Question about Aiwa Audio Players & Recorders
Good afternoon. i am inquiring if anybody who knows what is the small long wire with a small plug which is bundled along with the rca cords, power cord and ground wire? i am wondering what is its purpose or function since i have no idea cuz i just bought it less than a month ago. the one i got it from does not also know what it is...thanks edward
    Sergeant:
  • 357 Answers
Not seen one of these decks before. If it already has a mains lead an two phono plugs (red and white) this extra one would be a GRND (ground/earth) cable. If it has no power supply, this will be the "remote" power supply cord. This means it has to be attached to the right unit in order to gain it's power supply. Don't just bung a mains plug on this and plug it in as you will blow it sky high.
Posted on Sep 03, 2010
Testimonial: "thanks a lot"
Replace burnt power cable
You can replace it with the average extension cord as most can hold up to 12 amps and your freezer will pull 2-5. Just cut the extension cord to length and cut before where the wires are burnt out. Strip wires and connect black to black, white to white and green to green. Marrett each section of wires and plug it in. If you use electrical tape to make a bundle with the Marretts afterwards that will make sure there is less of a chance the Marretts will fall off.
good luck
Apr 06, 2014 | Freezers
Wiring diagram
Are the wires still bundled or loose?
If bundled, there are 3 connections to the motor and they make an L shape (sort of). place the motor in front of you so that 2 connectors are on the left and the last is at bottom right. The thermocoupler attaches to the bottom right, usually black or orange wire with the metal device on it. The upper left is usually a 2 white wires clipped together from the power cord and the short junction to the light bulb. The lower left is for connecting the short wire for the bulb to the black wires in the light bulb harness. Just go counter clockwise: Power, light, thermocoupler and you should be in good shape.
Nov 06, 2013 | Hoover U6616-900 WindTunnel Bagless...
1.sounds making noise that comes along with the engine tune? 2.my mono amplifier got burned during installation, is this possible for repair?
keep the rca cords away from your power wires( +) and the remote lead. The rca cords have a tendency to pick up and reproduce alternator noise if you run them too close together. Generally you should run them on opposite sides of the car when wiring. hope that helps.
Dec 11, 2010 | Rockford Fosgate Punch P5002 Car Audio...
What wires are what?!
The device has several sets of wires for different functions explained briefly.
1. The first bundle of wires make connectivity to the vehicle possible. For example, the bundle of wires are recogniseable by the color demarkation explained. The Red & yellow cable provide power requiring conection to the vehicle;s electrical system, batteries or alternator cables found in engine or under dashboard.b. The black wire is a supply current output requird to dispense an overflow of electrical charges from the battery setup process and is always connected to the botton framework of the vehicle. Every additional wires belonging to the first bundle being discussed are audio video connectivity wires. for example, depending on the number of speaker outputs on the vehicle out require connectivity with attempt to distribute sounds througout the audio speakers located along the doors and at back passenger area of the vehicle.
2. The audio system would have an additional bundle of wires similar as the power supply bundle aready provided to make possible current flow from vehicle battery to audio device. The second bundle of wires are called RCA adator cable kits that only would be required in the situation where the vehicle is required to be installed with additional features of amplifiers,, woofers and radio communication systems. The RCA bundle of cables are simple wrapped up by electrical scotch tape and snapped in safe place after installing the music system requiring least functionality than radio and CD player mode.
3. the additional bundles of cables/RCA becomes handy and by connectivity is as simples as inserting a cable into a similar receiver cable from provided with the new device to be acquire separaly.
4. Remember; RCA cables are symbolised for functiona s well, where red and yellow cables are video signals and white and several other coloured wires are audio and sound connectability cables to another device acquired later.
Important notes
Connecting the audio system is all performed by snapping open the radio video area of the dashboard area for access to the aready installed vehicle wiring kits.
All multi colored wires on the power supply kit are electrical
All additional wires are audio and video output and input connection capable
DVD player installation diagnostics are accheivable by refering to the user guide package,
also,
Dec 02, 2010 | Boss AUDIO SYSTEMS BV7300 Car DVD Player
Rca hd56w66 no power not even the green light power board looks good suggestions to find the problem?
Check the fuse. Its located on the right side looking in the rear of the TV its the small board where the power cord plugs into. The fuse is on that board.
Jan 01, 2010 | RCA HD56W66 56" HDTV
Do 2006 f 150 come with block heater
Only as an option. If your truck has one it shoud be
down in front of the engine,wrapped into small bundle if it has never been used.
Dec 31, 2009 | 2006 Ford F-150
Good afternoon, Ihave a viewsonic va702 17" monitor and would like to use as a receiver monitor for sky in my motorhome, is this possible and what would i require. regards Rosco
The ultimate would be a satellite dish. Also, If you know where the broadcast stations are near-by then you can get a small outside or rabbit ear antenna along with the hd converter box that has RCA jacks for video output then your all set to go.
Oct 09, 2009 | ViewSonic N4280P TV
RCA TV F31317 - can't turn power on - suddenly, it stopped workin
just follow the power cord where it goes into the tv and there is a small glass fuse right there,check to see if the small wire inside it is burnt out or if the fuse appears to be white or black inside.
Dec 01, 2008 | RCA F31317 31" TV
Rca
these are you convergence sensor wires.....why they disconnected? has the screen been remove... what this will do is disable autoconvergence sensors...there should be along two wire bundle that runs under the screen behind the screen through past the lens into the back right in the middle into a bundle of wire. the plug should be there somewhere.. look around for it
Mar 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
WONT POWER ON when plugged into a known good power source
This is from the FAQ on a similar model (the 770). My guess is that it won't be much help, but who knows... : The machine is not receiving a power signal. Make sure the power cord is plugged securely to the power outlet. If a surge protector or an extension cord is being used, disconnect them and plug the fax machine's power cord directly to the power outlet. If the fax machine is still not receiving a power signal, try plugging the machine's power cord into a different outlet on another circuit breaker. Good luck
May 19, 2006 | Brother IntelliFAX 775 Plain Paper Thermal...
217 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
