Question about Panasonic DMR-EZ27K
Model No'DMR-ES15 - U61problem
U61-*Unit detected an error while recording or playing with no disc in the disc tray. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears* This is what the Operating manual tells me. The screen message is: Self Check did not complete. 1) Press ENTER. Then the unit opens the disc tray & turns to standby. (did this, great!) 2) Press POWER to restart. (did this too!) If this message still appears please refer to the contact info listed on the operating instructions. Unable to clear this message. Have followed the above steps a few times to no avail. Have turned the recorder off at the wall & then switched on. Still have message appearing. Would really appreciate any help you can offer. Cheers I had the same problem (a U61 error) on my DMR-EZ27. My recorder would repeatedly turn on and off while it sounded like the disk drive was stuck. After Panasonic's awful support desk merely suggested resetting the unit by pressing the up and down channel keys on the front until the clock blinked, I became frustrated. I found this site and took a suggestion below one step further. I took the lid off of the player then removed the four screws holding the drive down. After that I removed the three screws holding the drive together. It turns out that the disc was improperly inserted, causing the error. PLEASE be very careful while doing this. You could break the unit or ruin the lens. I am also sure this voids the warranty.
No comunication betwen control y dvd
Posted on Jan 19, 2011
5 Suggested Answers
SOURCE: u61 on panasonic dmr es15
I have seen several postings regarding errors for the DMR ES15 recorder. I have resolved errors on my 15 month old device by cleaning the black spool that retains and spins the disc. Using denatured alcohol on a lint free cloth, I carefully cleaned the hub but did not saturate the material. This immediately cleared the no read and unable to record errors. Of course, I had to remove the outside covers to access the inter-workings of the read-writer.
Posted on Aug 10, 2008
SOURCE: DVD DMR-ES15 faulty Error message says
http://forum.videohelp.com/topic349292.html
Posted on Aug 31, 2008
  • 55 Answers
SOURCE: PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Posted on Apr 22, 2009
  • 309 Answers
SOURCE: Panasonic DMR-ES15 DVD recorder startup failure
The unit failed during self check, probably the power regulation board. A check by a qualified TV/VCR repair person is in order.
Posted on Nov 20, 2009
I load up my Panasonic DVD recorder and it has built in freeview as well. Every time i load up my box it comes with up with U61 error and the machine makes a funny noise while trying to load the DVD drive...
The unit is carrying out the recovery process without a disc in the tray. The unit detected an error while recording or playing without a disc in the tray. The recovery process restores the unit to normal operation. Have the unit power cord unplug for about 5 minutes, then reconnect. If issue still exist have unit service.
Sep 21, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
U61 Code will not reset - any suggestions?
You have the same issue as the one who is posted here at Fixya. But this requires you to open the DVD cover. If the unit is still under warranty, its best to bring it to the authorized service center. If not, you can try and test this if it'll work.
http://www.fixya.com/support/t221217-u61_error_code
"I have the same problem (same error # same model of DVR).
I noticed it happened after I left a DVD in play mode and paused for a long time.
I saw a message on the Internet that error U61 can mean that the lens is unable to move (return to its normal position).
The Internet message said that person unpluged everything, then opened the cover to the DMR-ES15 (3 screws) and gently pushed the DVD head back towards the rear of the DMR-ES15.
I assume that would void his warranty, but I am considering trying it since the time to have it repaired versus the replacement cost makes the possibility of a "self-repair" attractive.
Here is part of that actual Internet message. I hope it helps you:
Yesterday, my DMR-ES15 started to malfunction, giving me the error U61.
No matter how many times I tried to press Enter, and Power On, the machine
kept re-booting with the error U61. I noticed that the drive was making some noises as if the Read head was not able to park properly.
So I decided to open up the unit and find out why.
I took out the 3 screws holding the top in place. And then moved
the drive head mechanism back (pushed it towards the back of the unit).
I then plugged the power in, turned it on, and amazingly there was no more U61 error.
I test the unit this morning again and everything seems to work properly again!"
Aug 17, 2009 | Panasonic DMRES15 DVD Recorder
From User guide:
Feb 26, 2009 | Panasonic DMRES15 DVD Recorder
DMR-ES15 Stops after 45 Min.
U88 means the unit has detected an error while recording or playing and has entered its recovery process to restore the unit to normal operation. You could try using a DVD-RAM disk or a different make of DVD-R but, as you say the unit is new, you should probably return it to the retailer for exchamge, repair or refund according to unit age and retailer's return policy.
Nov 03, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic dmr es15 dvd recorder
My Panasonic Recorder DMR-ES10, will not play discs sent to me from the U/K,
using a L.G dr275 recorder, onto a DVD+R disc, how can i overcome this problem. regards Tom Escott.
Aug 30, 2008 | Panasonic DMR-ES10 DVD Recorder
U61 on panasonic dmr es15
For U61 errors:
Turn unit off
flip down front a/v input panel
simultaneously press the channel up and stop buttons for at least 10 seconds.
Jan 29, 2008 | Panasonic DMR-ES10 DVD Recorder
U61 error code
UMM the DVD top lid uses FOUR screws. The entire DVD drive is bolted to the chassis with 3 screws.
Oct 14, 2007 | Televison & Video
I get this message occasionally on my Panasonic DMR-ES15. It's actually a really simple fix. It occurs when there is a corruption in the disc which causes the recording mechanism to malfunction. There is a separate error message for this, however it is usually not detected until it's too late. When the recorder asks you to carry out the recovery process, do it. When the disc ejects, make sure you take the disc out that was in there when it occured and throw it away...it will keep happening because the disc is permanently corrupted. However, do not close the tray without a disc or the self-check will fail. Instead pop in a disc of the same format that the error occured in (if it was DVD+RW then put in a DVD+RW). It resolves the problem every time on the first try. (It only happened two times in a year and a half for me). As the manual says the unit is "NOT BROKEN".
May 23, 2007 | Panasonic DMR-ES10 DVD Recorder
Panasonic DMR-EZ27K Logo
243 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
