Question about Paradyne (6211-A2-200) Router
I want configration router Paradyne model : 6211-A2-302
SOURCE: 6381-A3-302,6211-I1-300 Paradyne ADSL 2+/Bridge Router
Admin/Admin default id and password
Posted on Mar 06, 2008
ayamaya
  • 143 Answers
SOURCE: configuring paradyne 6211 adsl2
i assume that the physical conenction of the modem to the computer is ok. if so,
- you need to access the modem's setup page by entering http://192.168.1.1 on your web browser's address bar. the default username is "user" and the default password if :admin"
- click on "device info" and select "quick setup", you can check the box "DSL Auto-connect" that will automatically detect your PVC (vpi & vci) but if you already knew these info, you can just enter it on the screen and click on "next"
- then go to "advanced setup", select "wan"
- if you don't have any "wan setup", you can click on "add" but if you do have one, you can just click on "edit" if it's not the correct internet settings
- then it'll promt you to select more settings like the "vpi" and the "vci", the "service category" (note: for the service category, you can select "UBR w/o PCR" but to make sure that it's the correct setting, you can ask your ISP). click on "next"
- select now "pppoa" or "power over atm"
- then select "vc/mux" for the "encapsulation mode"
- then click on "next", then click on "finish" to save the settings
hope this'll help you.
ciao!
Posted on Jun 19, 2008
SOURCE: Bridged Mode
Verify this with your ISP, but if you go into your modem settings, click on "Advanced Setup", click on WAN, when page opens, click "Edit". After clicking "Next", you come to the page labelled, "Connection Type". It is there you select what mode you'd like it to work in. When you are through selecting click NEXT till you get to the page with the SAVE button. Click Save and wait for page with FINISH to come up. Click FINISH and wait for the router to reboot(2 mins). Please write down the previous settings so you'll be able to undo whatever you do.
Posted on Jul 19, 2008
SOURCE: My Zhone 6211-I2-302 is not listed on port forwarding router list
I have a Problem in opening port 81 :(
how can i open it
Posted on Aug 07, 2009
SOURCE: what is the username and password for paradyne adsl2+ 6211-A3-304
The default username is Admin and the password is Admin. Both are case sensitive
Posted on Sep 04, 2009
Ok, I have a Zhone 6211-I3-200 Bridge/Router or in other words a Paradyne ADSL CPE, and I cannot for the life of me get it to work with my Xbox 360. I used to have a different router and I would switch...
Zhone Modem Model #. 6211-13-200-0PA ADSL2 BRIDGE/ROUTER, AN.
I would like to upgrade current Firmware, but it is quite difficult and my ISP support even knows how to do this upgrade.
Nov 06, 2011 | Zhone 6211-I3-200 Router
I lost cd of router paradyne 6211 1 port so i can't use usb of this router,my operating system is win7 x64 i need the driver for this router
Best way is to go buy a CAT5 Ethernet cable and don't use the USB at all. You don't need driver to use that cable.
Jun 23, 2011 | Paradyne 6211 ADSL2+ Router (6211I1200)
Is there UPNP option to enabel it in paradyne routers? i cant find any related options when configuring the router
It seems that the Model doen't have a direct option to configure UPNP. However you can refer the following articles which might help you out
http://www.grc.com/unpnp/unpnp.htm
http://www.zhone.com/support/manuals/docs/62/6211-A2-ZB21-40.pdf
Please let me know whether the above articles helped you..
Thank you
Dec 06, 2010 | Paradyne 6211 ADSL2+ Router (6211I1200)
Can the Paradyne 6211 ADSL2+ modem support internet speeds of 6Mbps. My carrier is saying I need a new modem for this speed.
ADSL2+ (aka ITU G.992.5) Is a standard that notable for its theoretical max download speed of 24 Mbps. Your carrier is mistaken. Howevver, perhaps they are claiming this because the speed is available on their end and there is a setting in your router causing the low speeds. There also could be high noise on your lines. Your router has a BER test that will tell you statistics about your line. Report that figure as well as your signal to noise ratio to your carrier to see if that changes their opinion.
Nov 28, 2010 | Paradyne 6211 ADSL2+ Router (6211I1200)
Unable to use admin username remotely
Most routers do not allow admin access from their WAN (public) side due to security concerns. Many routers allow you to enable this service from their browser-based configuration screens, but the 6211 does not. However, you can access advanced commands by logging into the router with telnet (from the LAN side) instead of a browser. The "remoteaccess" command allows you to turn on the feature you desire.
Full instructions for the command-line interface are here:6211-I1 ADSL2+ Router Command Line Interface User's Guide
You may need to upgrade your firmware to 3.00.22: Zhone/Paradyne Firmware - TSTT Forum
Dec 14, 2009 | Paradyne 6211 ADSL2+ Router (6211I1200)
What is the username and password for paradyne adsl2+ 6211-A3-304
Sep 01, 2009 | Paradyne (6211-A2-200) Router
What is the default user name and password for this paradyne modem?
By default both the username and password are admin.
Good luck and if you have any more questions, just come back here and leave a comment - I'm happy to help.
Apr 20, 2009 | Paradyne (6211-A2-200) Router
How do i disable the firewall on the router ?
have a thopson wireless modem model 782 cant disable the firewall so i can use bitcomet
Jun 04, 2008 | Paradyne (6211-A1-200) Router
No Advanced setting
Ok.... so i fixed my own issue...
All it needed was a Firmware Update.
No thanks to your site.. :P
Mar 07, 2008 | Paradyne (6211-A2-200) Router
Bridged Mode
Mar 04, 2008 | Paradyne 6211 ADSL2+ Router (6211I1200)
Paradyne (6211-A2-200) Router Logo
196 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
