Posted on Sep 04, 2010
  • Rene Rossouw
    Rene Rossouw Sep 04, 2010
    On the stereo diagram xover should be off. Xover acts as a filter
    • off - Full spectrum audio
    • Lo - Lo pass filter - anything under 80 Hz passes
    • Hi - Hi pass filter - anything over 80 Hz passes
    For SAMS operation (stereo with sub) lo and hi pass filters should be installed as shown. The speaker impedance should not be less than shown.
    President:
  • 1,851 Answers
First of all check the speakers cables for short circuit (using a multimeter would be gratefull) or the amplifier / player for overheating.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 03, 2010
  • Stelios
    Stelios Sep 03, 2010
    Have you check the power DC 12Volt? Sometimes if this power is low these kind of amps are stopping for protection.
    Thanks and regards
    Stelios
    direct FixYa link:http://www.fixya.com/users/technical114
  • Stelios
    Another idea: Just for trying, disconnect the audio input and check if it will stay at power onstate with and without speakers cables connected.
    Thanks and regards
    Stelios
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
Why is HDMI LED blinking and there is no power to the amplifier?
I assume that you are connecting your amp to a hi-def TV. Can you try out the TV stand-alone and see if it works? Perhaps there is a problem with the TV. The blinking light tells me that there is a HDMI related problem. What is connected to the HDMI? Check the cable and make sure both ends are connected properly. Disconnect the HDMI cable and see if the amp will turn on. Does it work? Do the lights on the amp come on? Give us some more details. Try the above and report back.
Jul 21, 2015 | Audio Players & Recorders
Tv won't turn on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
if it is 2,2 I have start to finish instructions for this repair in this model.
SD TECH
May 01, 2010 | Mitsubishi WS-55809 55" Rear Projection...
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Jan 02, 2010 | JBL BP1200.1 Car Audio Amplifier
TV will not turn on. Push power button green
Try this and let me know what you find:
If it is 2,2 I have START TO FINISH STEP BY STEP INSTRUCTIONS AND PHOTOS TO SHOW YOU WHERE THE FUSES & PROTECT RESISTORS FOR THEM ARE LOCATED.
The instructions tell you everything you will need for the repair and how to do it.
You can buy all the parts needed for less than 30 dollars on Ebay (I know the best seller there) I have repaired hundreds of these sets with this problem
If this information has helped you rate this solution as I do this here for free.
If you want the instructions & photos let me know and I will post them here for free.
SD TECH
Dec 09, 2009 | Mitsubishi WS-55809 55" Rear Projection...
The green light on our mitsubishi tv WE-48511 turns green and turns on for about a second and then immediately turns off. The unit will not power up at all. any ideas?
PRESS AND HOLD “device”(or input) and “menu” buttons on front of tv for at least 5 seconds and then release both together.
if this information has helped you rate this solution as I do this here for free.
SD TECH
Nov 27, 2009 | Mitsubishi WS48511 48" Rear Projection...
Kenwood vr 357 surround system stand ny light keeps blinking when turned on but no sound no nothing when turned on just powers up for 7 seconds then shuts off with light blinking
This means there is a problem with the system it is in the protect mode it will not come out of that mode untill repairs are made. More than likley the power amp is blown.
Nov 06, 2009 | Kenwood VR-357
My model is a WS-55511. I turn on the TV, the
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Protect led light
It appears that the amp is going into protect mode. To eliminate external causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 10, 2008 | Car Audio & Video
Mitsubishi VS-50607 Won't Turn On
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.
Sep 25, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
