Question about Acer Aspire 5600 Series 5630-6951 Laptop
Bios reset ACER 5600 Inadvertantly set bios to version for Vista after losing hard drive. Now I have only black screen on startup, no Bios on F2 and inability to boot. Any ideas on how to reset. Thanks
  • 1,031 Answers
Whats the bios manufacturer
Posted on May 26, 2008
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
Change the f12 boot menu on an acer t180
Press F2 to enter BIOS setup at startup. You can set which devices appear in the list from the boot menu.
http://johnbokma.com/mexit/2007/12/22/acer-aspire-phoenix-bios-boot-screen.jpg
Jan 20, 2013 | Acer Aspire™ T180 PC Desktop
I have an acer aspire 5536 G, it had windows vista on it. Now everytime i try to turn it on it says that there is no operating system found. what can i do to restore it?
An error of no operating system found, is often an indication of a failed hard disk drive (HDD) in the system (The hard disk drive is where all data including Windows is stored)
  1. If the system is equipped with a floppy diskette drive, remove the diskette from the floppy drive and reboot.
  2. Re-seat the hard disk drive. (From time to time due to expansion and contraction the HDD may lose contact and is no longer detected)
  3. Once re-seated, reset the BIOS defaults (normally F2 at boot) then there is normally a setting to reload defaults. Resetting default settings forces the BIOS to re-detect all peripherals connected to the system.
  4. If you still get that error at boot, then it is very likely the drive no longer is functional and will need to be replaced.
Aug 05, 2011 | Computers & Internet
I have an Acer Aspire 3680 and all i get is a black screen when i power up. it seems to get power, but nothing appears on the screen when you boot up. is it the graphics card or could it be a bigger issue?...
Do you hear any sounds?,.. see any LED lights? Do you see any way to know there is power to the laptop? Please provide more details so that you can get an answer that is somewhat accurate.
without any more information to go on,.. the problem could be motherboard, backlight, backlight inverter, power supply, dc power jack (in the laptop),.... and that is just the short list,.. Please provide more details to get a better answer
Feb 09, 2010 | Acer Aspire 3680 Laptop
Acer aspire one after starting my laptop it goes to a black screen and says check cable connection..! PXE-E63: Error while initializing the NIC PXE-MOF: Exiting Intel PXE ROM. No bootable device-- insert...
The computer can't see the hard drive for one of many reasons.
1. Hard drive failure
2. Bad connection between hard drive and motherboard.
3. BIOS corrupted
4. Motherboard failure of HDD control.
Press F2 when the ACER splash screen appears and go into BIOS set up.
The first page should show the hard drive name and ID number.
This may be missing or have corrupted characters in it.
Go along to the 'save and exit' and allow a restart. This sometimes kicks it into life.
Replace the hard drive with a known good one and check to see if this is recognised in the BIOS.
Clean the contacts of the hard drive.
ACER fitted both types of hard drive to this model, either PATA (IDE) or SATA.
Dec 28, 2009 | Acer Aspire 5100 Notebook
Can not boot up my acer aspire one note book?all i keep getting is a black screen and my curser.
i have this problem 2 days ago.. and this works on me... maybe on your's too
you may need to flash your bios. why need to flash the bios.. ? 1. had the black screen of death. or deleted the bios
how to flash the bios:
STEP 1.download the AA1 BIOS from this link:
http://www.acerpanam.com/synapse/data/7117/documents/AS1_BIOS_3309.zip
2. extract the file
3. rename the file 3309.fd to zg5ia32.fd
4. put zg5ia32.fd and FLASHIT.EXE onto the usb drive
now, start the process
STEP 2
A. make sure the power cable is in
B. the laptop is turned OFF
C. Plug the usb stick in!
STEP 3:
Press and HOLD down the FN and ESC key together
then press the power button, while holding the buttons
release the power button and continue holding FN and ESC for about 5 seconds
release the buttons and the power light will start to blink
let the laptop run and DO NOT PRESS anything this can take upto 8 mins
when it's done the laptop will restart.
this works on me... good luck.. and i hope it will help you.....
Jun 06, 2009 | Acer Aspire 4315 Notebook
How can I password-protect all files on my laptop?
Hi there.
You can set a bios and hard drive password either by using Acer Empowering Technology application or entering the bios itself by restarting the computer and hit F2 while its just starting up, make sure you keep your password safe because if you forget the the passwords you may find yourself locked out of your own computer and bios passwords are very hard to crack.
Good luck and thanks for using FixYa!!
May 13, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
VISTA uninstal
the first thing you have to do is go to acer support website to see if your model supports downgrade to XP, in other words XP drivers for the model you have, if it does get back to me for more help, if it doesn't your stuck with vista i'm affraid
kind regards
Nov 17, 2008 | ASUS Eee 4G Notebook
Resetting Bios
theres a couple of ways, you could try to solve this.
1:) remove the battery and power supply from the unit. and leave for 24 hours.
2:) find a repair or dismantling manual. locate the CMOS Battery. This is what stores The Date/Time settings et,c. ** Usually looks similar to a chrome watch/lithium battery** located on the motherboard.
3:) attempt to enter the systems bios, at startup. Pressing The F2/esc Or Delete Button. Set the boot sequence to first device CD/DVD Rom Drive. This will give you the chance to use a system restore CD, Or re-install windows.
Finally when you get your laptop up and running, i,d suggest installing Windows XP. Vista still has a lot of bugs and glitches.
mike @ compurepair.
May 13, 2008 | HP Presario C555nr Notebook
How to reset the bios of the Acer 5920?
you can reset the bios setting by removing the battery, you can also remove the jumper pin from the motherboard from pin1-2 to pin3-4 wait for 10sec then return to pin1-2
Jan 14, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5600 Series 5630-6951 Laptop Logo
131 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
