Question about Fujitsu Heating & Cooling
Fujitsu Multi Split Inverter AOT30QMAM4 with: 2xAST9QMACW heads and one - AST12PMACW , - the last of which, (12PMA), has "Operating Lights" fast flashing and "Timer Light" flashing in bundles of four @ 0.5secs. at a time. The unit seems, nevertheless, to be working well. Problem started, as unit was off and is continuous. After being switched off at fuse box, the flashing stops, but re-commences immediately upon start. May I be informed of the cause and its rectification, please?
notsomot
  • 67 Answers
SOURCE: Fujitsu AOT30PMAL inverter outdoor unit not working
Sounds like your compressor is seized or a start fault. If the unit is under five years old it should be under warranty. Call Fujitsu warranty out to have a look at it for you.
Contact details as follows
http://www.fujitsugeneral.com.au/contact.php
Sorry but either way I think your going to need a part there is very little that I can do unless your in WA.
Hope this helps
Posted on Jan 11, 2009
  • 10 Answers
SOURCE: Fujitsu inverter air cond. just stopped working pr...
It sounds like your inverter is at fault. You will need an inverter tester ( most good service techs will have one ) to prove that the output to the compressor is correct. If the inverter is okay then it will be the compressor at fault with a location error or it is simply seized. A common fault that caused this was the eev remained closed (coil failure ) and caused the compressor to over heat.
Posted on Jul 15, 2010
technic_7117
  • 38 Answers
SOURCE: THE RED (OPERATION) LIGHT AND
replace the thermistor
Posted on Aug 16, 2010
justinbur167
  • 257 Answers
SOURCE: i have Fujitsu AOY36VMNB4 inverter multi split
EHello wgq66,
The in side unit is running and the outside unit is not.
This could be a of a few things things.
1. Power - check power
Check and rest beakers and fuses in the disconnect box. If good continue to next step.
2. contactor - the contactor tells the unit when to turn on.
Take the service panel off it is the little box with two big wire 220 volts (black
Posted on Mar 18, 2011
  • 11800 Answers
SOURCE: Fujitsu General ASHA09LAC Multi Inverter
Your split system is an inverter model. In it the compressor is powered not simply from the mains thru a relay but from a special and very complex set of converters: a rectifier to convert the incoming AC current to DC and then uses pulse-width modulation of the DC current within an inverter to produce AC current of a desired frequency to power the compressor.
In your case the unit that provided the final AC current to the compressor has failed. The fact this happened a few days after you have started using it is a clear indication of manufacturing defect - some of the electronic components used in that inverter were of a low quality and they haven't been able to cope with the stresses so they failed.
This is something that only the dealer (and its repair crew) can solve and it's covered by the warranty - time to call them. And in the mean time disconnect the unit from the mains.
Posted on Jun 03, 2011
FUJITSU Inverter wall mounted split air conditioner Model : AST12LSBCW not working, flashing lights
This is a "PFC circuit abnormal" in the outdoor unit meaning that the outdoor controller board is faulty. Try turning the machine off at the isolator switch for 10 mins, then back on to see if the error resets. If not you will need a new controller PCB.
Nov 15, 2016 | Fujitsu Heating & Cooling
We have fujitsu inverter plasma airconditioner mpdelastb09ldc ths fan runs but timer light blinks 3 times but outdoor does not start
Hi Rajneel,
I hope this link is of some help to you
Good luck
http://www.climatecenter.co.uk/wcsstore/ClimateCenter/Attachment/downloads/fujitsu-trouble.pdf
Feb 10, 2015 | Fujitsu Heating & Cooling
New LG mini split installation getting error CH05
I believe the wiring may be incorrect. Here arethe fault codes.
05
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
5
Hope this helps
Bob
Aug 08, 2014 | LG LA120HYV Art Cool Premier 120HYV Ultra...
What error is causing it to flash 2 x green and red then 5 x red?
This fault relates to a over current protection,
fault can be a number of things
connection failure (check power and connections)
outdoor fan failure (fan operating?)
outdoor coil dirty (is air passing through coil or is it clogged)
compressor failure (compressor operating?)
pcb and/or inverter PCB failure (is there power at boards or any visual damage)
Aug 14, 2012 | Fujitsu ASU36CLX1 HALCYON Mini Split Wall...
I have Fujitsu AOY36VMNB4 inverter multi split air conditioner, all the indoor unit are running normally, but no cool air come out, i found the outdoor compressor is not running, what is the problem?...
EHello wgq66,
Mar 18, 2011 | Fujitsu Heating & Cooling
I have an LG inverter split system which is coming up the error C5. What can I do to fix this problem?
Communications Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4.
Jan 06, 2011 | LG Heating & Cooling
My fujitsu inverter asta12jcc outside fan is not working. On the inside unit the operation light is on for a few seconds than the green timer light flashes every few seconds. but the fan inside is running.
Communication error between indoor to out door.Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Jan 02, 2011 | Heating & Cooling
LG split inverter model LSL122V3 and it doesn't cool and shuts down after a few minutes with the green led flashing five times repeating.
Communcation error between in and out.
Dec 31, 2010 | LG LSC121PMA Split System Air Conditioner
Have model ASTB24LDC/AOTS24LDC Inverter Fujitsu split system. As of Thursday 11th Nov, unit stopped working. Won't respond with remote. An electrician came to test it this morning, says there is power to...
I have same problem like yours to my newlyinstalled Fujitsu multi-split system (the first time use since system installed1 week ago). I rang the electrician whodid the installation; he said it must be the units themselves nothing to dowith electricity. Okay, then I rang Fujitsu and their local service agent. Theysuggested me to switch off C/B for an hour to reset the units. I followed theinstruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired tothe outdoor unit). So I used a multi-meter to test the power terminals of indoorunits (Danger! If you have no idea about this, don't even try! ): it seemed nopower supply even C/B is on. I turned to the isolator which next to the outdoorunit. The isolator was making arcing noise when I switched it on and off. Theindoor units suddenly turned on for few minutes then died again. So I figuredout the problem is that crooked isolator. I called the unhappy electricianto replace the isolator. End story....
I hope my experience will give a littlehelp to you...
Nov 13, 2010 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
95 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
