Question about NEC MultiSync FE700 17" CRT Monitor
Hi,please if you can help me.I have NEC MyltiSync FE 1250 monitor.It stoped working when is connected to desktop,it has light on but the screen is blank.I've connected it to laptop and it works fine but with desktop not.Please help
  • NEC Master
  • 32,281 Answers
You have proved the monitor is OK.
If the desktop appears to boot up then the most likely problem could be a faulty video card OR the video card setting has been changed that is outside the range of the monitor's capabilities, ie, the refresh rate set too high (set it to 85Hz or less) or the screen resolution is set too high (set it to 1024x768).
You may need to connect a different monitor to the desktop to get a display to lower the video settings.
Posted on Sep 03, 2010
Why did my screen turn light blue lcd1712 ?
Please try to connect your computer to a different monitor. It may be that you're experiencing the notorious "blue screen of death", but you will be able to determine whether that's the case by trying another monitor. Please keep me posted. Thanks!
Aug 06, 2014 | NEC LCD1712 17" Flat Panel LCD Monitor
My NEC Versa 6300 Laptop screen lights momentarily to show the NEC logo on a white background and then goes black. It has even flashed on the desktop for a few seconds before going black. I can connect to...
i would try a new cable before i say it is the screen and you may want to unplug cable from back of screen and make sure it has a good connection there as i have found reseating them has helped on quite a few
Aug 18, 2013 | NEC Computers & Internet
I have a NEC AccuSync LCD5V monitor and the picture on the screen will not extend over the whole screen....the right side has the picture re starting by about an inch
Windows 7 & Vista:
Right Click on your desktop and go to Personalization. Click on Desktop Background at the Bottom of the screen. On the Picture Position drop down menu, click Stretch and save changes.
Windows XP:
Right Click on the Desktop and click Properties. Go to the Desktop Tab. Select stretch from the drop down menu. Apply.
Please Rate my answer. Thank you.
Apr 19, 2011 | NEC AccuSync LCD5V-bk (Black) 15 in. Flat...
I want to use my lcd tv as a monitor for my NEC VERSA E6200.How do i set this up. I have already connected the cords and then turned in the tv and laptop and this hasnt worked. Please help Eddie
When you are on the desktop screen, Right click your mouse, Display properties will open. click on settings. Now click advanced. Then click displays.
Most chances are that you will see 3 options. Monitor, Panel and TV. click on TV. Click ok. Check whether your TV is getting connected. Once this is working properly, come back and on the scheme, you can select "Switch amongst displays" click Ok . Hope this helps.
Jan 30, 2010 | Computers & Internet
I have a nec LCD2070nx Power light is on
Hi:
Your monitor has a problem on its inverter board. It is an electronic component failure, and often it cost's more to fix it than to buy a new LCD monitor .
Nov 23, 2009 | NEC AccuSync LCD71VM 17" LCD Monitor
Distorted shrunken picture
hi
reduce the resolution to a bit lower and the refresh rate to a nominal 60hz and things should get back to normal
my hunch is u r using a slightly high resolution and refresh rates
but before that try the buttons on the monitor to see if expanding the image sideways or top and bottom would help initially
cheers
pls rate if this was any help
Mar 31, 2009 | NEC MultiSync FE700 17" CRT Monitor
NEC monitor drvier please !!
if you monitor turn on then not problem with monitor. it's related with your computer.
and what does it do when turning it on?
need more info for exact answer.
Mar 25, 2009 | NEC MultiSync FE991SB 19" CRT Monitor
Boot problem
It's maybe because of your bios battery are weak, change it with a new one 3volt cr2032, hopefully this could help
Dec 22, 2007 | NEC PowerMate 2000 PC Desktop
NEC MultiSync FE700 17" CRT Monitor Logo
133 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
