Question about HP LaserJet P1505n Printer
My printer is reporting the door open. i have tried all i can to resolve it. kindly help
  • 67 Answers
Remove the toner/cartridge and then unplug the power from the printer.. after about 10 seconds, replug the printer and insert the toner .. Now, ensure that the door is properly closed ..
Posted on Sep 03, 2010
I have an open door message on my hp 350 copier printer
Open the door, ensure there is no debris of any kind arount it and then shut it firmly. This may resolve the issue
Jun 10, 2015 | HP Deskjet 350 InkJet Printer
Samsung CLX-3185
Hi
Have you checked the cartridges access door?
If so,try disconnecting the printer and leaving it for a long period [like 1hr] before connecting again.
Feb 28, 2012 | Samsung CLX3185 AllInOne Laser Printer
Have been receiving a DOOR OPEN message when I try printing (usually after changing a printer cartridge on a HP C6180 Photosmart printer). There is no door open. The cartridges are properly seated, and...
Hi injkretz,
The "door open" message will only appear when the front door is open or if something is wrong with the sensor and sensor flag.
The door sensor is visible when the door is open -- located on the left side of the opening, just about an inch below a silver screw head. (kind of hard to describe where it is.) The sensor is a black horizontal bar. If you see it, try pressing it in with something thin like a paper clip. Press the sensor in about a 1/2". If the "door open" message goes away, then you know your sensor is good. Next look to see where the sensor flag is located on the back of the door. Again, it's on the left side toward the top of the door. The flag is simply a section of plastic that sticks out far enough to engage the sensor.
Hope this helps.
Thank you for using FixYa.
Jun 28, 2011 | HP Photosmart C6180 All-In-One InkJet...
Carriage jam message...........comes on no matter what.........reset several times
Solution one: Turn the All-in-One off and on again Turning the product off and then on again might resolve the issue. Step one: Turn the All-in-One off and on again
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Wait 60 seconds.
  3. Press the Power button (c01602202.gif ) to turn on the product
Step two: Print a self-test report
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01461502.gif ). The Setup menu opens.
  3. Press the arrow button to select Tools , and then press OK .
  4. Press the arrow button to select Self-Test Report , and then press OK . The self-test report prints.
  • If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting.
  • If the issue persists , continue with the next solution.
  • If the self-test report does not print , continue with the next solution.
Solution two: Clear any jammed paper Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the rear of the All-in-One Use the following steps to check for and remove jammed paper from the rear of the HP product.
  2. Disconnect the USB cable from the rear of the product.
  3. Disconnect the power cord from the rear of the product.
  4. Squeeze the tab on the rear access door to release it, and then pull the door outward to remove it from the product Figure 1: Open the rear access door
  5. Gently remove any jammed paper from the rollers inside the product. CAUTION: If the paper tears while removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.
  6. Reattach the rear access door. Gently push the door forward until it snaps into place.
Jun 21, 2011 | HP Photosmart C5280 Printer
Printer was working ok then error 0x610000f6 came up this comes up all the time
Follow the below mentioned steps to resolve the issue :
This error is usually due to Carriage Jam issue. 1) Power off 2) Unplug the power cable from the wall outlet (should always power off first using the power button). 3) Remove the back piece and putting it back, making sure it's well adjusted. 4) Also removed the piece where the printed paper land, and put it back. In case if this doesnt help follow the below mentioned steps : Print a self-test report : ollow these steps to print a self-test report. Press the Power button to turn the product on. Press and hold the Cancel button. Press the Red-eye Removal button. Solution one: Turn the printer off, and then turn it on Follow these steps to turn the product off and then to turn it on. Step one: Turn the printer off, and then turn it on Press the Power button to turn the product off. Wait 15 seconds. Press the Power button to turn the product on. Step two: Print a self-test report Print a self-test report. Refer to the section on how to use these solutions at the beginning of this document. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. Solution two: Clear all paper jams Follow these steps to clear any paper jams. Step one: Remove any loose paper 1. Disconnect the USB cable from the product. 2. Disconnect the power cord from the back of the product. 3. Remove all unused paper from the tray. Step two: Remove all paper from inside the back of the printer. From the back of the product, remove the rear access door or duplexer, and then remove any paper stuck inside of the product. Press the tab on the left side of the rear access door to release it, and then remove the door by pulling it away from the product. Gently pull any jammed paper out of the rollers.
