Question about Altec Lansing VS3251 Speaker
Does these work with laptops?
Do these speakers work with laptops, if so how do you set them up, and where do they plug into?
  • Skullhunter May 11, 2008
    Does sound come out of all speakers???
    PS- I dont have this speakers yet.
  • samcherukuri May 11, 2010
    need clarity for functioning of 5.1 channel
  • 58 Answers
Try the headphone jack, this should work just fine. I used this type of speaker on this laptop that i am running for many months via the headphone jack
Posted on May 11, 2008
Headphone jack not working on dell d810
You may need to go into the sound properties and then to deviceto change the settings to enable the speakers and change it from headphones to speakers.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Feb 04, 2013 | Dell Latitude D810 PC Notebook
Headphone jack not functioning properly
This is the normal way for this laptop ..leave it always with the headphones on selected in that list ..cause if the main speakers don't work well there is no point in using them ..This way you will run whatever yo will plug in ..speakers or headphones..The only setting difference in headphones and stereo out that for headphones will but the speakers of the laptop when plugged in ..This way it will even help you if the speakers are making weird noises cause they are damaged ..
Dec 22, 2011 | Computers & Internet
My Z205 worked when I first got it, but now it won't work. I have plugged it into another laptop and it's fine. I have tried all ports but no luck. The light comes on the speaker top so I know that...
If your using windows 7 go to the volume control in the taskbar right click it and select playback devices then make sure the speakers are set as default by clicking the speakers and then click set as default.
May 17, 2011 | Logitech Laptop Speaker Z205 2 Speakers
One speake is not working
The sound MAY BE turned down to zero using the Windows sound program/Mixer . Go to START - CONTROL PANEL - HARDWARE AND SOUND - MANAGE AUDIO DEVICES - and double click on the speaker icon then check the BALANCE control it should be set a 100% for both left and right. Click CONFIGURE and TEST the speakers.
If that doesn't work you have either a bad plug (on the speakers or on the laptop) or one bad speaker or the plug is not fully inserted or the speakers a just incompatible with the laptop. You might test the speakers on another computer.
Jan 28, 2010 | Audio Players & Recorders
Have windows 7 on my new acer aspire 5517; trying to get external speakers (2 different kinds) to work. my generic usb speakers install and it shows they're working properly, but errors when trying to play...
what happens when you plug the speakers in the green port? You might want to try the other audio ports because on a few new computers i have seen the speakers have to be plugged in a different hole. also make sure the speakers are plugged up to the electric plug.
Dec 06, 2009 | Acer Aspire 5500 5570-2609 Laptop
Built in speakers not working
Are you using external speakers? or internal?
EXTERNAL SPEAKERS: If your are plugging speakers into your headphone jack and they dont play, but you plug headphones into the same port and they work fine.. then it is the external speakers.
INTERNAL SPEAKERS: But if you are using the speakers in the laptop, then your speakers are probably bad. Try some software settings, but probly just bad speakers. Could also be that the speaker cord inside the laptop came unplugged from the motherboard. In which case you would have to take the laptop apart and plug it back into the motherboard.
Good Luck.
Sep 08, 2009 | HP Compaq nx6115 Notebook
No sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
Aug 26, 2009 | Toshiba Dynadock Port Replicator, Docking...
I have purchased from Walmart 2.0 CH USB POWEREDSPEAKER SYSTEM.  UC-280.On plugging in the usb cable I get nothing from theToshbia laptop (running Vista).  The power light onthe speakers does...
Did you get a software CD with this speaker set? Check the box and ensure that it says it's compatible with Windows Vista. I'm not aware of any speaker sets that wouldn't be, but it's always a possibility.
Also, more importantly, plug in the speakers before turning the laptop on. Many powered speaker sets will not work if you plug them in while the system is on.
Apr 08, 2008 | Computers & Internet
Mulitmedia speaker and mic not working
If both are not working at the same time, its quite possible that you have plugged in the wrong cables. try interchanging the cables. That shud help
- Ranjit
Nov 27, 2007 | Computers & Internet
Altec Lansing VS3251 Speaker Logo
106 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
