Question about HP LaserJet 5550dtn Printer
HP Laserjet 5550dtn printer is giving error 59.51, what will be the problem?
  • 1,110 Answers
This code means there is a Cyan Cartridge motor error. The most common cause of this error is the Cyan Toner/Drum cartridge is binding up and causing the motor to stop turning. I would try removing then re-installing the Cyan cartridge first and see if it goes away. If not then replace the Cyan cartridge with a new cartridge. If the problem persists then there is a problem with the drive assembly for the Cyan cartridge.
Good Luck and Thank You for using Fixya.
Posted on Sep 03, 2010
  • 3 Answers
SOURCE: 59 C0 error on hp color laserjet 5550
I had the same error, I had to take the left side cover off, (looking at the front of the machine) and found a small piece of paper that ended up right in the middle of a sensor flag! Of ALL the places to land. I pulled it out, it worked, end of problem! When you get the side cover off, the sensor flag is located in the middle/bottom of the printer. Hope this helps, happy fixin'.
Posted on Sep 08, 2008
  • 102 Answers
SOURCE: Printer Hp Laserjet 3055 giving error message 5
If you scanner error 5 or printer hangs at scanner bulb warming up than the issue is with Scanning Assembly inside the printer and it is hardware issue.
Posted on Jul 02, 2009
  • 1218 Answers
SOURCE: hp color Laserjet 5550 59.C0 printer error message
For those users who are having a problem with the printer motor, this C level problem is referred to as 'developing disengaging motor rotation error'. Most likely, this problem points to an issue with the function of the DC controller: either it has failed or it has affected the developing disengaging assembly. The solution is quite simple and the user may fix the error in a matter of few steps. The first step is to reconnect the J16 connectors that are used for the developing disengaging motor to the J1100 connectors that are used for the DC controller PCB (that is the printer circuit board of the DC controller). After connecting these two connectors to each other, the user must replace the developing disengaging drive assembly directly. The final step is to replace the DC controller PCB, after which the printer is to be recalibrated. get more information and help for Printer Error Code 59 c0
Posted on Sep 16, 2010
  • 10 Answers
SOURCE: LaserJet 3600n Printer: how can i fix 59.C0 printer error hp lj 3600...
i have many times working on this printer and i always experience this problem...i think this problem is disalignment of the main gear...check the gear if its on the alignment and its work for me and the problem never comes back
Posted on Oct 19, 2010
seeker5211
  • 1089 Answers
SOURCE: Problem Error Code 59.FO For HP Color LaserJet
If you haven't taken your printer apart, somehow the "cams" in the developer drive assembly worked their way out of alignment.
Somebody trained is going to have to align and calibrate the main drive assembly.
Posted on Mar 05, 2011
My printer hp color laserjet displays a printer error 57.07 i need to a process to clear the code
Try looking up that specific error code and it should tell you what you need to do.
Dec 28, 2014 | HP Color Laserjet 5550 5550n 5550dn...
No carriage jam fix
Error message what you are mentioned no way related to clj5550 printer., chk once exact error
Sep 30, 2014 | HP LaserJet 5550dtn Printer
Error code 55.4k
This error 55.4k appeared in printer hp color laserjet 5550. The following trouble shooting did. Orignally my printer fault is display blank.Then i replace dc board with formatter board. blank is gone dueto new ram.Machine display showed the memory process. but immediatly the error 55.4k appeared on display.The reason for this error is, communication failure between formatter and dc board.The dc board which i was replaced by old type one.Then i found exact same dc board, replaced. Error was gone.Machine came to normal status , working fine.
Oct 01, 2013 | HP LaserJet 5550dtn Printer
Getting service error 49.4C02 from hp color laserjet 5550dtn frequently. Cancelling printing jobs from server and restarting the printer solves the issue temporarily but arises again again the next...
1st thing to do is upgrade the firmware. 49.XXXX errors are almost always firmware problems. Go to www.hp.com/support Answer the questions and then download the firmware. Please pay careful attention to the directions that are given. Problem could also be the application that you are printing from. Or a bad formatter. The firmware is the cheapest place to start.
Sep 07, 2011 | HP LaserJet 5550dtn Printer
I keep getting an error message that says "standard out put full remove all paper from bin"
the flag from the exit paper sensor is blocked or the sensor is not in place.
Call for a tech to resolve your problem.
Nov 18, 2010 | HP LaserJet 5550dtn Printer
LaserJet 5550dtn Printer: blows mains fuse and power supply board fuse and b...
The fuse blows all time on High Voltage Poewr Supply, on HP Color Laserjet 5550dn,
May 16, 2010 | HP LaserJet 5550dtn Printer
HP LaserJet 5550DTN jams at transfer unit
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 06, 2009 | HP LaserJet 5500dtn Color Printer
Laser Jet 5550DTN printing problem
I am reading your question and coming up with 2 different thoughts.
Are you wanting multiple prints of one page, or are you wanting to print out a 5 or 10 page document?
I am not sure how to answer.
Feb 29, 2008 | HP LaserJet 5550dtn Printer
HP LaserJet 5550dtn Printer Logo
2,891 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
