Question about Ricoh Office Equipment & Supplies
Auto Restart and erorr sc 345 RICOH 2060 - Ricoh Office Equipment & Supplies
2 Suggested Answers
sir fixalot
  • 146 Answers
SOURCE: ricoh 2027 sc792 erorr code
This seems to be a finisher communication error. If you unit has a finisher on it check the connector.
Posted on May 26, 2008
Howe do i fix ricoh 2060 code sc342?
there are more possible solutions and cause of this error. First of all the sc code and the sign for no toner are connected. The sc code mean that is there is no toner in the developer hopper. First of all if this code appeared after you replaced the developer, you will need did you connected the two connectors that connect the developer unit with the machine, and also check do the developer unit is properly inserted into the machine. But if this problem ocured before you replaced the developer, than the problem is with the toner holder. Open the front door and check the white hook that pulls out the toner bottle cap when the bottle is home position. This white hook is located on the back of the toner bottle holder. you will notice it when you pull the bottle from 90 degrees angle into home position how it slides on the metal rail located next to the toner bottle holder on the right corner of the machine. If it is broken or out of position than that is the problem. If this part is ok that open the front door and put something like a screwdriver in the upper taster that detects do the front door is closed its located above the red main switch, you will notice a hole with a bronze colored plate inside. The other switch is located on the front right bottom corner next to the third paper tray, you will notice a hole in the olive-brown color plastic. When you will insert something into this two holes the machine will think that the front door is closed and it start the toner loading process. While the machine run, with the door open notice do the toner bottle rotates.If does not rotate than the motor that rotate the bottle is not working. If non of this help than tell me and i will tell you other possible solutions.
Mar 06, 2015 | Ricoh Toner for Aficio 1060, 1075, 2051,...
When copier complits one job it remains on please wait all the time. no sc nomber shown
hi there,replace the potensial sensor in the drum unit.its the silver one which sit inside,on top.
Nov 12, 2014 | Ricoh Aficio 2060 Lower Fuser Pressure...
Erorr problem code sc 336
No such error code. There is a 363. That is for a bad yellow developer unit.
Sep 09, 2014 | Ricoh Aficio Mpc 3500 Color Copier
Ricoh Aficio Sg 3110Dn erorr code sc (20200)
Sometimes when you get an error on a printer you can just press the stop button or some have a clear button to get rid of the error code.
If that doesn't work, try unplugging the printer from the outlet for a few seconds then plug back in to reset the error code.
Dec 05, 2013 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
Sc 536 error code
Ol? tudo bem! o erro funcional (SC 536) trata-se de um cooler ou do sensor de temperatura que parou de funcionar levando o sistema a parar de funcionar por medida de seguran?a, infelizmente trata-se de um daqueles problemas que s? a autorizada resolve.
Jan 14, 2013 | Ricoh Toner for Aficio 1060, 1075, 2051,...
Sc 345 problem
you have a fuser code you need to have a tech come out and test the thermistor, lanp, and thermo fuse.
Sep 28, 2009 | Ricoh Office Equipment & Supplies
RICOH 2027 SC792 ERORR CODE
May 26, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
471 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
