Question about Toshiba 42HP66 42 in. LCD Television
Toshiba 42HP66 Picture fades in when turned on. After taking off the back  panel noticed the Zsus board had a bad fuse on the 180V Side. After replacing  the fuse the tv wont power on and the power supply kinda locks it self out. If I  remove the fuse that I put in I get the TV to turn on to the fuzzy fading picture.
  • Anonymous Jan 31, 2009
    When I turn on my TV the only colors that appear are blues and grays, it takes about 5 minutes or so for all of the colors to appear and then the brighter colors seem to pulse. It has gotten progressively worse. Is there anything I can do to fix this problem myself? the TV is only 2 years old.
    Genius:
  • Toshiba Master
  • 1,673 Answers
To start, the module with the blown fuse will have to be replaced. The rest of the boards will have to be verified to know which other ones may have been the cause of the failure.
You will have to give the set out for factory service to have it working again.
Jerry G.
Posted on Jun 06, 2008
I have a toshiba 50hp plasma t.v. and it made a popping sound and the picture went dark and somewhAT FUZZY. CAN STILL SEE PICTURE BUT BAD COLOR AND ITS DARK. IS THIS ANN EASY FIX OR IS IT NOW TRASH?
I am ready to bet my lunch that you have a bad ZSUS board.
There is less than 1% chance I would go hungry and that's with around of thousand of such repairs on my back.
This is the link for what you need:
http://www.coppelltvrepair.com/p/263/75003043-zsus-board-for-toshiba-50hp66-repair-service
Aug 03, 2013 | Toshiba 50HP66 50 in. Plasma Television
I have a Toshiba 42HP66 Plasma and I have no picture or sound. It worked great and than the next time I turned it on there was nothing. It would turn on and turn off right away. I had pulled the wires to...
I have another model Toshiba LCD tv and have had the immediate turn off problem a few times before. What has worked every time for me so far is to repeatedly press the power button (on, off, on, off) about ten times or so. Then turn it on and see if it stays on this time.
Mar 05, 2011 | Toshiba 42HP66 42 in. LCD Television
Have sound. But no picture
The Zsus and Ysus Board are common failures. It is a possibility that the Plasma Panel also is the problem. If you take the back off, (make sure unplug the set first), the board on your left is the Zsus and is marked accordingly. The Ysus is on the right of the Power supply. Look for fuses being open on the Zsus Board and Power Supply using a ohm meter. If they are, I would replace both Zsus and Ysus. They seen to fail together many times. If the fuses are good. I would suspect the Plasma Panel.
I hope this helps,
Skyassoc
Dec 10, 2010 | Hitachi 55HDS69 55 in. Plasma Television
Toshiba 42hp66 has sound but no picture. I hear 2 clicks and Power led turns green when I turn it on, 1 click and led turns red when I turn it off, no picture at all.
Part of the power supply is in protect mode. There is most likely a short or something failed on one or more of the boards.
The service rep would swap out boards to locate the fault. Then he would leave the new board(s) in the set, and perform any necessary adjustments.
Take the set in for an estimate before approving repairs. There are many times these sets are not worth serving when they are out of warranty.
Jerry G.
Mar 05, 2010 | Toshiba 42HP66 42 in. LCD Television
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
Toshiba 42hp66 without an image
Hello, You most likely have a bad Y sustain board! Part #'s are:
6871QYH053A, 6871QYH053B, 6870QYH005B, 6871QYH953A, 6870QYH105B.
Here is a link to the part you need!
http://www.discount-merchant.com/Y-SUSTAIN-PN-6871QYH053A-6871QYH053B-6870QYH005B-p/vizio-sku9506.htm
I hope this help you! Please feel free to give me a call or message me if you have any questions! Ask for Dave!
Thank you! :-)
Dave
1-503-432-9904
pleasefixitdave@yahoo.com
Jul 06, 2009 | Toshiba 42HP66 42 in. LCD Television
How to change lamp in toshiba 42hp66?
This TV is a plasma according to the model number you've posted. It does not use a lamp.
If the plasma does not show any picture, there might be a defective Ysus, Zsus or power suppy board.
There is a high failure rate on the Ysus and Zsus boards.
Search for a Ysus and Zsus board on google and you should find them.
Good Luck.
Jul 02, 2009 | Televison & Video
No picture on my Toshiba 42HP66 plasma tv.
I too have this problem with no help from hh Gregg, where I bought the tv, and no help from Toshiba. I resorted to calling the BBB and complaining about the defective workmanship. I took the tv, which is less than 2 years old, apart and found the y-sus board, behind the y-sus board is a foam rubber spacer to seperate the circut board from the backside of the screen. I think this pad is designed to prevent heat buildup in the y-sus board. The pad itself is held on by glue and that glue melted causing the y-sus board to short out. I noticed this after finding a tacky substance behind the board. The heat from the plasma screen melted this and also the pad itself. Toshiba claims no resposibility because the tv was out of warranty. Thanks Toshiba.
Jan 22, 2009 | Televison & Video
Toshiba 42Hp66 No picture only sound
to test the zsus board check for a low resistance on the fuse to ground. sadly if the zsus is bad, the ysus and one or both of the driver boards is probably also bad. best to change all at once as a defective one can tacke out the others.
Apr 19, 2008 | Toshiba 42HP66 42 in. LCD Television
Toshiba 42HP66 42 in. LCD Television Logo
455 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
