I need to driver sata raid for portege s100 versi v 1.3.8.0
    New Friend:
  • 98 Answers
Toshiba RAID driver for Portege S100, Windows XP v.1.3.8.0: http://cdgenp01.csd.toshiba.com/content/support/downloads/raid138.zip
Posted on Sep 03, 2010
Setup did not found any hard disk installed+toshiba s100-s1133. While trying install windows xp
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 06, 2012 | Toshiba Portege S100-S1133 Notebook
Want to install fresh windows xp pro to my toshiba portege s100 series but the windows installation sain that there is no hdd installed on the system
HI
this problem shows that your HDD is not recognized bye your notebook...
try this:-
  1. Go to the BIOS and change your hdd priority IDE to SATA, select SATA for your note book an then restart and check ..
  2. reconnect your hard disk on your system.
ifyou find this is helpful for you so please rate me this will encourage me to domore free work..
regards
sandy
Sep 08, 2011 | Toshiba Portege S100-S1133 Notebook
Hi i have a portege s100-s1133, i try to install new os but the hdd cant not detected, but if i tried to boot into windows the hdd are detected. and im tried to go to bios settings because i want to change...
1.FIRST YOU DO ONE THING IF YOU USING XP OS MEANS CHANGE THE SATA MODE TO IDE OTHER WISE CHANGE THE SATA MODE TO AICH.
2.IF BOOT WITH CD MEANS CHANGE BOOT PRIORITY CD/DVD ROM
2.IF YOU BOOT WITH HDD MEANS CHOOSE HDD.
BIOS OPTION----CONTINUOSLY PRESS F2 KEY.
Nov 17, 2010 | Toshiba Portege S100-S1133 Notebook
Toshiba portege s100 without battery
in can work even no battery pack. using your power adapter.
Apr 15, 2010 | Toshiba Portege S100-S1133 Notebook
I want to install windows vista on toshiba portege s100-s1133, it has sata harddrive when i try to install vista but it is not showing hard drive i need stat drivers for vista
You can download any/all the Windows Vista device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Mar 30, 2009 | Toshiba Portege S100-S1133: S100-S1133...
Slow transfer from SATA II (IDE) drive to 3 SATA II Drives configured as RAID (1). Drives wouldn't format until we installed the OS onto the RAID -- but it wouldn't install completely. We boot from the...
It appears you have made an error with the RAID configuration. RAID 1 is mirroring and requires an EVEN number of drives unless one is a hot spare. Also, RAID 1 is for redundancy and is slower than a single drive or RAID 0. Verify your RAID configuration and make sure you have RAID 1 and not RAID 0 or RAID 5 which can be an even or odd number of drives.
Nov 17, 2008 | Computers & Internet
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
I accidentally removed SoundMAX Audio from my PC and now I have no sound.
Go HERE and select your model (Portege s100) to get the drivers and software you need.
May 21, 2008 | Toshiba Portege S100-S1133 Notebook
Installing windows without DVD
The hard disk is not recognized from USB because of SATA drivers not present on XP setup disk.
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Mar 17, 2008 | Toshiba Portege M205-S810 Tablet PC
Install xp-sp2
First you must know is that RAID has nothing to do in a laptop... that function has nothing to do if you use just one HD, I doubt your laptop supports that RAID thing, but if it does you should disable by entering your bios first. It could be SATA problem, that many times the silly companies call RAID or something else...
I would need precise information to help, information about what you do exactly and what exact messages you get.
normally if your hardware is OK and its just a laptop and there is no other thing connected to it, windows should install perfectly... so either you are doing something else or you have hardware problems. Stay in touch with more info please.
Oct 27, 2007 | Toshiba Portege S100-S1133 Notebook
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