If your product has a duplexer :
1. Remove the duplexer from the rear of the product and remove any paper or scraps of paper stuck inside of the product. 2. Open the duplexer and remove any paper or any other obstructions. 3. Close the duplexer. 4. Reinstall the rear access door or duplexer.
Step three: Remove jammed paper from the front of the printer. Remove the paper very carefully. If the paper tears, part of it might remain inside the paper path and damage the product. Carefully remove all traces of paper that you can find. Reconnect the power cord to the back of the product. Press the Power button to turn on the product. Open the carriage access door. The carriage might try to move into the access area. If so, allow it to move to that position.
With the product turned on, disconnect the power cord from the back of the product. Unplug the power cord from the power source or electrical outlet. Check for any paper or objects that might be stopping the carriage. Reach inside the product, and then manually move the carriage. If the carriage is stuck on the right side of the product , move the carriage to the left side of the product. If the carriage is stuck on the left side of the product , move the carriage to the right side of the product. If the carriage is stuck in the middle of the product , move the carriage to the right side of the product. Remove any loose paper or obstructions found. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Close the carriage access door. Reconnect the power cord to the product and to the power source. Reconnect the USB cable to the product. Load plain paper in the tray. Press the Power button to turn the product on. Step four: Print a self-test report If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. Solution three: Make sure that the cartridges are installed correctly Improper placement or installation of the cartridges can cause a carriage jam. Installing only one cartridge can also cause a carriage jam. Follow these steps to make sure that the cartridges are installed correctly: Step one: Remove the cartridges Press the Power button to turn on the product. Open the carriage access door. Press the tab on one cartridge to release it and then remove it from the slot. Repeat the previous steps to remove the other cartridges. Look under and around the carriage, and then remove any obstructions. Step two: Reinstall the cartridges 1 - Latch in down position Slide one cartridge into its slot with the matching icon, and then press it in until it snaps into place. Figure 9: Slide one cartridge into its slot and snap it into place
Repeat the previous steps to install the other cartridges. Close the carriage access door. Load plain paper in the tray. Figure 10: Load plain paper Step three: Print a self-test report Print a self-test report. Refer to the section on how to use these solutions at the beginning of this document. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. Solution four: Connect the printer directly to a wall outlet If the product is connected to a power strip or a surge protector, follow these steps to connect the product directly to a wall outlet. Step one: Connect the printer directly into a wall outlet Press the Power button to turn off the product. Disconnect the power cord from the back of the product. Disconnect the power cord from the power device. Plug the power cord directly into a wall outlet. Connect the power cord to the back of the product. Press the Power button to turn on the product. Try to print.
Print a self-test report. Refer to the section on how to use these solutions at the beginning of this document. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. Solution five: Perform a power reset. Follow these steps to reset the product. Step one: Perform a power reset Press the Power button to turn on the product. With the product turned on, disconnect the power cord from back of the product. Disconnect the power cord from the wall outlet. Wait at least 15 seconds. Connect the power cord into wall outlet. Connect the power cord to the back of the product. If the product does not turn on by itself, press the Power button ( ) to turn it on. Try to print. Step two: Print a self-test report. Print a self-test report. Refer to the section on how to use these solutions at the beginning of this document. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. If the self-test prints, then your carriage jam issue is resolved. Connect the USB cable to continue the print job. Step three: Search for more information If you detect another issue, go to the HP Product Support Home Page, and then search for another document that relates to the issue you are experiencing. Solution six: Service the product If you have completed all the preceding steps and are still experiencing a problem, service the product.
May 01, 2011 | HP Office Equipment & Supplies
I have a jam on my printer that says there is a print carriage access jam how do i solve it
I have the same problem.... trying to use lubricants and done some cleaning, but no luck... till i found out that using an extension cord with several devices plugged in will lessen the amount of current that flows to the devices.. that's why the printer's motor can't able to do his job because of no enough power.... Connect the printer's plug directly to the wall...
it works for me....
---ritchie---
Jan 13, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
New printer--------paper jam 8.5w x 3.5 inch paper in printer; cannot see it!!
Print a self-test report Use the following steps to print a self-test report.
  1. Load unused, plain, white paper in the tray.
  2. Press the Power button (c01602202.gif ) to turn on the product.
  3. Press the Setup button (c01438890.jpg ) on the control panel.
  4. Use the right arrow (c01185072.jpg ) to highlight Print Report , and then press OK .
  5. Use the right arrow (c01185072.jpg ) to highlight Self-Test Report , and then press OK . The self-test report prints.
c01733891.gif IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue.
