Question about Honeywell HY-048BP Tower Fan
Need cold air
MY AC WENT OUT AND I CAN'T FIGURE OUT HOW TO GET THIS FAN TO PUT OUT COLD AIR
  • itsfriginhot May 12, 2008
    It has a thermostat that lets you adjust the temperature you f**** a**hole!
  • Anonymous May 18, 2009
    temp wont go below 85 although it shows it can go to 60 ? wtf
I had the same problem...and I accidentally discovered the solution...
One thing you have to remember is that the temperature that is shown on the screen is actually the room temperature and not the "wind" temperature.
To set the "wind" temperature, press the "m" button (aka temp/timer) once...it should show a flashing thermostat and the temperature screen changes to show the default "wind" temperature (it's 74 degrees)...
Next use the "down" button to the right of the screen to reduce the wind temperature to the desired temperature and that's all you have to do. IMPORTANT: if you wish to increase or decrease the temperature of the "wind" you just use the "up" or "down" button; DO NOT HIT "m" again since if you hit "m" again, it will cycle through the "timer" and then "temp" again, and it will reset the "wind" temperature to the default 74 degrees.
Posted on Jun 11, 2008
Can you read #3? They never said it was an A/C, all that was stated is they could not get cold air to come out of the fan... which for your info, does have an option to shoot out cold air (not A/C). durrr!
Posted on Jul 21, 2009
With Nagtive Ion function, it could provide cold air from this fan!!!
Mr. Solution 2 seems do not know this!!!
Posted on Jul 17, 2008
Hahahahahahahaha
Posted on May 19, 2008
ARE YOU ******* KIDDING???? IT'S A FAN IDIOT! NOT AN AIR CONDITIONER! YOU NEED COLD AIR ON YOUR BRAIN! LOL
Posted on May 11, 2008
I put a new belt for the ac unit and connected it but i hear no sound or feel any air nothing is working. What can i do to fix it cause its cold at night. And hot in the day and i need it. 78 chev imp
In a 1978 Chevrolet Impala? The category you posted is home air conditioners.
Sounds like the fan has failed.
Heat comes from the radiator via the heater core and the air circulation fan. The radiator must be full of coolant.
Cold air comes from the air conditioner compressor via a clutch drive from the serpentine belt, sometimes a separate belt. Cold air comes from the evaporator element and the air is also forced by the air circulation fan.
First thing to do is find the fan body in the bulkhead and tap the back with the handle of a hammer. Sometimes the brushes stick. Then check the fuses.
Apr 29, 2016 | Chevrolet Impala Cars & Trucks
The defrost, heater and Ac all went out on my 1993 maxima.
If the blower worked, but couldn't get cold air, there may be a leak of refrigerant in the A/C system. If you're complaint is about the lack fan-forced air; that could be a problem with the fan speed switch or a bunch of other places. Most often however, it is the speed control resistor. Have a look at this thread to learn more about it:
Air conditioner fan switch only works on high Nissan Forums Nissan Forum
Nov 30, 2015 | AC Cars & Trucks
Bought the cavalier had no ac/ but has great fan blowing it's just hot, defrost everything runs normal mulitiple speed////recharged w r134 blew ice cold almost 3 months went out again slowly. Stopped at...
I,t sounds like you had a leak, and pulled air into the system. This calls for professional servicing. Whenever there's a leak in a refrigeration system, air and sometimes other noncondensables get pulled into the system. They don't belong there. They cause heat and high pressure in the condenser, and will eventually destroy the compressor. The system needs dehydration and evacuation before charging. That's after all leaks have been repaired.
Aug 26, 2013 | Heating & Cooling
'97 Jeep Grand Cherokee AC "Works and Stops"
Make sure your fan clutch is working. No fan, no cooling of the condenser, no heat dissipation, no cold air. Start the truck and make sure you feel air movement, a lot.
Aug 11, 2012 | Jeep Grand Cherokee Cars & Trucks
Ac turns on and the fan blows air but not cold air. When switching from fan to ac mode i hear a buzz sound like it had switch to ac but still its not blowing out cold air. Any suggestions?
mcdevito75, Needs service either a chrge of freon or the need for a new thermostat and That is what it sounds like to me, (the compressor could be bad also, the buzzing sound) hope not expensive repair.
Jun 23, 2010 | Amana PBC101A00A Air Conditioner
Heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
Heater blows cold, and fan switch only works on 4 and 5
working on 4 and 5 speed that the resistor that broken cold air you got to move the selector to see the motor that move the trap hot and cold sometime when the motor was not move to the hot side for a long time its jam the motor on the passager side under dash put to hot and gently tap the motor tanks pierre
Oct 24, 2008 | 2002 Chevrolet Malibu
Honeywell HY-048BP Tower Fan Logo
505 people viewed this question
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
ray gallant
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
