Question about Acer Aspire 1640Z Notebook
When I switch my acer1640z the little envelope light flashes and goes out.If I hold down the start button the envelope continually flashes.Take my finger off and it stops.It wont fire up at all.Thanks Martin
  • 58 Answers
You should reinsert your RAM. Its may be RAM problem. Okay just try...it
Posted on Sep 03, 2010
Dell photo 966 streaked copies
Turn off the printer and open its front cover.
Press and hold the "Continue" button. While holding it down, turn the printer on. The power LED light will now start flashing. Once it stops flashing, release the "Continue" button and close the front cover.
Press the "Cancel" button four times in a row.
Press and hold the "Continue" button. The front panel lights will now start flashing. When they stop, release the button.
Turn the printer off and then turn it on again
Mercedes Custom Parts
Jun 06, 2012 | Dell Photo 966 All In One Print Copy Fax
My epson tx700 printer dispaly ink pad at end of life and printer not start
A fix from a forum:
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Apr 25, 2011 | Epson Printer
The ink pads are at the end if their service life.
Depending on what type of printer you have:
Procedure 2
Mar 13, 2011 | Epson Office Equipment & Supplies
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
Lock light stays on
It sounds like the circuit bontrol board is cracked or shorted, which means it must be replaced.
Jul 24, 2009 | Kenmore 15762 Dishwasher
Machine flashing load paper message even though paper is loaded
Hi ...
Most of the time this problem comes when the paper is not loaded correctly. Follow the below instructions to load papers to the cassette and I am sure this will resolve your problem. I will keep monitoring your responce and if required, i'll look for a work arround.
Follow this procedure to load paper / envelope in the cassette:
  1. Pull out the cassette from the machine.
  2. Remove the cover from the cassette.
  3. Fan out the sheets of paper so that they do not stick together.
  4. Align the edges of the paper.
  5. If the cassette is not yet extended, use your thumb to press the tab (indicated by the pink circular outline) and release the latch.
  6. After the latch is released, remove your thumb from the tab. Then extend the cassette until a click is heard.
  7. Load paper on the upper-right corner of the cassette with the print side facing down.
    Note:
    * Since the Credit Card sized paper, Canon Photo Stickers, and Legal sized paper cannot be fed from the cassette, load them in the auto sheet feeder (ASF).
    * When loading A5 or larger sized paper (nonstandard-size paper: 203mm / 8inches or more in length), extend the cassette by pinching the tab.
  8. Grasp the paper guide (A) and align it to the long edge of the envelope stack (2). Align the front edge of the paper stack in the same way (3).
  9. Close the lid and push the cassette all the way into the printer.
  10. Press the <Open> button and pull out the extension completely.
  11. Press the <Feed Switch> button to turn on the Cassette light.
    *MP500 shown.
    Note:
    If the Auto Sheet Feeder lamp lights, press the Feed Switch button to light the Cassette lamp.
    If the Cassette lamp does not light even after pressing the Feed Switch button, Paper Source in the printer driver may be set to the setting other than the Feed Switch button.
Loading on envelopes
Paper Type
Precaution
Envelope (DL / #10 )
Set paper with the flap closed.
  1. Press down firmly on the edges of the envelopes to make the folds crisp. Also, press firmly on the area that corresponds to the edges of the back flap.
  2. Remove any curling by holding the edges diagonally and bending them gently.
  3. If the edges of the envelope are inflated or are curling, place the envelope on a flat surface. With a pen, press down while moving it from the center toward the edges of the envelope.
  4. Ensure that no curl or puff exceeds 1/8 in. (3 mm).
  5. Load envelopes in the cassette with the print side facing down and the flap towards the left.
  6. Close the lid and push the cassette all the way into the printer.
  7. Press the <Open> button and pull out the extension completely.
  8. Press the <Feed Switch> button to turn on the Cassette light.
    Note:
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Replaced drum on Dell 1720dn printer. Where is
This should fix the drum light being on that 1720
Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
May 13, 2009 | Dell 1720dn Laser Printer
Trying to pair BT150 but it won't go into pairing mode
I had the same problem. The many instructions available don't have quite the right details. This worked for me:
1. Turn off the BT150 by holding down the answer button about 5 sec. until the blue light goes off and is not flashing.
2. Turn on the BT150 by holding down the answer button about 5 sec. until the blue light flashes.
3. Keep holding the answer button, and press and hold the volume + button for another 5 sec. until the blue light comes on solid.
Nov 12, 2008 | Jabra BT150 Wireless Headset
Acer Aspire 1640Z Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