CAUTION: Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product.
  1. Disconnect the USB cable from the rear of the product.
  2. Press the Power button (c01602202.gif ) to turn off the product.
  4. Remove the rear access door or the two-sided printing accessory (duplexer) from the rear of the product.
Jan 10, 2011 | HP Officejet 6500 Wireless All-in-One...
Printer error error code 3807
From the kodak website:
Error "System status failed" (3807)
How do I resolve the error message "System status failed" (error code 3807)?
To resolve the error message "System status failed" (error code 3807):
Disconnect the power adapter from the printer.
Wait 30 seconds to allow the printer to reset.
Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
Open the printer access door.
Remove and install the printhead two times.
Close the printer access door.
Wait until the printer is ready to use.
If the error is resolved, upgrade your printer's firmware.
If the error is not resolved, contact kodak.
Hope this helps
Jan 09, 2011 | Kodak ESP 5 Printer
My printer comes up with a clear paper jam and press checked key. I have cleared all paper from machine and yet the light flashes and will not allow me to print and the same error code comes up. What...
Solution one: Turn the All-in-One off and on again Follow these steps to turn the product on, and then off again, to reset the print mechanism.
  2. Wait 15 seconds.
  3. Press the Power button (c01602202.gif ) to turn the product on again.
    NOTE: The product might go through a warm-up period of up to two minutes. The product lights might flash and the carriage might move. Wait until the warm-up period is complete before proceeding.
  4. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again.
Solution two: Clear any paper jam Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper. Step one: Remove any loose paper Remove any loose paper from the input tray and output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear a paper jam from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the back of the All-in-One Use the following steps to check for and remove jammed paper from the back of the product.
  2. Disconnect the USB or Ethernet cable from the back of the product.
  3. Disconnect the power cord from the back of the product.
  4. Remove the rear door. Push the door latches toward each other, and then pull the door away from the product. Figure 1: Remove the rear door c00244379.gif Illustration of removing the rear door
  5. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.
  6. If you are printing labels, see if any are missing from the label sheet. If any labels are missing, find them inside the product, and then remove them carefully.
  7. Reattach the rear door. Gently push the door forward until it snaps into place.
Step three: Clear the paper jam from the front of the product Follow these steps to remove the paper jam from the front of the product.
  1. Open the cartridge access door. Figure 2: Open the cartridge access door c01913998.gif Illustration of opening the cartridge access door
  2. If you find paper jammed in the product that cannot be removed through the rear door, gently remove the paper through the front of the product.
    NOTE: Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism.
  3. Close the cartridge access door. Figure 3: Close the cartridge access door c01913999.gif Illustration of closing the cartridge access door
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01602202.gif ) to turn on the product.
  6. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Keep in this LINK.
Oct 26, 2010 | Dell 948 All-In-One InkJet Printer
I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this issue?
I am trying to print a label on the zebra 105SL but the font ...
www.fixya.com/support/t5406223-am_trying_print_label_zebra_105sl
Jul 11, 2010 - I am trying to print a label on the zebra 105SL but the font and the "text boxes" are printing too large like it is zoomed out - how do I resolve this ...
db:: 4.67::Crystal Report Label Won't Send To Zebra k9
www.hivmr.com/db/k99xad9dfspspddfs1scm9fzxxkdz9dj
My routine can print the label to any other laser printer, but the Zebra. ... I am tryingto find a way to print actual time a smartform label gets printed out on a zebra ... In this i want to changeCross Tab expert Row Label Font,Cross Tab expert ..... And labelpaper too. ..... DB:2.73:Zebra 105sl And Crystal Report Label Issues 1d.
db:: 5.16::Help My printer is printing in 3x5 documents and I ...
www.hivmr.com/db/xkzpajp81937ap7zdf87sdmsxmcm179m
DB:4.06:Printing 3x5 Continuous Feed Labels On Hp Officejet 6100 d8 ... Are they toosmall? ... I want to help you but I am not sure I can be of much help until I know what kind ... If the paper size is 3.5x5 but you are trying to print a 3x5 photo (which seems to be ...... I have a label format issue on a Zebra 105SL label printer.
db:: 4.15::Custom label sizes md - Hivmr
Jul 11, 2010 | Office Equipment & Supplies
HP LaserJet P1505n Printer Logo
159 people viewed this question
Seeker5211
Seeker5211
