Question about Canon Pixma iP3000 All-In-One InkJet Printer
How do you change the waste ink absorber - Canon Pixma iP3000 All-In-One InkJet Printer
  • Canon Master
  • 525 Answers
This is all procedure, no need to disassemble printer.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Posted on Jan 23, 2011
Error ink absorber troubleshooting
Not all of the ink that leaves the ink-cartridge is sprayed onto the paper.
Some of it is "waste" ink, that goes into an absorber, to be held until the absorber gets saturated or full.
Change the waste-ink absorber.
Apr 20, 2011 | Computers & Internet
Ink tank nearly full. How do I change?
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Only service centre can do the job only.
Jan 09, 2010 | Canon PIXMA iP90 Mobile Printer
Full ink absorber
Jan 02, 2010 | Canon PIXMA iP90 Mobile Printer
Tank for used ink is full - how do I change it?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 14, 2009 | Canon PIXMA iP2000 InkJet Printer
Message" waste ink absorber"
There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
Check your user's manual about the procedure for changing the absorber and where to buy new ones.
Dec 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
How do I clean the waste ink absorber on a cannon ip90
We are not advice to clean WASTE INK ABSORBER.
Nov 24, 2009 | Canon PIXMA iP90 Mobile Printer
Waste ink absorber
You'll always find the wast ink absorber under the printer head after printer head prints and rest, there is a rubber type clip which cleans the head and the ink drips down on the cushion absorber. Disassemble the printer and remove the cushion than dip in the bucket of water until ink dissolves out of the cushion and wash under running tap until clean then dry and finish, put back the item and assemble the printer.
Nov 06, 2008 | Canon Pixma MP450 All-In-One InkJet...
Canon pixma MP110 waste ink absorber full
1 - Turn on the printer
2 - press MENù SCAN COPY SCAN (it will enter in service mode)
3 - select TEST MODE
4 - Select PRINTER TEST in TEST MODE
5 - Select EPROOM CLEAR
6 - Select INK COUNT
7 - Press OK
8 - Press the STOP/RESET key and then press the ON/OFF key
9 - Change the waste ink absorber in the printer
Oct 24, 2008 | Office Equipment & Supplies
How do I find the waste ink absorber
The waste ink absorber is usually in the right side of the printer where the cartridges reside when the computer is off. To find the waste ink absorber you need to lift the cover of the printer remove the screws or some printer unlock the clip to remove the cover. After you remove the cover in the right side of the printer. The waste ink absorber is in the bottom of the printer head. Some printer you need first to remove the head before you can remove the waste ink absorber. The waste ink absorber is like a foam that we using in the dish washing you can wash and dry also. But before you can remove the waste ink absorber try first to solve the problem by using some guide how to reset the waste ink absorber problem. If you encounter this search in the internet about how to reset the waste ink absorber.
Apr 18, 2008 | Office Equipment & Supplies
Waste ink carterage full
You have to send it to your nearest service centre.
Nov 03, 2007 | Canon PIXMA iP90 Mobile Printer
Canon Pixma iP3000 All-In-One InkJet Printer Logo
59 people viewed this question
old marine
old marine
