What kind of cable if any can i use to make my wd52526 proj tv my pc comp monitor
    New Friend:
  • 98 Answers
Your projection TV has HDMI input so you would need to either run an HDMI-HDMI cable from an HDMI output on your computer or, more likely, a DVI-HDMI cable from the DVI output on teh computer to the HDMI input on the TV. If ycou can'T find a DVI-HDMI cable note that you can also buy DVI/HDMI adapters for one end of an HDMI-HDMI cable.
Note that DVI is HDMI minus the sound so if you do run DMI to HDMI you'll also need to route the sound to your TV or other amplifier.
If you only have a VGA output on your computer then you will not be able to easily run this to your TV as VGA is an anologue signal while DVI and HDMI are digital. To do this you'd need a converter.
Hope this helps. If so then please rate my advice.
Thanks
Posted on Sep 03, 2010
HDMI from Virgin cable box to Samsung 400px monitor
should have vga cable and sound cable is the same as the mic cable normal'y green jack on mother board, vga is standard flat screen for computer plugg'es into tv comp or aux will have on tv menu hmi aux,comp
Jan 02, 2014 | Samsung SyncMaster 400PX 40 inch LCD...
Does my comp Video Card supports digital signal output through VGA function? If not, what kind of cable i have to use to connect it to TV Toshiba(flat ckreen, digital)? I'v tried many cables... just...
no vga is just analoge use a svideo cable and set it up as pal if your tv is a pal or ntsc if ur tv is ntsc the tv format is not right ntsc is us pal is japan it can be found the ati cfg utility
Jan 18, 2011 | Gateway MT6840 Notebook
I connected my Dell laptop to my Vizio HDTV with an SVGA Monitor Cable, but I get a blue screen and "No Signal" when I select Comp on the television's input menu.
It's because the tv is connected as a second monitor and it must be configured accordingly. Follow this
http://freewindowsvistatutorials.com/customizeWindowsVista/customizingAppearanceAndSounds/configureDisplaySettings.php
 the tv will be the second (2) display. Also make sure you select the native resolution of your tv for the best image quality.
Mar 18, 2010 | Dell Latitude D620 Notebook
No video image on LCD but OSD works
Sounds like you may have a bad video cale or a dmaged or bentpin in the connector, remove the cable from the monitor and look at the pins on the connector
Dec 14, 2009 | Philips 170S4FG 17" LCD Monitor
Sometimes the picture on this monitor used to fade out to all black when my comp was idle but blocked from going standby. and recently it just quit working. when i power up my comp, the monitor gets all...
first u have to chk whether the screen has that kind of a colour in BIOS> if it has its a monitor issue> if not it can either be the video card that u use> or else the graphics chip on ur computer motherboard>
u can still try Reseating RAm and CMOS on ur motherboard then chek if ur computer boots with display
Oct 09, 2009 | Sony SDM-HS73P 17" LCD Monitor
Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Jul 25, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung hdtv to compaq pc
There should be a setting within the comp. Is it connected to the comp monitor and the tv? Perhaps from the comp to the tv with the monitor from the comp as well? Well if so, you may need a certain setting within the comp. Check under (on xp) display properties, and then under the settings tab. Please rate!
Apr 28, 2009 | HP Compaq nx6110 PC Laptop
Pc connected to tv, image is fine, audio won't come out of tv
Do you see a small audio jack next to rgb connector? hook your audio cable (3.5mm mini plug) to this. ought to do it. regards kindly, meder's tv
Mar 28, 2009 | Toshiba 37AV502U 37 in. LCD HDTV
Monitor keeps blank even the power lLED is on green
I suspect the problem is with the monitor itself. I have had the same problem. I reported it to Dell and they sent me a new monitor within a few days the problem resurfaced again on the new monitor. They have since sent me a new monitor and the problem has disappeared. The Dell customer service people sounded rather cagy to me when I suggested that this was a problem endemic to this model. The replacement monitor that I have had a sticker on the box that read "refurbished". This is a rather new model of monitor to already be into selling "refurbished" models. If you are still under warranty I suggest you call them. And even if you aren't, call them anyway. I sense that they know about this problem.
Oct 23, 2006 | Philips 105S51 15" CRT Monitor
Computers & Internet Logo
327 people viewed this question
David Payne
David Payne
