Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
Maytag ensignia makes a great deal of noise during rinse cycle
  • Maytag Master
  • 909 Answers
"If you dont have a noisy spin cycle and the noise you hear is only on the rince cycle, dont be worried, as this is totally normal. Water sprays onto the drum while the spin cycle is in progress and rewets the clothes to allow any existing soap to be desolved. This noise is in effect the water hitting the drum during the rince part of the cycle.
Posted on Sep 03, 2010
No agitation on extra rinse cycle on Maytag Washing Machine MAV8557AWW
The manufacturer may have found there was little or no advantage to having agitation in the second rinse cycle so omitted it.
Jan 08, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Need info about extra rinse cycye
there should be agitation..dont know unless its not making the connection in the control head..
The machine is very noisy during the wash and rinse cycles. Sounds like something is slipping
Tip back the washer and remove the belt. No tools are needed. Examine the pump for bearing separation and turn it by hand to see if it is stiff. Look or belt wear. If that is good turn the main drive pulley both ways. Spray a little WD 40 on the brake rotor if it is making a noise. Sometimes it will rust over and growl. More here
Aug 18, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
My Maytag Ensignia washer is making a clunking noise like something is loose when it is in the rinse cycle.. also does not appear to be spinning as well as it should. What could be wrong with it
Mine had the same problem! Turned out to be the transmision going bad. My machine is only three years old. Transmision cost over $250 Not worth fixing. The inside of this machine is very poor quality. I am very disapointed. Maytag not the quality it once was. I WILL NEVER WASTE MY MONEY ON A MAYTAG PRODUCT AGAIN
May 24, 2010 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag washer stopped working at the rinse cycle
do you have the machine set for cold water rinse? if so, the solenoid that allows the cold water to come into the machine may be malfunctioning. try to see if it will fill in the rinse cycle with hot water? if so, you need to change the water inlet valve.
Oct 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Spin cycle not working properly
On the transmission there are two shift arms. One shift arm controls the agitator and the other shifts to spin the cloths. If the washer has been making a "clicking" sound when it trys to spin, the solenoid that shifts the spin shift arm is not catching and the drum will not spin. The other possibility is the spin clutch is slipping and make a "grinding/ratcheting" sound. Neither, unfortunately are inexpensive to fix.
If you can describe the sound and when it occurs, I might be able to get closer.
Let me know.
Regards,
May 15, 2009 | Maytag Ensignia MAV4757AWW Top Load Washer
Maytag Washer whines during rinse belts burn
that friend is about the best possibility I can think of. This site has all your parts for the washer you have www.repairclinic.com
Mar 21, 2009 | Maytag LSE7806A Top Load Stacked...
Burning smell/noise with my Maytag Ensignia MAV7657EWQ Washer
it could be [motor] or 'condensur' for motor, starting to burn out or over heat, check drive belt as well for ware
Dec 08, 2007 | Maytag Ensignia 3.3 cu. ft. Top Load...
"howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Jul 25, 2006 | Maytag SAV5701A Top Load Washer
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
299 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
