Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
Stalls after starting, the model is a Poulan po500n21rh mfg id 96132002201 , the choke in not responsive, the engine is a Briggs and Stratton 158cc motor
4 Suggested Answers
  • 149 Answers
SOURCE: New mower 158cc Briggs & Stratton engine April 2010
Um if its new take it back before you damage the govenor then its not warrenty!!
the springs are fine. the metal the the spring conects to on the throtle control sets the high speed. dont play with unless you know what your doing for every ones safety
Posted on Jul 02, 2010
  • 150 Answers
SOURCE: I have a briggs and
A champion cj 8 plug will work fine. As far as air filter it is probably a paper on, take the old one to a dealer or small engine repair shop and they can match it up for ya.
Posted on Oct 06, 2010
  • 111 Answers
SOURCE: my briggs and stratton 158cc
There is a tab on either side of the carburetor right where the primer bulb sits. You can depress both of these tabs with a screwdriver and pry out the plastic ring that holds the primer bulb in place. You can purchase a new primer bulb (with a new plastic tab) from a local mower shop or from a small engine repair shop. When you install the new primer bulb, put the rubber bulb in first then put the plastic ring on top and press it in until the tabs click on each side. It should work correctly after the tabs are clicked properly. You can take off the air filter and look into the carburetor to see if the unit is priming correctly. I hope this helps you out.
Posted on May 10, 2011
158cc briggs stratton carburetor diagram
one and half turn out to start then turn out or in fine tune it
Sep 02, 2014 | Poulan "Poulan" Push Mower
How do i idle down the engine or govern down the engine on a briggs and stratton 550 series mower model 10T802
that engine uses a fin style governor remove the upper cover and see if there is a nest or something holding the fins movement
Jul 12, 2012 | Briggs & Stratton Briggs Stratton...
I have just purchase a Sears 22 Lawm mower, with a Briggs and Stratton 158cc engine. I prime the motor it act like it wants to start but then dies. I pull it and try to strat it several more times and it...
The procedure for starting an engine is as follows:
  • Check that you have the throttle in the start position and/or on high revs with choke on
  • Prime the engine by pushing the button about 5 times
  • Pull out the cord until you meet resistance. Then let the cord go fully back into the engine and then pull the cord out sharply. Repeat this until the engine starts but not more than a few times.
  • If the engine doesn't start, try pressing the primer button another few times then try to pull start the engine
  • If the engine doesn't start after a few pulls it may have flooded so leave it for a few minutes before pulling the starter rope
Apr 30, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Jul 01, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Engine stops when I engage attachment,or travel clutch. I know it is electical but can not find the cause. Can someone Help? Poulan 38-Inch Steel Deck 15.5 HP Briggs & Stratton I/C Engine With 5 Speed...
Have a Poulan 27147 model 13.5 38"
Start the mower and release the clutch or brake whichever you call it and the mower will stop. Have replaced the switch and soleniod and it still stalls out. Any solution to this? Been looking for a manual for this model - only 10 yrs old - but no luck.
Jun 23, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
98 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
