Unclear TV pictures
I'm renting a house with outdoor antenna on the roof. The TV connected to the antenna is clear when the antenna is in 'good' mood. When it's windy, the antenna 'moves' & the pictures became unclear. I'm afraid to get to the roof top to 'fix' the antenna, what should I do? (BTW, I don't need extra channels so setalite dish is not an option, just the few we get for free is more than enough)
  • Anonymous Mar 13, 2014
    do not know how to get a channel on my tv to work the usb stick. only have hdmi and antennae options
    Problem Solver:
  • 8 Answers
Well what your problem is the antenna is not secured well enough to the roof. You really only have a couple options, you can secure the antenna better or just live with the fact that when it is windy your channels will be fuzzy.
Posted on May 11, 2008
Need to know how to change and setup for use of antenna
Purchase your UHF/VHF antenna. The antenna can also be purchased at most electronic and retail stores. Consult your list from Step 1 and see how powerfulicon1.png the over-the-air signals are for your specific address. Purchase your antenna based on the broadcasting power you need to receive a clear picture on your TV. You might be able to get away with an indoor antenna if your signal strength is strong enough. If not, you'll need to purchase an outdoor antenna.
  • 4 Install your antenna (or have it done professionally) according to the building codes of your area. If you must use an outdoor antenna, it is a good ideaicon1.png to have the antenna professionally installed. This ensures that it is properly grounded on your roof, not too close to electrical wiring and stable during inclement weather.
  • 5 Hook the converter box up to your television using the cable that came with it (F Cable). Hook your antenna up to the converter Box. Turn on your TV and converter box. Tune your TV to channel 3 and press "Scan" on the digital convert box. Allow the box to scan for your available channels.
  • 6 View your picture and adjust your antenna accordingly for the clearest over-the-air feed. You should only need to make adjustments once. If you are having a difficult time getting a clear picture, use a signal strength indicator to see where you receive the most powerful signal.
  • Read more: How to Replace Cable TV or Dish TV With Antenna TV '
    Mar 29, 2013 | Sansui 19 in. LCD TV
    Ge antenna 24700
    Hi Patrick,
    A fuzzy signal on a plasma TV is not common anymore as with the lack of analog TV transmission the signal is either there or it is not.
    A amplified HD TV antenna is not always a solution and often times to get a good HD type reception a good outside antenna is required. I have two $100 antennas high up on my roof and still you can get a loss of data stream when the weather is bad. I also use distribution amplifiers to feed several TV's
    In the case that the picture is fuzzy but still there it might be a resolution setting that is wrong so hit the menu button on the remote and see if that display is clear- if it is then try setting a different resolution for the input that you are getting fuzzy signal on.
    Aug 10, 2012 | Televison & Video
    Weak signal
    Please, start thinking of "outdoor" HDTV antenna installation. You must of be in use of TV's SD tuner and "rabbit ears" or so. Only outdoor or "roof" antenna will solve your issue. Unless you have another option: satellite, cable, verizon? Check with them, first.
    Need antenna?
    Call Alex's Television.
    Nov 29, 2011 | Toshiba 26AV502R 26 in. LCD HDTV
    Moved into house, used auto tune feature on analogue tv get poor reception on everything bar two channels, bought DTV, autotune gave same result, with no digital channels picked up at all. Obviously an...
    Yes its antenna problem?maybe your house too closed signal your antenna is getting hard to find signal for your TV.
    You must use a Outdoor Antenna to widen your signal range.
    And also i suggest that you move you antenna outside your house or at your roof to be able to enhance the signal for your TV.
    Hope my solution will help.
    Jul 03, 2011 | Computers & Internet
    With or without my indoor rabbit ears, cannot get any channels below 7. the people where i got the antenna told that i could connect my roof antenna to an adapter and connect it to the antenna input on the...
    You heard is correct. Your roof antenna can be connected to your TV, after connecting it to a balancing coil adapter, usually called 'Balun Adapter" which converts the impedence from 300 to 75 Ohms. It can be bought for most of the electronic shops all around. Connect the antenna wire to it and then plug it to your TV antenna in socket. The stations will be very clear, and well defined. You may have to turn the roof top antenna towards the direction of the transmitting tower to get a well defined, ghost free image. OK.
    Mar 27, 2011 | Televison & Video
    Missing or weak signal
    try a outdoor antenna on the roof for digital signal use.also the main digital PCB is defective which has the tuner on it if the antenna does not may try taking the
    tv to a friends house and see if the tv works better.
    Sep 04, 2009 | JVC LT37X787 37 in. HDTV LCD Television
    Mitsubishi vs-50603 does'nt get regular antenna chanels.
    Indoor antennas have very limited capabilities especially in areas with elevation changes and heavy tree cover. Ideally, you should put an outdoor antenna on your roof or the highest elevation you can find with a relatively short distance to the TV. Make sure it has a good UHF section as this is where all digital broadcasts will be sent by the broadcasters as the digital transition occurs. You might try an amplified indoor antenna for better results than what you have now, but its no substitute for an outdoor antenna.
    Feb 16, 2009 | Mitsubishi VS-50603 50" Rear Projection...
    Digital tv
    Good Day, tuff65;
    Today with "HD TV" get a good UHF/HD antenna. You can get at any local Best Buy, Circuit City, Radio Shack etc.
    Good Luck, big IRISH. PS: Inside or outdoors.
    Sep 03, 2008 | Hitachi 53UDX10B 53" Rear Projection...
    Pay tv cable
    you may bypass the box by using a straight connector, find the cable that lead to the TV room and connect it to the cable from the aerial antenna.
    Mar 06, 2008 | Televison & Video
    Televison & Video Logo
    146 people viewed this question
    Top Televison & Video Experts
