Question about Sharp 21B-S10 21" TV
BLOWING FUSE , THE IX1791CE IS SHORTED - Sharp 21B-S10 21" TV
  • 30 Answers
Mostly this problem cause opto coupler is short. change the opto coupler and related parts like transistors,zener diode.and check all diodes&capacitors is power supply. you find any leaky or damaged part change it.
thank you
Posted on Oct 08, 2010
Cadilac srx 2005 blowing even coil fuse 15a everytime you turn the switch on
That fuse also powers the even fuel injectors .
EVEN COILS Fuse
15A
Even Ignition Coils and Even Fuel Injectors.
I would tell you to disconnect the fuel injectors an install a new fuse to see it blows then , if not shorted injector . If still blows then disconnect all the even coils an install a new fuse , if it doesn't blow then hook up coils one at a time till it blows ! Shorted coil same for the injectors . If the fuse still blows with all the coils an injectors disconnected , there is a short in the main B+ circuit for those components .
Could
Aug 06, 2016 | Cars & Trucks
Could a 1000 amp battery blow fuses in a 1999 blazer
Likely there is a blown fuse but a battery won't blow a fuse on its own. Change any blown fuses and if that fixes the issue and the fuse doesn't blow for awhile then your ok but if the fuse blows quickly then you have an issue with the electrical system and you need to take it to a shop
Apr 17, 2014 | 1999 Chevrolet Blazer
2005 chevy cobalt blowing injector fuse
Possibly a shorted injector, or a short in the wiring. Pull off all injector connectors from the injectors, put a new fuse in, and turn the key to on. If the fuse blows, look for a short in the power wire going to the injectors. If fuse doesn't blow, reconnect one injector at a time (key still on). If one of the injectors being connected blows the fuse-that is your shorted injector. Have to replace it. Good luck.
Nov 03, 2012 | Cars & Trucks
For 2004 ford truck f150 extended cab, I found the horn fuse, where is the horn relay?
disconnect the horn or horns, operate the horn and see if the fuse still blows. if the fuse still blows then there is most likely a short in the wiring. relays rarely cause shorts. if the fuse doesnt blow with the horn disconnected, reconnect the horn and operate the horn again, if the fuse blows you have a shorted horn.
Jul 14, 2012 | 2004 Ford F150
01 kia rio keeps blowing the injector fuse every time i put it in first and take off how do i fix it
You may have a shortted injector. Pull all the injector connections off, put a new fuse in. If it still blows the fuse, you must have a short in the injector drive circuit from the ignition switch to the injectors. I don't know what all is in the circuit, but you may have a resistor pack before the current reaches the injectors
If the fuse did not blow, then one at a time, reconnect the injectors. You are looking for a shorted injector that blows the fuse. If the first connection blew the fuse, disconnect that one, put in a new fuse, and start with a different injector connector. You may find one that blows the fuse, meaning it is shorted, and needs replacing.
Good luck.
Apr 08, 2012 | 2001 Kia Rio
I have a 1990 Chevrolet C2500 Pickup. It keeps blowing the ECM fuse. Its not the ecm, its not the fuel pump, its not the fruel pump relay. What else could blow the ECM fuse?. There is no visual evidence of...
if it is the ecm b fuse thats blowing i would try disconnecting your oil sending unit and see if it still blows the fuse.i have seen the sending unit short out internally before and blow the fuse.if it is the ecm 1 fuse it is either a chaffed wire or one of your injectors shorted.
Feb 09, 2011 | 1989 Chevrolet C2500
OVEN BLOWS FUSE EVERYTIME I TURN IT ON
the fuse blows only when there is a short and it is overloaded, so check it for shorts before replacing the fuse and turning it on!! once the short is cleared the fuse will not blow!!
reply and rate!
Jul 20, 2010 | Kenmore Microwave Ovens
Fuel pump fuse keeps blowing?The fuse is by the right front of radiator.
FUEL PUMP WIRES HAS A SHORT OR FUEL PUMP BAD SHORTING OUT.BLOWING FUSE.CHECK FOR SHORT AT FUSE BOX AND AT THE FUEL PUMP WIRES.THE PCM GOES BAD SOMETIMES IT WILL SHORT OUT BLOW FUSE TO FUEL PUMP.
Apr 14, 2010 | 1992 Oldsmobile Cutlass Ciera
Fuse
after blowing the fuse?..what happened next?...did you replaced the fuse and it start running again or if you replaced the fuse, it will blow again?
if it is always blowing the fuse, you may have a shorted diode in between the high voltage capacitor. you could remove that just to test if the fuse would no longer blow and if it would heat.
if it did not blow anymore and it did heat the ffod or water, then you all need to raplace that diode between the high voltage capacitor.
if the fuse did not blow anymore and it is still not heating the food , then you might have a faulty magnetron.
if it still blow your fuse then you could have a shorted magnetron, a shorted diode which is the one from the capacitor to the ground( this is anothere diode besides the one installed between the terminals of the high voltage capacitor) ( don't interchange them, they have different puposes..) or shorted capacitor also.
use a regular ohmeter to test each part...
i hope you can solve your problem with these instructions....
good luck,
drcool
Aug 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
RCA big screen tv
whenever fuse blows every time it is the indication of short circuit in tv. so please do not put fuse unless you know the cause of blowing fuse. these are the reasons of blowing fuse. 1 main filter cap.short. 2 rectifier diode short. 3 swithing transistor short 4 horizontal output transistor short 5 caps & diodes connected to flyback transformer short. 6 print short. 7 at last if every thing ok then flyback transformer defective. hope this will help. if you are not a tech person call skilled tech to fix it. good luck
Sep 24, 2007 | RCA P60828 TV
Sharp 21B-S10 21" TV Logo
323 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
