Question about KitchenAid KHMS2050SSS Microwave Oven
Food does not heat up anymore even when running
  • KitchenAid Master
  • 909 Answers
To correctly sort the problem out, you need to replace the magnatron and capacitor with the HV diode. That will definately sort the problem out. Do not do this repair without supervision as a microwave is truly a dangerous item to repair.(Make sure the plug is out when inspecting the components. You must be exact when ordering the componenents. Read off the numbers to the supplier to get the correct items.(Thats if you insist on doing it yourself).
Posted on Sep 03, 2010
My microwave does not heat. Sounds like it's working just fine....but food is not heated. Is it time to replace it? Panasonic doesn't support it anymore.
By the time you pay for the service call to diagnosis the part needed and labor it can cost anywhere from 250-400 dollars to repair I discourage home owners from attempting to repair a MW parts store lethal voltage even while unplugged there are too many components from the control down to the magnetron that could have failed if not supported anymore I would advise replcment
Apr 06, 2015 | Panasonic Microwave Ovens
Bosch microwave oven,turntable not working,food not heated
Even if the turntable isn't turning, the oven should still heat the food but it will be uneven cooking. I would suggest that the unit is not "microwaving" This is usually the high voltage capacitor, fuse or diode failure. You will need knowledge of how microwave ovens work and specialist tools to test these. If you don't, I would suggest you get a tech who does. There are extremely high voltages in microwave ovens.
Feb 23, 2015 | Bosch HMT75G451B Stainless Steel...
Microwave not heating food model MA795B
1 door interlock
2 diode
3 magnetron
4 heat censer
5 dry joint on relay on timer board
6 Re: Jeff
Apr 12, 2012 | Goldstar Microwave Ovens
GE Microwave JVM1850 Does not heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jjs
Apr 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Won't Heat
Check the door safety interlock switches. Be careful of the capacitor, potentially dangerous.
If the switches dont make a connection, the magnetron will not energize ... no heat
Apr 19, 2010 | Microwave Ovens
JVM1540 Above the oven microwave is not heating anymore
heatman101
gfgf
Dec 15, 2009 | GE Spacemaker JVM1540 Microwave Oven
Microwave still runs but is not cooking food
Sounds like a bad magnetron, i would replace the magnetron, Capacitor and Diode at the mag assembly, to be honest it will cost you more to fix than a new one.............
Sep 10, 2009 | Magic Chef CMV1000B Microwave Oven
Whirlpool mircowave will not heat
HI, the high voltage capacitor is unstable and, it has damaged the Magnetron. you will need to replace the Magnetron. it will run you about $191.30. this will restore the heating action in your microwave unit.
May 27, 2009 | Whirlpool MH6130XEB/Q Microwave Oven
Microwave doesn't heat food anymore
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Apr 21, 2009 | Frigidaire PLMV168 Microwave Oven
Microwave doesnt heat food
Microwave not heating problems are the result of one or more of the following problems -
1) Bad fuse
2) Bad diode
3) Bad capacitor
4) Bad transformer
5) Bad magnetron.
You would need to have special equipment to test the 2nd, 3rd, and 5th items.
Reply back of any other questions/help you may need.
Feb 03, 2009 | Whirlpool GH8155XM Microwave Oven
KitchenAid KHMS2050SSS Microwave Oven Logo
199 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
