How to connect kenwood GE 52 graphic equalizer to my sony str-DE345 any idea , please help me.thanks.I tried many combination but didnt work.
  • 52 Answers
An EQ usually plugged between a preamp and an amplifier. You have a receiver. There's no connections that will let you do that. The only thing you can do is between a source(ie: CD) and the receiver. The CD will go in the eq and out of eq to cd input on the receiver
Posted on Sep 03, 2010
  • Rusell Tobin Aug 30, 2012
    I'll try it. But will my phono have the source to be equed also?
  • Rommel Cana
    Rommel Cana Aug 31, 2012
    with the arrangement above , No
My sony STR-DE345 amp says "protect" and there is
The manual says it thinks there is a short circuit on the amplifier output side. If it still says Protect after disconnncting all the speakers wires there is an internal problem. Take it to a hands-on tech.
If the problem disappears, you had a short. Attach speakers one at a time to isolate the cause.
http://www.retrevo.com/support/Sony-STR-DE345-Receivers-manual/id/387bh943/t/2/
Dec 24, 2010 | Sony STR-DE345 Receiver
Sony str-de345 this keeps on making a
the clicking is a power suplie overload some output amp is with problems and shutdown after overheat, when you tap is bad connection inside, normaly is related with sound off after 15min. needs to be checked by tech. to ensure perfect operation.
Jan 30, 2010 | Sony STR-DE345 Receiver
I have a Sony STR-DE345 receiver, it occasionnal cuts out all together, I removed the cover, and there are two round pieces side by side that look like two "c" batteries, well when I wiggle the one on the...
First things first, be careful wiggling components in a unit that is pugged in. Even after the power is turned off and the steroe is unplugged you can still be shocked by a discharging capacitor.
It sounds like you have a broken solder connection. If you have a soldering iron and can access the solder side of the board, you can repair the connection by applying more solder to the board. This will reflow the old solder and add more which should give you a complete connection again. Be sure to check for shorts after you are done. If your solder flows to another component you may end up damaging the receiver completely
Dec 17, 2009 | Sony STR-DE345 Receiver
No display lighting up.
The first thing to check is the solder connections on the display itself. The display should have a series of pins that you will see on the PC board that is behind the front panel. Resolder the connections on either end. These are the connections that supply both the +and - sides of power. These often develop poor connections. Update this with the results of the resoldering and we'll continue from there if the problem is not resolved.
Dan
Sep 17, 2009 | Kenwood Audio Players & Recorders
Sony receiver STR-DE345 OVERHEATED how do i fix it ??????
these do run hot, they don't have a fan so they need good ventalation. If your has completely failed you may be able to resolder the voltage str and stk voltage driver Ic's or replace them.
Jul 16, 2009 | Sony STR-DE345 Receiver
Str de345 shuts down after a few and flashes (protection) on face of amp.
The Receiver is going into protection mode and possible some speaker cable might have touched the body or with each other.
Remove all inputs and outputs and then restart the receiver. If it starts then you are lucky and no further repair are required.
Connect all cable and wiring properly and ensure that they do not touch each other. You might have to reset the microprocessor also.
If the problem persist then let me know to further the trobleshooting.
Please do rate this solution and thanks for using FixYa.
Mar 08, 2009 | Sony STR-DE345 Receiver
I need a schematic or service manual for Sony STR-DE345.
hi,
i can download it for you..
visit this site for manuals of your unit it will help you answer all your questions.
http://www.free-service-manuals.com/Detailed/15736.html
thanks,
you rate in our answers are much appreciated..
Feb 19, 2009 | Sony STR-DE345 Receiver
313 people viewed this question
 Grubhead
Grubhead
