Hi, I have a Samsung J1045 front load washer, the door is stuck and I think I may have broken something while trying to force it open. Is there a way to open the door and also can the loack be replaced? Thank you for your help
  • derrickwaite Sep 05, 2010
    I have a samsung j1045 front load washer, the door got stuck and i have broken the handle while trying to get it open. Since then i have managed to open the door through the latch at the handle with a screwdriver. I have niw removed the door. I just need to know where i can get a replacement handle here in Perth, Western Australia. The advice i got from the expert before was of NO help whatsoever.
    President:
  • 1,554 Answers
Here's where you can find the part you need for your machine.
http://spares.bigwarehouse.com.au/
Also on the left pane are lists of Brand names, select Samsung then washing Machines. Select the model of your machine (J1045iW-XSA) then look for the door lock part.
Please make sure to accept the solution you find the most helpful. Failure to do so will automatically give credit to the first solution no matter how not helpful it is. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Sep 05, 2010
  • Washing Mach... Master
  • 17,130 Answers
You will need to loock from the bottom to get acess to the door swittch. The gravity of the jamming of the lock will depend on who it is stuck inside.
If you are tech savvy then you open this section and release the lock. This type latch on type locks are available but the end switch settings must also be present so as to have the safety mechanism of shutting machine when the door is opened or the door will be latched during wash rinse cycle and will be released only afterr the end cycle,
So this link of the door latch must confirm to the original or else get help from Samsung.
Posted on Sep 03, 2010
SOURCE:
LG 1056QD front load washer door will not open. It's locked. I have tried forcing it open but didnt work. Any suggestions please?
sensor is not fully trip to open position check the sensor there must be a broken plastic thats prevent the sensor in open position the sensor is located inside the machine behind the door
Oct 26, 2013 | LG F1402FDS6 Front Load Washer
Samsung j1045 washing machine
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Oct 14, 2012 | Samsung Front Load Washer Control Board...
Samsung vrt fl code
Check both parts of the latch mechanism. Something may have gotten stuck or the latching device may have broken
Sep 08, 2012 | Samsung WF337AA Front Load Washer
Front loader iwll not start DE error code Samsung model J1045
this means door error sometimes you have to rewire it, replace the computer & the door interlock all at the same time to fix it try the door interlock first beware sometimes if you dont do it all at once the new part gets taken out as well so fingers crossed its just the door interlock.best option to have samsung service agent out to check out with diagnostic tools.
Jan 13, 2011 | Samsung WF337AA Front Load Washer
My neptune frontend loader will flash the door lock for 2 seconds and then it will go off when ever i start the machine, i think my child opened it with out turning it off.. is something broken
HI- It is possible that the door lock was damaged if someone forced it open mid-cycle. The machine will not cycle unless the door lock engages. Will probably need a to get a Tech out to have a look. Good luck.
Sep 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a Samsung j1045 frontloader washer and it turns on but would not move to any wash cycle or turn off.
I have a Samsung j1045 front load washer and once turned on, it wouldnt move to any washing cycle or turn off. I would have to unplug the cord from the jack to prevent any danger. Please help me and give me a solution as I have a mountain load of washing to do.
Nov 02, 2008 | Washing Machines
Broken front door
you need to buy a new 'handle'. to open the door for the time being, disconnect power and then use a coat hangar to pull the latch towards you, ie. outwards
Jan 29, 2008 | Washing Machines
LG 1480fhd
Try first to unplug the power cable and see if it allow you to open the door. In case it will not help, you have to raise the top of the washer to get to the switch and release it manually (The switch is inside the washing machine main housing near the door frame). Good luck
Sep 03, 2007 | LG WM-1480FHD Front Load Washer
Washing Machines Logo
259 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
